| 2011+ LML Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |
| 2011 with D.E.Fluid Issues Hello and thisis my first diesel , I love it !!! But I was not well informed on DEF and the salesman at he dealershi wasnt either. I was told I used contaminated fluid and the dealer charged me $300 to drain the tank. I talked othe vice president fo the after market DE fluid and they had no recalls. anyone have issues with DEF? Iwsh I looked this site up before buying , kinds regret getting vehicle with DEF as everytime we go on a trip on the way back I get a fill up or reduced speed , One time I thought I was slick and refueled without shutting down the engine, it reduced my spedd to 55mph!!! it knew I refueled, thats like giving your wife gps tracking on your truck!!! |
| Senior Member Join Date: Oct 2011 Location: Vermont
| Welcome to the forum.Where did you buy the so-called "contaminated" DEF?As with anything in life,you usually get what you pay for; that most likely pertains to DEF as well.I personally would not put any product of questionable quality in my truck.I was not aware that refueling with the engine running will put you in limp mode.
__________________ 2008 LMM Silverado 2500 LTZ ECSB 4X4. Aftermarket calibration,Nicktane with Baldwin BF7587,PPE lift pump with Baldwin BF1212 water separator,285/75/17 Dura Grapplers on H2s,CTS Insight with pyro,Large fender mod. Proud Member U/A Local 693 Plumbers/Pipefitters. |
| Disc Diesel Performance ![]() Join Date: Oct 2008 Location: So Calif.
| There have been issues with this where its not actually the DEF fluid its a sensor in the truck. Do a search for more reading on this but here is one thread that people talk about this. It seems to be more prevalent in the 2011 year. DEF Issues
__________________ ![]() 2013 Chevy CCLB 4X4 Victory Red email us Amsoil Distributor #1466322 Specialist in Longevity, MPG and Easy Maintenance Factory Authorized Nicktane Dealer Filters 4 your Dmax cheaper than most other Vendors Fumoto Valves, FilterMags, Fuel Filter Access Doors CAI, Exhaust, EFI Live by Kory Willis Your Satisfaction is Our Satisfaction! |
| Junior Member Join Date: Dec 2010 Location: Michigan
| Make sure the latest calibrations are installed. If the dealership does not know how to work on the system, find one that does. The system is kinda tricky. Poor fuel quality will also get this message and DTCs to set. We can thank the government for this wonderful system. I can just about guarantee that not one manufacturer would put this on their vehicles if the government did not make them do it.
__________________ 2006 2500HD LBZ 4X4 CC/SB LT3, 265/75R16, Rhino Liner, PCV Reroute, Resonator Plugged, 35w 6K HID Low Beam & Fog Lights, LED Interior Lights, ISSPro Pyro, Boost, & Rail Pressure Gauges in A-Pillar, more to come soon. 1996 K2500 Suburban 7.4L, 265/75R16, Brush Guard, Nerf Bars |
| Moved to LML-- not a 911 problem
| Junior Member Join Date: Oct 2008 Location: JC
| The DEF doesnt know when you filled up your fuel tank. It uses DEF fluid based on your driving habits. If you drive in the city and are heavy on the right pedal you will have more frequent regens which will cause you to go through DEF fluid quicker. If you drive all highway and are easy on it you will have less frequent regens requiring less DEF fluid. Roughly you should get about 1000 miles out of a gallon of DEF fluid. Now for me I regen about every 400-500 miles which I fill my DEF tank about every 6k or so. Hope this helps. Also make sure you find a dealer who knows about the system so they can trouble shoot it better for you and also explain it to you how the system works. good luck
__________________ Smo, 27- living the dream baby 2011 Silverado 2500HD CCSB Z71 ![]() cognito UCA tinted all around debadged/black bowtie 6000k lows and fogs 305/55/20 terra grapplers on level 8 guardians Hoping kory can work a miracle ![]() Electricians LU 325 |
| | eBay Motors #7 (permalink) | |
| Senior Member Join Date: Jan 2011 Location: Olympia, WA
| Quote:
DEF consumption is not related to REGEN. DEF is continually injected into the exhaust, not just during regen. It is injected based on a ratio of fuel consumption, so the more fuel you're burning, the more DEF will be used. You use more DEF when towing than when empty for-example.
__________________ 2011 K2500HD LTZ with DMaxHD and Allison Trans | |
| | eBay Motors #8 (permalink) | |
| Quote:
__________________ Smo, 27- living the dream baby 2011 Silverado 2500HD CCSB Z71 ![]() cognito UCA tinted all around debadged/black bowtie 6000k lows and fogs 305/55/20 terra grapplers on level 8 guardians Hoping kory can work a miracle ![]() Electricians LU 325 | |
| Junior Member Join Date: Aug 2011
| Quote:
The brand from the dealer was GM and since then I only use BlueDEF bought at Wal Mart for under $12 a box. Tim
__________________ 2011 GMC 2500 CCSB 4x4 SLT | |
| Junior Member Join Date: Jul 2012 Location: Alberta Canada
| How did the dealer prove that it was contaminated DEF. Look up the Poor Quality DEF string on this site. I would suspect that the dealer bent you over and didn't even kiss you, let alone give you the courtsey of a reach around!
__________________ 421 EME 14 SVC BTN Tin Basher First in the family to have a '12 Dmax |
