DPF delete tuning with DPF - Chevy and GMC Duramax Diesel Forum
2011+ LML Performance Parts Discussion Discussion of Performance Parts For the 07 and up LML Duramax Trucks No Advertising
Old 11-28-2012, 12:41 PM   eBay Motors  #1 (permalink)
DURAMAXED OUT's Avatar
so as i said before my dad purchased a H&S XRT pro and wants it just to clear the emissions codes it throws, is it possible to run the DPF delete tuning with the stock exhaust on the stock setting?
2011 LTZ CCSB Z71 4x4,
H&S XRT Pro, 5in MBRP straight,
Banks Full Ram Air Intake (with scoop mod),
FASS 150 lift pump,
Isspro EV2 factory match pyro and boost, Edge CTS
8K HID kit (lows and fogs),
Cobra 29 LT WX with dual 4 ft antennas,
custom pin stripe.
Westin 3in Ultimate Bull Bar
Nitto Trail Grapplers 285/65 R18 (Rims to come)
DURAMAXED OUT is offline   Reply With Quote
Old 11-28-2012, 12:49 PM   eBay Motors  #2 (permalink)
I'm That Guy...
TDFDiesel's Avatar
Not sure that I 100% follow your question, but if you have a higher then stock HP setting and the DPF is in tact you will cause excessive regeneration and build up on the DPF. Eventually most people find that they reach a point the truck can't keep up and a manual forged regen will be required.
I don't know that this has been tested extensively on the LML platform, but when I was looking for tuning with my LMM I was told that you could reach about a 50 or 90hp tune MAX with the DPF in tact.
If you plan to remove the DPF and say it's been deleted, then you will for sure clog the DPF as it's not completed necessary regen cycles.
Tony
TDFDiesel is offline   Reply With Quote
Old 11-28-2012, 12:49 PM   eBay Motors  #3 (permalink)
WildChevys's Avatar
you can run deleted tuning on stock setting, but you need to get rid of the stock exhaust.
2011 Chevy Silverado 2500HD LML
BDS/BMF/Toyo/Pioneer/Alpine/Edge and some more
My Build Thread
2011 Chevy Tahoe
WildChevys is offline   Reply With Quote
Old 11-28-2012, 12:59 PM   eBay Motors  #4 (permalink)
KensAuto's Avatar
Confusing question, but you have a 40hp and 80 hp tune with stock exhaust, the 80 will plug dpf alot faster.
2012 GMC 2500 SLT 4x4
H&S minimaxx, MBRP downpipe back SS duals, Insight CTS w/backup cam, Fass HD150, PPE rear diff cover, Amsoil front to rear w/by-pass
Cognito 4-6 NTBD w/idler/pitman braces, a-arms, Monster energy 18x9 w/BFG KM2s 35x12.5, Recon smoked cab lights
Titan 57 gal saddle tank, linex color matched bedliner w/kevlar, Trekstep bed steps x2, RBP rail steps
KensAuto is offline   Reply With Quote
Old 11-28-2012, 01:16 PM   eBay Motors  #5 (permalink)
You need to run DPF tuning if the DPF is still on the truck, otherwise it will not regen and slowly plug the DPF.
Auston KCCO
2009 GMC D/A CC/SB 4x4
ATP MildMax / Transgo Jr. / aFe stg. 2 / AirDog II 165 / New H2 wheels / Black N-fabs / Edge CTS w/pyro / MA PCV ReRoute / PF Downpipe / MBRP 5" w/muff (bbq black) / MA EGR plate / Bilstien 5100s / Nicktane W/Cat
DuramaxxedLMM is offline   Reply With Quote
Old 11-28-2012, 02:11 PM   eBay Motors  #6 (permalink)
Trying to clarify a little. He has had nothing but problems with the emissions stuff and bought a tuner to eventually get rid of the DPF all together but he doesn't want it loud so he just wants the tuner to clear the codes when it throws them because that's all the dealership is doing. Will it do this? Or do you have to delete the exhaust?
FASS 150 lift pump,
custom pin stripe.
Old 11-28-2012, 02:14 PM   eBay Motors  #7 (permalink)
Okay, well, if you still want it to be quiet but with no dpf, look in to a DPF race pipe. However, this will void the warranty and they will be able to tell if the DPF has been removed due to how many times the truck has done a regen, let alone notice that power output has increased a significant amount by reading the TCM.
Auston KCCO
Old 11-28-2012, 02:23 PM   eBay Motors  #8 (permalink)
will it clear a code in a DPF present tuning??
FASS 150 lift pump,
custom pin stripe.
Old 11-28-2012, 02:25 PM   eBay Motors  #9 (permalink)
KensAuto's Avatar
Yeah, you can use a tuner to clear codes...if its capable. A $20.00 code reader would also. just set the tuner to stock power, no hp added(or +40 or +80), with DPF present
I only said 'if its capable' because I'm using the minimaxx and it reads/clears codes. Can only assume xtr pro does as well. I've cleared codes while on the freeway a few times without stopping
Old 11-28-2012, 02:26 PM   eBay Motors  #10 (permalink)
That would be a question for H&S or someone that already has the product. Sorry.
Auston KCCO
