| 2011+ LML Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |
| DuramaxForum n00b Join Date: May 2011 Location: Connecticut
| Trouble keeping prime w/ ADP adapter I installed ADP filter adapter with no problems. Used truck for 2 days then at the end of second day having just used it an hour earlier - started than ran out of fuel. I took everything apart making sure it was all tight. Truck ran for about two weeks now then did it again. I just have to bleed thru the injectors and it works fine. This only seems to happen when I've just used the truck (1-3 hours previously) I did install the filter head spacer and I thought I remember reading concerns about heat. Truck has ~10,000 miles so I didn't think I needed to rebuild the filter head. Another question, how many o-rings are on the ADP adapter? I saw a pic of the nicktane and it had an o-ring on the threaded nipple for the filter but not on my ADP adapter. Any help would be appreciated.
__________________ 2011 K3500HD LT EXT CAB DRW LML- Mocha Steel Metallic |
| DuramaxForum Fanatic Join Date: Jul 2010 Location: Athens, GA
| I had a similar issue with my nicktane unit. The defect is not in the ADP adapter, I know they pressure test them and have not had any issues. The issue is the stock fuel filter head. I rebuilt mine twice and the son of a bitch still leaks, needless to say I have a ADII in my garage I will be installing next week and deleting it
__________________ -Lee- LBZ Crew - EFI - MBRP - Profab - Airdog my "build" threadRaptor lined rockers and flares by me Raptor color match thread ATP Trucks |
| Junior Member Join Date: Oct 2011 Location: Altoona, PA
| I installed my ADP adapter with Cat filter on Saturday morning and ran fine all weekend. This morning I start up to go to work and it idles maybe 5 seconds and shuts off. I had to pump the primer until it got hard, then restarted the engine. Made it to work fine, but I am worried it won't start again when I leave work.
__________________ 2005 Silverado LT 3500 SRW CC LB 6" SuperLift, 315/75/16, LBZ MP, EGR Blocked Last edited by 2300Hz; 12-10-2012 at 09:44 AM. |
| This space for rent! ![]() Join Date: Oct 2011 Location: MT/K.C./FL
| Been having the same issues w/mine. I just installed it last week and the very same thing that you guys are having troubles with mine is doing.
__________________ 05 LT 2500 CCSB 4x4 LLY 11 Harley Road King Classic "Screamin Eagle" 12 F350 King Ranch 6.7l PS Of course all kinds of other stupid "Sh*t" ------ Yes Koho is a fish, but atleast I don't have Walleye vision --------- |
| Duramax Lifetime Supporter Join Date: Apr 2009 Location: Arizona
| Keep us posted . . .I'd like to get one.
__________________ 2007 LBZ 4x4 regular cab S & B Intake - Diablo Predator 285/75/16 Cooper ATP's - 8' Bedslide Amp Steps - Bilsteins - Fumoto |
| DMAX fuel filter heads suck ass. I decided against trying to put lipstick on a pig and trying to retain it and am just doing away with that POS
| | eBay Motors #7 (permalink) | |
| Senior Member Join Date: Feb 2011 Location: SW Ont
| Quote:
If not, what trouble were you having with the stock filter? The other responders have non-LML's in their sigs, presumably also modded.
__________________ 2011 GMC 2500 LML CCSB 4x4 SLT sold 2010 GMC 2500 LMM CCSB 4x4 SLT sold 2004.5 GMC 2500 LLY ECLB 4x4 SLE | |
| Definitely need this issue resolved. Truck would not start after work either. Had to prime again just like this morning. Worked just fine before the adapter install, so it looks like I'll be switching back to stock.
__________________ 2005 Silverado LT 3500 SRW CC LB 6" SuperLift, 315/75/16, LBZ MP, EGR Blocked |
| switch it back to stock. I wasted way too many hours of my life fighting it. Your filter head is trash. And it's going to cost more to replace than the adapter. Unless it just needs rebuilt, but if it wasn't leaking with stock FF then I highly doubt that is your issue
| Senior Member Join Date: Jan 2012 Location: edmond ok and nw ks
| I never tried to rebuild my filter head, even though I hear its easy, I fixed all my starting and dying problems with my ad-II. Apparently they can leak air, but when pressure is applied (via lift pump), still not leak diesel. I have no external diesel leaks, hasn't died since lift pump! Sent from my iPhone using AutoGuide.com Free App
__________________ Curt 05 GMC ccsb slt 4x4 efi live 3"dp 5"straight pipe built trans airdog blocked rerouted lbz mp power steering 95 dodge eclb cummins 4x4 5sp slt 90 F-250 rclb 7.3 4x4 |
