I've gone and done it.. Blew up my LML - Page 9 - Chevy and GMC Duramax Diesel Forum
2011+ LML Performance Parts Discussion Discussion of Performance Parts For the 07 and up LML Duramax Trucks No Advertising
Closed Thread
Old 11-21-2012, 01:08 PM   eBay Motors  #81 (permalink)
Firefighter08's Avatar
Subd to see the possible if any end result.
Jacob
2008 SLE GMC C/C.
4" mbrp, FTE resonator, EFI from duramaxtuner, blocked and rerouted. CAT filter adapter with Donaldson filter.
Firefighter08 is offline
Old 11-21-2012, 01:52 PM   eBay Motors  #82 (permalink)
SouthernSmoke99's Avatar
I wouldn't take it to court. I'm sure the first thing the judge will ask is why are you using an illegal exhaust system?? Removing DPF for use other than sanctioned racing is illegal. Stupid, yes. But the law is the law.
I def feel you're pain though!
2011 LML CC/SB Summit White
Leveled via ProComp, 20'' American Eagle 79 Series wrapped w/ 275/65/R20 Terra Grapplers, Black Nfabs, S&B CAI w/scoop, ScanGauge, H&S Mini Maxx, 4" MBRP dp-back (deleted), Dynamat all around, SimpleSoft Navi,
SouthernSmoke99 is offline
Old 11-22-2012, 09:58 AM   eBay Motors  #83 (permalink)
Thatmarkguy's Avatar
What I see here is that you altered your powertrain (ecm programming, emissions deletions, installed power adders), and in the warranty book it clearly states that the powertrain warranty will be void if any non-factory approved changes are made (my words, but saying the same thing).
GM is not going to do a teardown at their expense - whatever they find (even it their part failed) they will say that the changes you made to the truck caused the failure. You will then have to pay for the time involved in the teardown. You know you voided the powertrain as soon as you plugged the programmer into the socket.
Then if you go to court, as it was said already, removal of the emissions equipment is a federal offense - you will dinged with a minimum of a $10,000 fine for that (and maybe prison to set an example), so you're already in the hole.
I think trying to get GM to do anything is an exercise in futility since you altered your powertrain from stock, they are not going to do anything on their nickel.
You are a mechanic, chalk this up to experience, do the teardown yourself, find out what failed - you're pretty sure it was a piston, if it was, you know that it was probably because of the times you ran your programming a little hotter and/or got on it a little harder. If it died when you were getting on it you could say it was because of the changes you did, but since you were just cruising along and it died, now it's GM's fault? Maybe your hot-rodding weakened the piston or related hardware and it just took time to fail?
You said that you've got other vehicles to drive, rebuild the engine, put in some heavy duty parts, make it better, faster, stronger, (sounds like a TV program) and make this engine a monster.
Good luck.
2011 Chevrolet Silverado 2500 HD LTZ Crewcab Duramax/Allison
RetroSolutions 5000K HID Light Kit
Gaylords X-2000 Tonneau Cover w/remote.
RIP:
2007.5 GMC Sierra 2500 HD SLT Crewcab 6.0 Vortec Weld Velocity 8 Wheels.
Thatmarkguy is offline
Old 11-22-2012, 01:18 PM   eBay Motors  #84 (permalink)
wheelie-king's Avatar
i wanna know how you tuned for the meth??? because i know on turbo gas car it must be tuned for the meth.. if not the air fuel ratio will be way off and the cylinders will detonate!! and this sounds like what happened with your truck because the mini-max doesn't have any tunes for meth!
2012 LT blue LML CC/SB 20% tint 6,k hid's N-Fab Nerf Bars, pioneer avh-p8400bh, MBRP 5'', DRP down pipe, EGR block off with DRP up-pipe, H&S MINI-MAXX, DRP 3'' driver side intercooler pipe ... next thing i need is an AirDog 165
wheelie-king is offline
Old 11-22-2012, 01:23 PM   eBay Motors  #85 (permalink)
Longbeds FTW
DMAXchris's Avatar
My piston cracked while the cruise was set at 75mph. They almost never fail while being ran hard.
06 Dmax/Allison EC/LB 4x4
TTS PowerLoader III • full billet Bully Dog stage 7 • BCI 7" intake with custom snorkle • fender vents • quintuplet shotgun cat stacks • 22" Rockstars • Huge "Dirtymax" sticker • -60% nozzles • extra pcv with dual catch cans • compounded EGR • silencer ring MIA • 4.56 gears • Lowered 5.5" in the back • Lifted 6" in the front • Monster sticker • flat bill mod • 8' CB whip • blacked out reverse lights • gauges everywhere
08 BMW 528xi
00 Buick Regal GS
DMAXchris is offline
Old 11-22-2012, 01:48 PM   eBay Motors  #86 (permalink)
At what power level and for how long? What's best replacement? LB7 pistons?
Jacob
2008 SLE GMC C/C.
Old 11-22-2012, 01:58 PM   eBay Motors  #87 (permalink)
Longbeds FTW
DMAXchris's Avatar
~630rwhp for a year
530 rwhp for 3 years
200+ 1/4 mile passes
43,xxx miles
Mahle Motorsport Race Cast are the best replacement if you're buying new. LB7 pistons are good too, if you can get them for cheap or free. I wouldnt waste my money buying brand new LB7/LLY pistons though. You can get the Mahle Race for about 300 more bucks and they come with rings and pins.
08 BMW 528xi
00 Buick Regal GS
Old 11-22-2012, 02:05 PM   eBay Motors  #88 (permalink)
~630rwhp for a year
43,xxx miles
Good to know for if/when mine go. Thanks.
Jacob
2008 SLE GMC C/C.
Old 11-23-2012, 04:55 AM   eBay Motors  #89 (permalink)
Salt sucks
WVRigRat05's Avatar
Almost. Mine went at 4200 rpms in 4th gear on my big tune getting on the interstate. It was a ticking time bomb though it was tuned for 160k miles.
Reger
Black on Black 05' Silverado 2500 HD 4X4 CC/SB, LBY7, LT. 8580 lbs
Motor died 1/19/12 190.131 mi.
Trans. died 7/27/12 200,136 mi.
Built motor/Trans and tuned by Blackout Performance
some parts to take it.
2011 30' Puma KDBSS
WVRigRat05 is offline
Old 11-23-2012, 06:38 AM   eBay Motors  #90 (permalink)
FC5452's Avatar
If your interested in a parts motor, this may be for you, 2011 Duramax diesel engine 6.6 lml vin 8 2500 3500 GMC Sierra chevy silverado | eBay block looks shot , looks like one heck of a front end shot was taken.
LML with some stuff added
Time to beat: 6DOT6
www.trollperformance.com/
FC5452 is offline
Closed Thread
