My Build Thread - Page 369 - Chevy and GMC Duramax Diesel Forum
2011+ LML Performance Parts Discussion Discussion of Performance Parts For the 07 and up LML Duramax Trucks No Advertising
Old 01-17-2013, 01:35 PM   eBay Motors  #3681 (permalink)
flyin6's Avatar
You people are ruthless!
Just got back from Case. When they pulled the tracks off the dozer, they discovered my frame was cracked on both sides. We're going to grind it all out and reweld, but that costs another $400-$600
2011 Chevy LTZ 6" Fabtech, 2.25" Dirt Logics Road Armor front & rear,Warn 350F fogs,Hella HID's,S&B Intake,H&S XT Pro,MBRP 4" w/muffler,Pro comp 18" wheels,35" Toyo MT's 9K winch,synthetic rope,poly rollers,AD 165,Alligator sump,Opti-Lube,Rare parts tie rods,4.56 gears locker,Amsoil bypass filter/oil,Fumoto valve,GLO diff cover,survival gear,Raptor bedliner,GLO U-bolt flip,relocated shock mounts,Cognito UCA & truss kit,Sulastic shackles,Shotgun mount,Filter rock shields,Edge CTS,resonator block off,HID and LED lights,EGR delete,Alligator downpipe,Hypertech speedo calibrator,Kenwood GPS,Pro-Flow manifolds & up-pipes,Trans pan,3" intercooler pipe, custom rack
Author of: "Distant Thunder"
http://www.duramaxforum.com/forum/20...ld-thread.html
flyin6 is offline   Reply With Quote
Old 01-17-2013, 02:18 PM   eBay Motors  #3682 (permalink)
KensAuto's Avatar
Ahh man, I feel guilty about my wise a** comments now. On another note, I think I saw someone jumping a schoolbus with a red dozer on one of those tv shows a couple weeks ago....the crowd was chanting "chrome stack attack" over and over again in the background. jk Big Don, that does suck, hope they don't find anything else while it's tore down.
2012 GMC 2500 SLT 4x4
H&S minimaxx, MBRP downpipe back SS duals, Insight CTS w/backup cam, Fass HD150, PPE rear diff cover, Amsoil front to rear w/by-pass
Cognito 4-6 NTBD w/idler/pitman braces, a-arms, Monster energy 18x9 w/BFG KM2s 35x12.5, Recon smoked cab lights
Titan 57 gal saddle tank, linex color matched bedliner w/kevlar, Trekstep bed steps x2, RBP rail steps
KensAuto is offline   Reply With Quote
Old 01-17-2013, 04:52 PM   eBay Motors  #3683 (permalink)
Jared Herzog's Avatar
Don thanks for the great build. I have read all posts twice and have really enjoyed all aspects of guns, politics, etc. What are your thoughts on coolant filtration. It looks like the kits are pretty cheap. I am trying to get the best filtration of all fluids.
Jared Herzog is offline   Reply With Quote
Old 01-17-2013, 05:03 PM   eBay Motors  #3684 (permalink)
nmeyer414's Avatar
don, check your email. i sent you some pictures of those spare tire mounts and a couple of other ones that i thought you might find interesting
NATE
06 LBZ, CC SB
52 gal titan
edge juice w/ attitude
nmeyer414 is offline   Reply With Quote
Old 01-17-2013, 05:14 PM   eBay Motors  #3685 (permalink)
flyin6's Avatar
Haven't really thought about that, your thoughts? Others?
Old 01-17-2013, 05:16 PM   eBay Motors  #3686 (permalink)
flyin6's Avatar
Thanks Nate
Good pics!
HMMV, for sure.
You know how that thing swings out??? You could easily mount a hand crank winch on the inside... Was already thinking about that, but since everyone jumped on that deadlift bone I threw out there, I thought I'd keep it close hold until it showed up in pics!
Old 01-17-2013, 05:26 PM   eBay Motors  #3687 (permalink)
flyin6's Avatar
You know, that's OK. At least we found it. That track is going to be spiffy cool! So far they replaced three questionable hoses. Replaced the worn sprokets, Found a support roller wheel all loose and hanging and reinstalled that properly. They crimped new ends on the bat cable, put a fuse in a wire that was added which was a fire hazard, pulled one final drive apart replacing the gaskets that were leaking. Cleaned the air filter system with a new filter, installed two new track adjuster cylinder grease valves which were defective, changed the fluids (Amsoil in the motor) and are replacing the bushings and some pins in the loader lift arms.
With the welded up cracks, I have about a 80% undercarriage, recently rebuilt engine, and all serviced and new everything. I could have purchased another unit for 15K-20K and had to work on it, this way I will have 8K cash and my old gator in it, and it will not be all that far from a new unit. And I even got ugly paint at no extra charge!
Can you just imagine that ugly beast parked on a pile of freshly crushed Kias?
Old 01-19-2013, 02:54 PM   eBay Motors  #3688 (permalink)
flyin6's Avatar
Got a call from R&L trucking.
The bumper will be here Monday!
Old 01-19-2013, 03:05 PM   eBay Motors  #3689 (permalink)
CODE4's Avatar
Hell yes!
2012 2500HD LML
http://zero-signal.org/2500HD/2500HD_sig_small.jpg
SGT/USMC | 0311/8541
CODE4 is offline   Reply With Quote
Old 01-19-2013, 03:06 PM   eBay Motors  #3690 (permalink)
Ford Recovery Vehicle
Georgia Duramax's Avatar
And will be installed Monday afternoon ! Looking forward to seeing pictures of this.
Charlie
2008 GMC 2500HD LMM SLT CC SB 4x4 Z71
Buckstop front bumper, WARN M12000 winch, PIAA 520 ATP driving / PIAA 510 fog, Westin Platinum Series nerf bars, Pace Edwards Bedlocker tonneau cover, Cognito UCA leveling kit and HD Idler Pivot Assembly, Cognito Pitman and Idler steering braces, Bilstein 5100's, LT285/70R17 BFG AT KO tires, 17 x 9 XD Series Crank Wheels, 15% Tint Driver/Passenger windows, GM Tow Mirrors, DDM Tuning HID lights 6000K 35W
Georgia Duramax is offline   Reply With Quote
