Thanks to this guy that can't drive!! - Chevy and GMC Duramax Diesel Forum
2011+ LML Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
Old 12-26-2012, 11:24 AM   eBay Motors  #1 (permalink)
Aboscamp's Avatar
Wow speechless ... Learn to drive
http://www.google.com/url?sa=t&rct=j...55534169,d.b2I
2008 LMM, 7" RCD susp, Bilstein Shocks, 3 JL amps, Focal speakers, 2 W7 JL subs, Kenwood NAV In Dash (reverse cam), 20x12 Fuel Krank Chrome Toyo M/T 35", N-Fab steps, Viper Alarm, HID's (highs lows fogs) Limo tint
-Airaid Intake, 2" Rear Wheel spacers, Smoked Spyder Tail lights, Retro Solution reverse bulbs
-4" straight pipe MBRP, 6" RBP tip, Firestone air bags, Tierods by Rare Parts, Cognito A arms
-EFI LIVE DSP5 by PBD Diesel Performance
-Air Dog II 165 Lift Pump
-PPE race plug, PPE ported fuel rail, PPE Diff Cover..
-Industrial injection CP3 42% over, Edge CTS Insight
-All season diesel perf EGR Delete
-Diamond Eye Down pipe
Built by PBD Diesel
Tranny is hurting!!!
Aboscamp is offline   Reply With Quote
Old 12-26-2012, 11:37 AM   eBay Motors  #2 (permalink)
The Vigilante MEME Maker
jwcgmc1985's Avatar
Jeff -Proud Member of the "Pup Bro's"- 28
White 2012 LML CCSB LTZ 4x4, all the Options. + NAV/Sunroof/Rear Sliding Glass
-Dropped 7.5" RCX, Sulastics, Cognito UCA's/Supports, DUAL Stabilizer's, Nicktane Cat, Fox's
-S&B Dry + Scoop, Edge CTS, 5" Flo Pro, XRT PRO on Hot, Nfabs, Debadged, 22x9.5 Throttles on 35x12.50
Gray 2008 ECSB LT Silverado "Texas Edition", OEM 20's, 2.5" TGC leveling kit, 2x JL 10"s, RF Amps- Daily Driver
Body Dropped Build Thread - 2001 Sierra / 2000 S10
- Lowering A Lifted Truck - Cognito Support Kit- Cognito UCA kit - How To LML Cat Adapter -Modified Dual Stabilizer Kit-
jwcgmc1985 is online now   Reply With Quote
Old 12-26-2012, 04:24 PM   eBay Motors  #3 (permalink)
Grasshopper101's Avatar
That had to be a set up.
2011 GMC 2500 HD. First ever diesel and loving it.
Grasshopper101 is offline   Reply With Quote
Old 12-26-2012, 04:34 PM   eBay Motors  #4 (permalink)
the SLEDGEHAMMER
2500-HD's Avatar
i dunno, that vw has 309hp/553 ftlb...thats enough to pull that truck if it spun (which it did)
04.5 2500hd
2500-HD is offline   Reply With Quote
Old 12-26-2012, 04:36 PM   eBay Motors  #5 (permalink)
6dot6's Avatar
this was posted already and i think the chevy broke a tie rod after the wheel hop.
- 2010 GMC sierra dually SLT CC -
sdp twins,60 overs, efi by rob, trac bars
built trans/ suncoast 1058 converter
djm 3/5, sleeves and braces, 5inch straight pipe
cts insight, ad2 165, 1pc shaft, reroute
airbags, bt lockbox
thanks to: Bigdipper, ATP, BT Dieselworks, Blackout Performance
time to beat: 12.60 @ 108
6dot6 is online now   Reply With Quote
Old 12-26-2012, 04:37 PM   eBay Motors  #6 (permalink)
Yeah, already heard shit from Cummins buddies on a local site.....
That driver dropped the hammer and started spinning annd bouncing the rear end. He lost any traction real quick. I couldn't really tell from teh video, but I don't think he was in 4wd. He definitely wasn't in 4lo.
2008 2500HD CCSB
EFI Live by Idaho Rob Coddens Adrenaline Truck Performance
4" turbo back MBRP by Pat at BT Diesel
lifted with 35s.
http://www.trollperformance.com/
Originally Posted by oleblack03
Every time I hear someone say that their half-ton will tow as much as my 3/4 ton I just compare it to having sex with your cousin.......it can get the job done.....but the longterm effects can really F%$ something up
Originally Posted by ty_LBZ View Post
A firefighter inherits a bad situation too, but you don't see him throwing gas on the fire...
Jhill is online now   Reply With Quote
Old 12-26-2012, 05:01 PM   eBay Motors  #7 (permalink)
BigDW's Avatar
I have an 84 chevette coupe. I would bet the vehicle if I was in place of the 2500HD and that german car floored it and started bouncing its tires, I could pull it across the parking lot as well.
BigDW is offline   Reply With Quote
Old 12-26-2012, 06:47 PM   eBay Motors  #8 (permalink)
Just looking at it
duramaxbd03's Avatar
yea it looked like the chevy broke a tie rod
but he should of pulled that suv around like nothing
2005 Silverado 2500HD 4x4, Reg Cab LB, LLY, RED
20inch XD Hosses, 305/50/20 Nitto 420s, 3inch drop shackles
Edge Insight, Autometer gauges, 3inch boost tubes
Blackout Performance trans with 1058
Tuned by Blackout Performance
-Jake
duramaxbd03 is offline   Reply With Quote
Old 12-26-2012, 07:05 PM   eBay Motors  #9 (permalink)
zeke38's Avatar
It was defnitley in 4wd. Your tires dont end up facing each other if your in 2 lol
Sent from my SPH-L710 using AutoGuide.Com Free App
2006 LBZ. ATS Stage 2 W/ Co-Pilot. EFI Live. 5" diamond eye. Keys. Tierod Sleeves. CenterLink. Gauges.
zeke38 is offline   Reply With Quote
Old 12-26-2012, 07:29 PM   eBay Motors  #10 (permalink)
That is not a test of HP or TQ either one. That is strictly a traction test and the first one to spin looses. That idiot in the truck couldn't wait to lay some black lines. The VW driver knew what he was doing.
