p204f code - Chevy and GMC Duramax Diesel Forum
post #1 of 15 (permalink) Old 06-26-2013, 04:29 AM Thread Starter
p204f code
What exactly is this? All I can find is p204 which says injector #4. Currently at 106k I'd really hate to think I need injectors already. Couldn't be a worse possible time.
2011 lml still stock
Thanks
2011 LML 2500HD Crew Cab
hunt365 is offline
post #2 of 15 (permalink) Old 06-26-2013, 06:16 AM
Cknight199's Avatar
Warranty?
Sent from AutoGuide.com App
[SIZE="2"]
Caden : LBZ - ET: 12.4 MPH: 108
S475 on stock fueling
Cknight199 is offline
post #3 of 15 (permalink) Old 06-26-2013, 07:22 AM
oobreedenali's Avatar
Originally Posted by Cknight199 View Post
Warranty?
Warranty runs out at 100k
2011 denali duramax. Mods: deleted with H&s mini max.
4'' straight pipe,airdog165, edge cts for gauges,
Leveled with shackles and cranked t-bars, wheels/tires: 20'' fuel
mavericks offsett+20 backspace 5.75''
toyo open country 3312.50R20
Deleted since 11,000k miles. Current miles 133,105k
oobreedenali is offline
post #4 of 15 (permalink) Old 06-26-2013, 10:55 AM
ceide4489's Avatar
Double check that as I believe warranty on injectors is longer than that
ceide4489 is offline
post #5 of 15 (permalink) Old 06-26-2013, 11:37 AM
Do you have a extended Warrenty?
I have a extended 3 year Warrenty on my car just in case i needed it.
Always seems something aways comes up after the original warrenty is over.
Scott
ScottStielow is offline
post #6 of 15 (permalink) Old 06-26-2013, 11:51 AM
Chevytuff19's Avatar
After searching around, it looks like P204F indicates a problem with the DEF system. Time to delete.
2011 GMC 2500HD Duramax Z-71 CCSB SLE
S&B Dry Cold Air Intake
Ranch Hand Front and Rear Replacement Bumpers (Ridgid Dually Lights on Rear (2)), NFAB 6-Step Nerf Bars, RKI Tool Box, Custom Headache Rack w/ Ridgid Dually Lights (4)
Limo Tint All Around w/ Limo Brow
EDGE CTS Insight, Rancho Steering Stabilizer, Backup Camera
3/4" Lift via Torsion Bars (it was all I could get with stock keys), 285/65/18 Nitto Trail Grapplers
GoLight Stryker HID
XRT Pro on Tow with 4" Flo Pro Exhaust
Chevytuff19 is online now
post #7 of 15 (permalink) Old 06-26-2013, 03:59 PM Thread Starter
I hope its DEF / DPF related, I have a black max race tuner i've been waiting to pull the trigger on the delete. Will it be ok like this for a little while besides clearing the code every time i shut down so i can remote start.
hunt365 is offline
post #8 of 15 (permalink) Old 06-26-2013, 05:29 PM
I would try to get it fixed ASAP (either by deleting or having the dealer look at it) just to be safe, but I don't think it will actually hurt anything...could go into reduced power mode, though.
GoLight Stryker HID
post #9 of 15 (permalink) Old 06-27-2013, 12:11 PM Thread Starter
So going to work this morning the service exaust fluid light and message comes on. Made it home with out limping otherwise truck would be dead on side of road full of .40 holes. Took into dealer today DEF pump bad. Pump alone $900. Dealer can not get just the pump due to backorder. Will sell whole tank for $1200. Guess that was the little push i needed to delete. Time to see if i can get an exhaust locally. Can I just take to exhaust shop and have dpf cut off and pipe welded in, if i cant get a delete pipe soon enough. Any thoughts or should I just wait til i can get an exhaust, just get a rental til i can delete.
hunt365 is offline
post #10 of 15 (permalink) Old 06-27-2013, 12:43 PM
You can replace the DPF with a straight pipe. Just make sure to disconnect all the sensors in the factory exhaust and DEF tank. Also, be sure to unplug the EGR stuff under the hood. And, as you probably know, make sure to tune the truck prior to driving it after you do this. I am assuming you already have an unlock code from H&S, correct?
GoLight Stryker HID
