| 2011+ LML Performance Parts Discussion Discussion of Performance Parts For the 07 and up LML Duramax Trucks No Advertising |
| Junior Member Join Date: May 2009 Location: MD
| Couple questions! and problems I just installed a fass 150 on my truck and I didnt notice a change at all! is there anyway to check the output pressure on the pump? Also My buddys truck with the same mods seemed to smoke alot more than mine only difference is i have the xrt he has the mini max. I havnt changed my fuel filter recently would this effect power?
__________________ 2011 Denali Duramax -Loaded HID's,Recon smoked cabs,Recon tail lights,Tint all around,H&S xrt pro with 4 inch down pipe back,S&B intake,fass 150,NorCal leveling kit with fox shocks,20 inch fuel rims...more to come |
| Senior Member Join Date: Jun 2010 Location: Fort McMurray Alberta Canada
| The lift pump doesn't do anything for power. All it does is remove air from fuel, separate water and push fuel to the pump thus getting rid of the problem with draining fuel rails when running the hot 150hp tune. That's the only time you will know its there. What setting is your xrt on?
__________________ 2012 GMC 2500HD cc/sb Ultimate GFX Edition Escort 9500ix radar detector, Rancho stabilizer, Rotella T6 synthetic 5w40 engine oil, Allison Transynd transmission oil, H&S mini maxx, FASS Titanium 150, 5" flo pro straight exhaust, Diamond Eye Downpipe, Autometer Cobalt Pyro and Boost Gauges, AFE Stage 2 CAI, ASDP EGR Block Plate. Running on HOT |
| | eBay Motors #3 (permalink) | |
| DuramaxForum Veteran Join Date: Sep 2008 Location: Western MA
| Quote:
__________________ My truck 04.5 LLY CC/SB Slt Djm/mcgaughy drop 20x10 gear 726's Big dipper IV Trans and precision converter Efilive tuned by Tony Martino(Moonshine) 12.95@103.5 w/1.79 60' | |
| | eBay Motors #4 (permalink) | |
| Duramax Lifetime Supporter Join Date: Nov 2011 Location: East Texas
| Quote:
__________________ 2012 lml cc/4wd Road Armor Lonestar Front Bumper, Warn 9.5k, Hella 7" and 4" HID's, Rancho 4" lift w/ 2 3/4" 9000s shocks, Cognito UCA's, 35" Trail Grapplers, RCD Sway Bar Links, Nfab 3step bars,front wheel spacers,sulastic shackles, MA sleeves, s&b c.a.i. dry filter w/ outer wear, resonator block plate, amsoil bypass kit, Fumoto drain valve, amsoil syn/ 15-40 motor oil, amsoil syn/ torque drive transmission, amsoil syn/ torque drive transfer case, fabtech stabilizer, opti-lube xpd, HID 55w 6k lows, L.E.D. bulbs throughout, H&S Mini-Maxx, H&S Pyrometer, Vumaxx mount, Autometer Cobalt Pyrometer, Diamond Eye down pipe, FASS Titanium 150, FASS custom filter cover, MBRP 5" Straight pipe exhaust, 6" Chrome MBRP tip, Custom overhead switches, Fuse banks INSTALL THREAD http://www.duramaxforum.com/forum/20...-2012-lml.html | |
| Quote:
__________________ 2011 Denali Duramax -Loaded HID's,Recon smoked cabs,Recon tail lights,Tint all around,H&S xrt pro with 4 inch down pipe back,S&B intake,fass 150,NorCal leveling kit with fox shocks,20 inch fuel rims...more to come | |
