Fuel filter after 40k - Page 3 - Chevy and GMC Duramax Diesel Forum
2011+ LML Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
Old 12-31-2012, 08:44 PM   eBay Motors  #21 (permalink)
JOKER's Avatar
Originally Posted by Duramax19 View Post
what do dealerships recomend for fuel filter change?
Doesn't really matter what a dealer suggests.
One needs to take into consideration what sort of fuel they are burning and how much of said fuel(s), then make an educated decision.
The interval also depends on the year/model of truck, as the fuel systems differ greatly in sensitivity. While we change out the fuel filter every 7,000 KM on a friend's LB7, I only slap a new one on my LML every 30,000 KM. His LB7 has "finicky" injectors and he runs nothing but died diesel (or the junk we use in equipment on site). My welding rig on the other hand, only gets fuel from the popular gas stations in town.
Check your owner's manual for a GM suggestion, then apply above theory.
No rocket science involved.
Proud Member of "the pup bros"
-'11 GMC Sierra HD 3500 SLE, CC/LB/DRW, LML, 4x4
-'91 GMC Suburban V2500
-'90 GMC Suburban V1500
-'90 Subaru Sambar (DURAMAX KILLER)
-'88 Chevrolet R20 3+3
-'86 GMC Sierra K35 3+3, SRW, mild-350/400/205/60/14FF(welded), 39.5s and 44s / 4" springs, X-over, m15000 rear winch, etc. THREAD
-'86 GMC K2500 reg/long, 350/465/205/44/14SF
-'82 Chevrolet S-10 reg/long/2WD
-Aluminum jet boat 427BBC/SD309
JOKER is offline   Reply With Quote
Old 12-31-2012, 10:42 PM   eBay Motors  #22 (permalink)
Disc Diesel Performance
Dirtbikindad393's Avatar
This is why I preach better filtration because that stuff is fatal if it gets through your filter. I am a true believer in better aftermarket filtration. Things like the Nicktane Auxiliary Filter and the Nicktane Cat adapt. Those with a Fass or AD lift pump get better filtration. No matter what you choose it is money well spent for your Dmax.
As far as filter changes on my 05 that I just sold we changed every 15K miles with the oil change. Make it simple for you, change your Allison spin-on filter and fuel filter at the same time. Many do a 10-15k mile fuel filter change.
2013 Chevy CCLB 4X4 Victory Red
email us
Amsoil Distributor #1466322
Specialist in Longevity, MPG and Easy Maintenance
Factory Authorized Nicktane Dealer
Filters 4 your Dmax cheaper than most other Vendors
Fumoto Valves, FilterMags, Fuel Filter Access Doors
CAI, Exhaust, EFI Live by Kory Willis
Your Satisfaction is Our Satisfaction!
Dirtbikindad393 is offline   Reply With Quote
Old 01-01-2013, 07:02 PM   eBay Motors  #23 (permalink)
I noticed that everybody saying the OP is crazy for going that long before changing does not own a LML. In their older trucks they should change their filters sooner. I agree it all depends on application and good judgement, but changing your fuel filter ever 6K or 10K in a LML truck is a flat waist of time and money. The 100K 5 yr. warranty is based on what that DIC displays. My truck is at 26K and my DIC still says 50% fuel filter life left. I think Ill be changing it soon even though I think it'll be a little unnecessary. The LML is designed to go further on oil and fuel filter life and GM bases their 100k 5yr warranty off of this system and thats good enough for me. If GM weren't possitive that the LML could do what the DIC displays to it's owner, they wouldn't do it, cause after all, within that time, they are the one footing the bill for a failure. As long as the owner isn't stupid enough to poor straight water into the fuel system, the DIC should be sufficient in most cases.
2011 3500 HD SRW LML Duramax
BeatriceLML is offline   Reply With Quote
Old 01-01-2013, 07:11 PM   eBay Motors  #24 (permalink)
TakeEm's Avatar
I want some of this super high quality clean fuel you are running. You are running the same fuel I am and the next guy. Just because you have a LML with a warranty doesn't mean your fuel filters last longer. I don't trust the DIC nor do other members on here. 40,000 miles is a lot on one fuel filter.
A 40$ fuel filter is a lot cheaper than a CP4 pump or injectors. Just saying...
Caleb 22
2007 LBZ CCSB S475/stock Wehrli Twin Turbo Kit/Suncoast Built by Dmitri Millard
EFI Live DSP5 by Duramaxtuner.com
5" DE, rerouted, debadged, demolded, 18X9 BMF Novakanes Stealth wrapped with 285/65/18 Nitto Trail Grappler MTs, 45 gallon transfer flow replacement tank, Amp power steps, All Season bulletproof trans/power steering line kit, Airdog II 165, Nicktane with Cat filter, Edge Insight CTS with pyro
Big thanks, Duramaxtuner.com & Willie @ Synthetic Motorsports
TakeEm is offline   Reply With Quote
Old 01-01-2013, 07:39 PM   eBay Motors  #25 (permalink)
Super Moderator
jc1843's Avatar
If you get dirty fuel, and it damages the injection system-- GM will NOT warranty the damage. Just saying.
Old 01-01-2013, 08:07 PM   eBay Motors  #26 (permalink)
SoCalMike's Avatar
Just change it every other oil change.
SoCalMike is offline   Reply With Quote
Old 01-01-2013, 08:07 PM   eBay Motors  #27 (permalink)
Well then maybe you guys should change your filters after every fill up? From the sounds and concerns of it, sounds like you guys believe your buying Mexico quality fuel. personally I believe in about 25,000mi intervals. Coarse I leave my truck stock, I don't put all those power adders some of you guys do.
Old 01-01-2013, 08:11 PM   eBay Motors  #28 (permalink)
Thebiggids's Avatar
Cool story. You run your ff to the moon an back then...filters are cheap insurance.
Gideon
01 LB7 EC/SB Ally 4x4 shop ornament
DD: 1990 4runner completely stock 4x4 3.slow
Big Thanks To Adrenaline Truck Performance, Alligator Diesel Performance, and Socal Diesel
Thebiggids is offline   Reply With Quote
Old 01-01-2013, 08:15 PM   eBay Motors  #29 (permalink)
Thebiggids's Avatar
10k ^^^^
Gideon
Old 01-01-2013, 08:21 PM   eBay Motors  #30 (permalink)
boostnlb7's Avatar
all diesel can be considered ''dirty'' its a bi-product of gasoline.. it doesnt matter how often everyone tells one another they should change fuel filters.. more filtration and quicker intervals between changes will never hurt a thing, cant do no harm, it can only help, with or without additives.. i think we all take a vow when we buy these trucks that we know our parts most likely arent going to be cheap in the event of replacing things.. id rather spend 40$ and change my filter more often then spend the money it will cost to replace fuel system parts.. the filters are there for a reason and they r made to be changed, thats why they screw on.. lol to each his own. im sticking with the way i been changing mine
couldnt pass hazing to be a "pup bro"
03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos-
auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel
boostnlb7 is online now   Reply With Quote
