DEF tank heater
72K views 19 replies 9 participants last post by  Kormaster
Just got the code for P20B9 looks like my heaters went out, $249 for the parts will see how changing them goes when I get a min to do it.
#4 · (Edited)
Yip, I would be interested too.
My replacement was under warranty so I figure it's probably going to happen again at some time. I think they stuck GM for over $1K. They didn't give me a copy of the total repair bill, just a receipt that it was replaced under warranty. I saw the $ amount when the service writer had it in their hand. That might have been just for the part and didn't include the labor. By the time they added the labor and DEF fluid charged at the price of Imperial Collection Super Premium Vodka it probably came to about $2K. http://www.complex.com/pop-culture/2012/11/most-expensive-vodkas/imperial-collection
got it installed and everything seems to be working, it released the truck from the limited speed. In the first pic you can see the heater at the bottom, 2nd pic is the level pins
I had a heater code which would prevent my remote start from working until cleared. The dealer replaced the whole tank under warranty. Delete is on the way though I can't wait!!
#12 ·
Not entirely true I have a door module code that reoccurs frequently and does not prevent remote starts. I also had an oil pressure sender go bad which would throw a stop engine message and it would still remote start! Delete is on it's way and I have a free Dyno day at my cousins shop next weekend ����
#14 ·
Campaign - DEF System Components Warranty Extension
# 14652: Special Coverage Adjustment - Diesel-Emission- Reduction Fluid Tank - (Jul 7, 2015)
Subject: 14652 - Special Coverage Adjustment - Diesel-Emission-Reduction
Fluid Tank
Models: 2010-2012 Chevrolet Express
2011-2012 Chevrolet Silverado HD
2010-2012 GMC Savana
2011-2012 GMC Sierra HD
Equipped with 6.6L Diesel Engine (LML/LGH)
Condition
On some 2010-2012 model year Chevrolet Express and GMC Savana vehicles and 2011-2012 model year Chevrolet Silverado HD and GMC Sierra HD vehicles that are equipped with a 6.6L diesel engine (LML/LGH), a malfunction-indicator light (MIL) may illuminate due to an offset in the temperature sensor in the diesel-emission-reduction fluid (DEF) tank reservoir, increased tank-heater resistance, or reductant-system performance.
This special coverage covers the condition described above for a period of 10 years or 120,000 miles (193,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership.
Dealers are to replace the DEF tank reservoir and/or supply module pump. The repairs will be made at no charge to the customer.
For vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after July 7, 2015, are covered by this special coverage and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to July 7, 2015, must be submitted to the Service Contract provider.
Vehicles Involved
All involved vehicles are identified by Vehicle Identification Number on the Applicable Warranties section in GM Global Warranty Management system. Dealership service personnel should always check this site to confirm vehicle involvement prior to beginning any required inspections and/or repairs. It is important to routinely use this tool to verify eligibility because not all similar vehicles may be involved regardless of description or option content.
Parts Information
Service Procedure
^ Verify that the Emission Reduction Fluid Tank Reservoir or Pump Module requires replacement. Refer to the appropriate diagnostic information in SI.
^ If either the Emission Reduction Fluid Tank Reservoir, or Pump Module does NOT require replacement, no further action is required. Inform the customer that any additional diagnosis and repairs are not covered under this special coverage.
^ If the Emission Reduction Fluid Tank Reservoir (2) or Pump Module (3) requires replacement in the DEF tank (1), refer to Emission Reduction Fluid Tank Reservoir Replacement or Emission Reduction Fluid Supply Pump Module Replacement in SI.
Customer Reimbursement - For US
Customer requests for reimbursement of previously paid repairs to correct the condition described in this bulletin are to be submitted to the dealer by July 31, 2016 unless otherwise specified by state law. If this is not convenient for the customer, the customer may mail the completed Customer Reimbursement Request Form and all required documents to the GM Customer Assistance Center. Repairs must have occurred within the 10 years of the date the vehicle was originally placed in service, or 120,000 miles, whichever occurs first.
All reasonable and customary costs to correct the condition described in this bulletin should be considered for reimbursement. Any questions or concerns should be reviewed with your GM representative prior to processing the request.
When a customer requests reimbursement, they must provide the following:
^ A completed Customer Reimbursement Request Form. This form is mailed to the customer or can be obtained through GM GlobalConnect.
^ The name and address of the person who paid for the repair.
^ Paid receipt confirming the amount of the repair expense, a description of the repair, and the person or entity performing the repair.
Important : GM requires dealers to approve or deny a reimbursement request within 30 days of receipt. If a reimbursement request is approved, the dealer should immediately issue a check to the customer and submit an appropriate warranty transaction for the incurred expense. If a reimbursement request is denied, the dealer MUST provide the customer with a clear and concise explanation, in writing, as to why the request was denied. The bottom portion of the Customer Reimbursement Request Form may be used for this purpose. If the denial was due to missing documents, the customer can resubmit the request when the missing documents are obtained, as long as it is still within the allowed reimbursement period.
Warranty transactions for customer reimbursement of previously paid repairs are to be submitted as required by GM Global Warranty Management. Additional information can also be found in Warranty Administration Bulletin 11-00-89-004.
Customer Reimbursement - For Canada and Export
Customer requests for reimbursement of previously paid repairs to correct the condition described in this bulletin are to be submitted to the dealer prior to or by July 31, 2016. Repairs must have occurred within the 10 years of the date the vehicle was originally placed in service, or 193,000 kilometers, whichever occurs first.
- Proof of ownership at time of repair.
- Original paid receipt confirming the amount of unreimbursed repair expense(s) (including Service Contract deductibles), a description of the repair, and the person or entity performing the repair.
Courtesy Transportation - For US and Canada
The General Motors Courtesy Transportation program is intended to minimize customer inconvenience when a vehicle requires a repair that is covered by the New Vehicle Limited Warranties. The availability of courtesy transportation to customers whose vehicles are within the warranty coverage period and involved in a product program is very important in maintaining customer satisfaction. Dealers are to ensure that these customers understand that shuttle service or some other form of courtesy transportation is available and will be provided at no charge. Dealers should refer to the General Motors Service Policies and Procedures Manual for Courtesy Transportation guidelines.
#18 ·
Everybody who has a Diesel Particulate Filter and DEF tank WILL have an issue with the tank heater and then probably the DEF pump. It is not a matter of if it will go bad but when. And it will probably happen right after the 120,000 mile mark. That Urea crap is extremely corrosive and it is going to corrode the heater. I just had this happen and am the 3rd person I know it happen to recently. My brother went to South Carolina and it got a little cold up there a few days ago and his truck went into limp mode. Had to drive straight to the dealer and they told him it was DEF heater. He had about 120,050 miles on his truck and they replaced the heater and fudged the numbers to do it under warranty. Then they sent him on his way and headed home back to Florida and as soon as he got home the DEF pump went out and again went to limp mode and had to go straight to dealer. Would not cover under warranty and had to spend $950 to replace the pump. 2 days later I had the exact same thing happen to my truck here in Central Florida where the temperature dipped into the 40's. My truck had 121,000 miles on it. I took it straight to dealer and they told me it was just out of warranty and i would have to pay to fix it. No way in hell was that going to happen as I know it will just happen again some time down the road. I ordered the EZ link programmer with exhaust, EGR delete and cold air intake. Should have done it when it was new.
#19 ·
Oh, about my last post. My brothers truck is a 2013 LML and my truck is an early 2015 LML.
