| 2011+ LML Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |
| | eBay Motors #31 (permalink) |
| Senior Member Join Date: May 2011 Location: Rupert ID
| Mine is barley long enough to reach the head light with the hood popped open. Doesn't bug me too much but that's just me...
__________________ Silver ccsb lbz 4-6" pro comp lift, Skating 20"s wrapped up in 35" nitto trails,Black 7" axle dumped tip, Debadged, Smoked tail lights Dsp5 @ diesel addiction, Afe cold air intake, Alligator fprv, Alligator cat adaptor w/donoldson filter, PVC re-route, 4" straight pipe, Cobolt boost & egt gauges, Transgo jr. To do list Egr blocker plate |
| | eBay Motors #32 (permalink) | |
| Duramax Lifetime Supporter Join Date: Apr 2012 Location: Casa Grande, Az
| Quote:
__________________ 2012 GMC 2500 SLT 4x4 H&S minimaxx, MBRP downpipe back SS duals, Insight CTS w/backup cam, Fass HD150, PPE rear diff cover, Amsoil front to rear w/by-pass Cognito 4-6 NTBD w/idler/pitman braces, a-arms, Monster energy 18x9 w/BFG KM2s 35x12.5, Recon smoked cab lights Titan 57 gal saddle tank, linex color matched bedliner w/kevlar, Trekstep bed steps x2, RBP rail steps | |
| | eBay Motors #33 (permalink) |
| Junior Member Join Date: Mar 2010 Location: yucaipa
| 15 degrees at work with a wind chill of -25 damn cold but she starts right up.the work trucks we have didnt ford 6.slows but thats a whole diffrenet animal heui injection now thats block heater worthy.The only thing i could think is weak batterys or frozen moisture in the fuel filter or geling.
__________________ 07 GMC lbz CST 6/8 at 7 on 35"Toyo mt's Rob's dsp5 Ppe fprv Ppe ported fuel rail fitting 3" mflow dp s.d.p egr delete 4" mflow tb exhaust into 6" stack ported and polished exhaust side vgt turbo 5/8" backhoe hydraulic tranny lines .pcv reroute danvilleperformance resonator plugs.[I]electronics8000k lo's fogs and reverse lights led parking lamps and signals blue led gauge cluster and HVAC controls.led pyrometer and boost.pyrometer flashes gauge red when I hit my preset temp ridiculous stereo train horns led tails. ![]() |
| | eBay Motors #34 (permalink) |
| and the best way to get the block heater out on my lbz is to take the passenger outer fender liner outmine was burried under the coolant bottle.
| | eBay Motors #35 (permalink) |
| Junior Member Join Date: Jun 2009 Location: Keenesburg CO
| I'm in colorado and haven't had any problems with mine starting at -4F with out plugging it in. If I was you I would take it by the dealer and have the glow plugs checked out because it should start with just one use of the glow plugs I've never had to use my glow plug more than once.
__________________ 2012 GMC 3500 SLT CCLB Steel Gray Duramax Sent on the Nook HD |
| | eBay Motors #36 (permalink) |
| Senior Member Join Date: Feb 2011 Location: SW Ont
| Collimare, did you set the 'elevated idle' to on? It won't make it start any easier, but will improve the rate that engine and transmission warm up.
__________________ 2011 GMC 2500 LML CCSB 4x4 SLT sold 2010 GMC 2500 LMM CCSB 4x4 SLT sold 2004.5 GMC 2500 LLY ECLB 4x4 SLE |
| | eBay Motors #37 (permalink) |
| DuramaxForum n00b Join Date: Jul 2012 Location: Denver, CO
| | eBay Motors #38 (permalink) |
| I routed my plug through the bottom to the front bumper and I wrap the plug cap around one of the transmission lines and I can get to it with no problems. |
| | eBay Motors #39 (permalink) |
| If you have theh DIC buttons, scroll thru and set "elevated idle" to on. You can leave it on all year. It will self activate when the necessary conditions are met. Elevated Idle The engine has a cold temperature high idle feature which elevates the engine idle speed from base idle to 1050 rpm for pickup models or 1200 rpm for van models when outside temperatures are below 0°C (32°F), and the engine coolant temperature is below 65°C (150°F). This feature enhances heater performance by raising the engine coolant temperature faster. This feature can be turned on or off using the DIC buttons. If the vehicle is not equipped with DIC buttons, do the following to turn this feature on or off: 1. Turn the ignition to ON/RUN, with the vehicle off. 2. Press the accelerator pedal to the floor and hold while quickly pressing the brake pedal three times in less than eight seconds. 3. Release the accelerator pedal and start the engine. When the engine is started, it will slowly ramp up to the high idle speed after a delay of a few seconds up to approximately two minutes. For this method to work properly there must be no throttle or brake pedal faults. The engine idle speed will return to normal once the following conditions are met: . Once engine coolant temperature reaches 65°C (150°F). . Air intake temperature reaches 0°C (32°F). The high idle speed will be temporarily interrupted and the engine speed will return to normal if any of the following conditions occur: . The brake pedal is applied. . The accelerator pedal is pressed. . The transmission is shifted out of P (Park) or N (Neutral). . Vehicle speed is detected. Once these inputs are removed, the engine idle speed will slowly ramp back up to high idle after the normal delay, if the conditions for engine coolant temperature and air intake temperature are still met. This is different from the the 'fast idle' control (which is an option) that is manually activated with the cruise control buttons.
| | eBay Motors #40 (permalink) |
| 'Elevated idle' is standard on all Dmax's.
