| 2011+ LML Performance Parts Discussion Discussion of Performance Parts For the 07 and up LML Duramax Trucks No Advertising |
| DuramaxForum n00b Join Date: Sep 2011 Location: Miami, FL
| H&S Tuner Mini Max DPF removed Question I ahvea 2012 LML with the mini max, setting is on no power. But the unit stays on when i shut off the truck, basically it never shuts down. is thsi normal? I have a remote start alarm but not sure if it will affect it. |
| Duramax Forum Supporter Join Date: Nov 2011 Location: New Jersey
| i would check on the H&S forums also
__________________ ![]() 2011 Chevy Silverado 2500HD LML BDS/BMF/Toyo/Pioneer/Alpine/Edge and some more My Build Thread 2011 Chevy Tahoe |
| Junior Member Join Date: Jun 2012 Location: Winston-Salem, NC
| What fuse did you run the power wire to in the fuse box? Aux. heater fuse (45) is the one to use. If you did not run the power wire and are just plugged into the OBDII port the unit will always stay on. There is a power button on the OBDII adapter also...
__________________ 2012 Chevy D/A CC LT Z71 ALL BLACK Stock...for now.:what |
| Duramax Lifetime Supporter Join Date: Sep 2011 Location: Atmore, Alabama
| Does the place you tapped into stay hot with the switch off? have you tried moving the switch on the black box?
__________________ 2013 Silverado 2500HD Duramax Diesel LML CCSB 4x4 LTZ Trim H&S Mini Maxx (just have to push the button to install) Cognito 4-6 lift (5" in front- 3" in rear) Fox Shox Sulastic Shackles Pittman arm and idler arm braces Bushwacker Cut-Out fender Flares (Color Matched) 33x12.50 Toyo MT's on 20" Moto Metal Wheels Recon smoked tail lights w/Recon smoked 3rd brake light Du-Ha under seat storage compartment |
| Duramax Forum Supporter Join Date: Nov 2011 Location: Eastern, PA
| You will have to chase the power wire from the kit to the engine block power hub from the obd adapter thru the firewall if you want the power to come on and turn off with the key. Otherwise like the poster above stated, just flip the little black switch on and off as needed. The unit will not effect your truck alarm or remote start system. Sent from my iPhone using AutoGuide.com App
__________________ LML with some stuff added 13.1@105 Time to beat: 6DOT6 <<<----Real Soon |
| Duramax Lifetime Supporter Join Date: Nov 2011 Location: East Texas
| Yep, pretty much what everyone has already said. Check the fuse you tapped your power wire too, then check the switch on the box...
__________________ 2012 lml cc/4wd Road Armor Lonestar Front Bumper, Warn 9.5k, Hella 7" and 4" HID's, Rancho 4" lift w/ 2 3/4" 9000s shocks, Cognito UCA's, 35" Trail Grapplers, RCD Sway Bar Links, Nfab 3step bars,front wheel spacers,sulastic shackles, MA sleeves, s&b c.a.i. dry filter w/ outer wear, resonator block plate, amsoil bypass kit, Fumoto drain valve, amsoil syn/ 15-40 motor oil, amsoil syn/ torque drive transmission, amsoil syn/ torque drive transfer case, fabtech stabilizer, opti-lube xpd, HID 55w 6k lows, L.E.D. bulbs throughout, H&S Mini-Maxx, H&S Pyrometer, Vumaxx mount, Autometer Cobalt Pyrometer, Diamond Eye down pipe, FASS Titanium 150, FASS custom filter cover, MBRP 5" Straight pipe exhaust, 6" Chrome MBRP tip, Custom overhead switches, Fuse banks INSTALL THREAD http://www.duramaxforum.com/forum/20...-2012-lml.html |
