Engine Block heater cord - Chevy and GMC Duramax Diesel Forum
2011+ LML Performance Parts Discussion Discussion of Performance Parts For the '11 and up LML Duramax Trucks No Advertising
post #1 of 28 (permalink) Old 09-03-2012, 04:54 PM Thread Starter
I have a 2011 silver ado. But I don't have a plug for cold weather. Told it wasn't really necessary. So not all trucks were ordered with them. Any comments would be helpful.
Builder12395 is offline
post #2 of 28 (permalink) Old 09-03-2012, 05:07 PM
GMC..Professional Grade
KensAuto's Avatar
did you look under passenger battery. thought all the lmls came with one
2012 GMC 2500 SLT 4x4
---Arizona Diesel Club---
Member #19
KensAuto is offline
post #3 of 28 (permalink) Old 09-03-2012, 05:09 PM
Banned
Its not necessary for cold weather startup, but depends on your opinion of cold weather.
what exactly are you asking?
Hondarider552 is offline
post #4 of 28 (permalink) Old 09-03-2012, 05:09 PM
Clubin's Avatar
Yes it has to be there check the owners manual location description will be in there.
2012 Denali HD
Clubin is offline
post #5 of 28 (permalink) Old 09-03-2012, 05:43 PM
rebpdt's Avatar
look through your passenger fender well. its there, probably still ziptied up
CCSB LB7 4x4
rebpdt is offline
post #6 of 28 (permalink) Old 09-03-2012, 05:51 PM
pud383's Avatar
Last November in Colorado it was 0-5 deg every morning and after about 20 sec of wts it started just fine every time didn't rattle at all like the ford did
06 Chevy cc sb lbz
Efi live by engineered diesel egr block off plate 4 in silverline exhaust edge insight with egt probe b&w turn over with companion 5 wheel hitch air bags cat adapter from alligator performance magnaflow dp ad2 165 all on mod sulastic shackles body mounts
04.5 chevy rclb lly
Efi live by kory 4" flopro dp back exhaust Magnaflow dp Egr blocker Edge insight B&w gooseneck bfg ko2
pud383 is offline
post #7 of 28 (permalink) Old 09-03-2012, 08:09 PM
Higher Caliber's Avatar
Some of them dont have it. call a service writer and they will check your vin to see if you have one or not. It is stored zip tied by the passenger's side battery as they said.
11' 2500HD Z71 LT, 4" FloPro turbo back, Motor Ops tunes, Edge CTS, S&B CAI, Fass 150 lift pump, sprayed in bed liner, Ranch Hand front and rear, B & W turnover hitch, Graco Nautilus 3 in 1 X2!
Higher Caliber is offline
post #8 of 28 (permalink) Old 09-03-2012, 09:31 PM
FireRescue's Avatar
I've never seen one that didn't have it, but rather or not if they have been freed up from under the pass. battery/fender well area. Needed to start? That's difference of opinion. My Ohio dealer flat out said (Sales and Service departments) that the Duramax does not need it, nor have it, and what not. Dad reached in, and cut the cord lose and showed them. At that point they wanted to charge a $110 for the option that wasn't even on the window sticker...
Bryan
2011 Chevrolet Silverado 2500HD WT, Victory Red, 4x4, ECLB, Duramax(LML)/Allison, Heavy Duty Towing Package
Insalled: Amp Research, Amsoil, ATS, Autometer, B&W, Back Rack, Bushwacker, Code Alarm, Cognito, DRP, FASS, Goodyear, H&S, Hypertech, Mayhem, MBRP, Plasti Dip, Precision, Ranch Hand, Rearview Saftey, Rhino Linings, Rigid Industries, Rough Country, S&B, Snow Performance, Titan, Warn, Weather Guard
Need the Guts to Install: Frost Fighter.
FireRescue is online now
post #9 of 28 (permalink) Old 09-04-2012, 04:50 AM
Armalite's Avatar
It should be there. Remove the passenger side fender well and you will see it ziptied to the frame...
2015 Dodge Laramie Megacab 4wd
My Build Thread
Armalite is offline
post #10 of 28 (permalink) Old 09-06-2012, 07:23 AM
GMCustomerService's Avatar
Builder12395, the engine block heater is an available option on all the trim levels of the 2011 Silverado. It isn't a standard feature. If you would like me to research the build sheet for your vehicle please, send me the VIN at michelle_renee@gmexpert.com.
Michelle, GM Customer Service
GMCustomerService is offline
