| 2011+ LML Performance Parts Discussion Discussion of Performance Parts For the 07 and up LML Duramax Trucks No Advertising |
| Junior Member Join Date: Jun 2012 Location: Alberta and North Dakota
| Installed an S&B on my 2013 After alot of reading on this and other forums I decided that I wanted to install an intake on my truck. I know there are alot of people who are set against intakes as they don't really add anything on these trucks. Personal preference and I am happy that I did. Before the intake, the best mileage I saw was 15.5 mpg(15.2 L/100km) on a 1200 km drive from North Dakota to Alberta. Coming from a Dodge that made over 500 hp and averaged mid to high twenties depending on conditons, I haven't been too happy about the mileage. ![]() ![]() The install was pretty simple, actually easier than I thought it would be with all of the extra junk on these new trucks. The worst part was having to work outside as my garage is currently full to the roof storing stuff short term. Not too many tools needed for the install, anyone who can open their hood should be able to install one lol ![]() I had to remove the support brace at the corner of the engine bay...my hands don't fit under to remove the battery clamp. ![]() ![]() The hose clamps and clips on these duramax engines come apart fairly easy, then removed all of the intake assembly ![]() ![]() ![]() ![]() I decided to install the bottom plate in the airbox, I work in muddy conditions and drive lots of slushy highway in the winter. Also, added the pre-filter ![]() ![]() ![]() ![]() Fits nice, I didn't notice any power increase, a slight bit of turbo noise (wish it was more..) but I did see a bit of an improvement in fuel economy. I went on a sled trip and averaged 17.1 mpg on the way home (13.4 L/100km for my Canadian brothers) ![]() ![]() I haver an H&S tuner waiting to go in, hoping to do delete and exhaust in the spring!
__________________ 2013 2500 Grey Denali, Leveled, RBP 94R 20x10 -12, Nitto Terra Grapplers 305/55r20, Amsoil Bypass kit, Airdog 165 with stock filter delete, Spyder 5"x6" tip, S&B Dry CAI, Duraflap kickback mudflaps, Romik step bars H&S minimaxx, glowshift fuel pressure gauge and 5" Flo-Pro on the shelf waiting to install |
| Senior Member Join Date: Mar 2011 Location: Zanesville, Ohio
| You might get even better MPG if you fill up your tires to the proper air pressure, lol. Anyway, sweet write up! Thanks for the input!
__________________ 2011 Chevrolet Silverado 2500HD WT, Victory Red, 4x4, ECLB, Duramax(LML)/Allison, Heavy Duty Towing Package Insalled: Amsoil, Rhino Lined, B&W, Mayhem Riot w/ Goodyear Duratrac, Bushwacker, Code Alarm, Rigid Industries, AMP Research, Hypertech,Tint, Seat Covers, Rough Country, Plastic Dip, WeatherGuard, Back Rack, H&S Performance, MBRP, DRP, S&B, Cognito Need the Guts to Install: Warn 16.5ti, Frost Fighter, Ranch Hand, Snow Performance, Autometer, ATS, FASS, Titan. http://www.dmaxstore.com, Your Duramax Diesel-Only Shopping Resource |
| lol possibly, but my light comes on when it is 1 psi low! When ever the temperature drops a few degrees the pressure drops a pound and the stupid light comes on.
| Senior Member Join Date: Jul 2011 Location: At the sparkly end of a welding lead.
| Very nice write-up. I saw similar gains in fuel economy when I installed my CAI. The whole "stock intake is good up to 500 hp" statement is probably true, but it certainly does not flow as well as some of the aftermarket CAI kits out there.
__________________ -'11 GMC Sierra HD 3500 SLE, CC/LB/DRW, LML, 4x4 -'91 GMC Suburban V2500 -'90 GMC Suburban V1500 -'90 Subaru Sambar (DURAMAX KILLER) -'88 Chevrolet R20 3+3 -'86 GMC Sierra K35 3+3, SRW, mild-350/400/205/60/14FF(welded), 39.5s and 44s / 4" springs, X-over, m15000 rear winch, etc. THREAD -'86 GMC K2500 reg/long, 350/465/205/44/14SF -'82 Chevrolet S-10 reg/long/2WD -Aluminum jet boat 427BBC/SD309 |
| And the S&B looks nice under the hood to for what its worth
| Junior Member Join Date: Nov 2010 Location: Vail, CO
| nice. Gotta love the S&B. Love mine.
__________________ PERRY 2009 2500 EFI LIVE FROM DUSTIN AT DIESEL ADDICTION 4" STRAIGHT PIPE EXHAUST S&B INTAKE PCV REROUTE 285/70/17 NITTO TRAIL GRAPPLERS |
| DuramaxForum n00b Join Date: Oct 2012 Location: Bakersfield CA.
| Hey jay boom nice write up! Question though, did I see that the S&B intake housing had a removable bottom? Were you to remove the stock airbox mounting plate you could install it open ended? I've been trying to find that out.
__________________ Jorge 2006 CC/DRW Duramax LBZ 4X4 Mods: Diamond Eye 4" Turbo back, True Flow XDi C.A.I. Wish List: Cognito Leveling Kit, Sun Coast T/C, Trans go Jr. Kit, EFI Live |
| EFI'd and lovin it ![]() Join Date: Jan 2008 Location: Roswell, NM
| I put a S&B intake on my truck because I wanted to. I cannot leave anything alone.
__________________ ![]() 06 2500 CREW CAB 4X4 LBZ LOONNGGGGG BED EXHAUST,EFI LIVE,DSP5,TPTUNED BY KORY WILLIS,S&B COLD AIR INTAKE AUTOMETER GAUGES, TRANSGO JR, BLOCKED, TIE ROD SLEEVES... WORK RIG O7.5 3500 CREW,DUALLY, LMM, ROYAL UTILITY BED...STOCK......ISH This is not only your forum you have to share it with over 80,000 others |
| DuramaxForum Veteran Join Date: Oct 2011 Location: TX
| I keep reading these posts about gaining 1-2 mpg by just installing an S&B intake. Maybe I should just pull the trigger and do it, but with my luck I would probably lose mileage. ![]() Very nice write up, though.
__________________ 2011 GMC 2500HD Duramax Z-71 CCSB SLE S&B Dry Cold Air Intake Ranch Hand Front and Rear Replacement Bumpers (Ridgid Dually Lights on Rear (2)), NFAB 6-Step Nerf Bars, RKI Tool Box, Custom Headache Rack w/ Ridgid Dually Lights (4) Limo Tint All Around w/ Limo Brow EDGE CTS Insight, Rancho Steering Stabilizer, Backup Camera 3/4" Lift via Torsion Bars (it was all I could get with stock keys), 285/65/18 Nitto Trail Grapplers GoLight Stryker HID XRT Pro on Tow with 4" Flo Pro Exhaust |
| | eBay Motors #10 (permalink) | |
| Quote:
Mileage gains likely depend on elevation, ambient temperature, etc., so hard numbers will be hard to find and agree upon between people/members who have aftermarket CAI kits. My $0.02 Canadian.
__________________ -'11 GMC Sierra HD 3500 SLE, CC/LB/DRW, LML, 4x4 -'91 GMC Suburban V2500 -'90 GMC Suburban V1500 -'90 Subaru Sambar (DURAMAX KILLER) -'88 Chevrolet R20 3+3 -'86 GMC Sierra K35 3+3, SRW, mild-350/400/205/60/14FF(welded), 39.5s and 44s / 4" springs, X-over, m15000 rear winch, etc. THREAD -'86 GMC K2500 reg/long, 350/465/205/44/14SF -'82 Chevrolet S-10 reg/long/2WD -Aluminum jet boat 427BBC/SD309 | |
