| 2011+ LML Performance Parts Discussion Discussion of Performance Parts For the 07 and up LML Duramax Trucks No Advertising |
| Junior Member Join Date: Sep 2011
| Re-Gear 2011LML 4:63 Rear / 4:56 Front With a lift and 37" tall tires, it's time to re-gear. My gear guru recommends running OEM gears on trucks with single aluminum drive shafts because they are quieter than aftermarket gears such as Motive/G2. Here's the catch: OEM only makes 4:63 rear and 4:56 front. He says that the slight difference won't hurt a thing and not to be concerned with the 1.5% gear ratio difference front to rear. What do you all think?? What would you guys do? I appreciate any input from the board brotherhood.
__________________ 2011 Dmax, CC 4WD SB. 6" ICON Lift & Shocks. BMF 20X9 Novakane 8 Stealth wheels. Nitto Trail Grappler 37" Tires.4:56 G2 Gears, ARB Air-Locker (rear), AMP Research Steps. Custom Firestone AirBags with Warn Compressor. RetroSolutions Hi-Beams and Fogs. Trailworthy Fab 42" LED Light Bar. AirDogII. 400W/120VAC PureSine Inverter. |
| DuramaxForum Enthusiast Join Date: Mar 2011 Location: jackson,nj
| i am not an expert and have no real hard experience with changing gears or even how the work really but i would think that could cause long term damage? im here to learn...im also curious.
__________________ - 2010 GMC sierra dually SLT CC - sdp twins,60 overs, efi by rob, trac bars built trans/ suncoast 1058 converter djm 3/5, sleeves and braces, 5inch straight pipe cts insight, ad2 165, 1pc shaft, reroute airbags, bt lockbox thanks to: Bigdipper, ATP, BT Dieselworks, Blackout Performance time to beat: 12.60 @ 108 |
| Senior Member Join Date: Oct 2011 Location: South Florida
| i would think that it wouldnt hurt anything as long as your in soft sand or mud. but i wouldnt even drive on a dirt road with different sized gears. thats just me though and i dont know jack about gears but it seems like common sence right?
__________________ Nick 2004.5 LLY Chevy ECLB 4x4 charcoal gray EFI Pela Motorsports dsp5, AirDog 165, 3" DE downpipe, 4" DE straightpipe, Edge CTS w/Dash mount, AFE mouthpiece, egr blocked, pcv rerout, resonator plugged, 6" Fabtech RTS lowered down a little, add a leaf, 4" block, Rare Parts tierods, MOOG pitman, idler arm, and idler arm bracket, cognito brace kit (PISK), Rancho steering stabilizer, 35/12.5" toyo's, 20/10" xd satin diesels, horn blasters "train horns", custom 23gal air tank, de-badged, Tow mirrors, 145000 miles 3rd owner, lots of custom dents and scratches |
| The gear guru gave the example of early Ford Bronco's that came equipped with Ford 9" rear ends running 4:09 ratio's and Dana 44 fronts that came with 4:11 ratio's. Came that way from the factory...never an issue.
| Guru said the chain in the transfer case can easily make up for the 1.5% differnece front to rear...also said if it were his vehicle he would opt for the OE gears 4:63 rear and 4:56 front as opposed to having 4:56 rear aftermarket gears that howled a little bit.
| Senior Member Join Date: Jan 2012
| Seems to me with that ratio difference the rear will be pushing the front around, ive herd of rock crawlers putting Lower in the Front to make the front pull the rear for quicker cornering but never reverse.I'm no pro but it dosent seem like a good Idea to me Sent from my iPhone using AutoGuide.com App
__________________ White,06,LBZ,GMC,CC,SB,SLT,82,***miles,17"XD Misfits,305/70-17 Terra Grapps,Leveled Cognito Balljoint UCA's,Alpine deck,Kicker ZX500.1,2-10" Kicker ,PCV reroute,Res. plugged,5"MBRP straight,S&B intake,pipe,6"MBRPTip,Gutted magnaflow cat,AFE MP,EGR blocker, slipyolk,Edge CTS, TransGo Jr,Pro Fab Performance downpipe,AFE IC pipe,Nicktane/donaldson ,FPR plug,Mhale LB7 pistons, LMM rods, clevet bearings and ARP head studs,DS max flow exhaust manifold,new#6 injector,Drilled FRF, Pump rub fix, new trans cooler lines,PPE deep tranny pan,new#6 injector,the motor getting installed By Adams HRC Thanks to him Hes the best in town has saved me lots of $$ http://adamshighrollincustoms.com/[/SIZE] Last edited by STEENOS428; 01-04-2013 at 05:04 PM. |
| Senior Member Join Date: May 2011 Location: Reading, PA
| I wouldn't do it. I'd choose a little humming over a destroyed t-case. JMO
__________________ 07.5 LMM CCSB LT. A couple mods. |
| | eBay Motors #8 (permalink) | |
| Quote:
good luck with everything
__________________ Nick 2004.5 LLY Chevy ECLB 4x4 charcoal gray EFI Pela Motorsports dsp5, AirDog 165, 3" DE downpipe, 4" DE straightpipe, Edge CTS w/Dash mount, AFE mouthpiece, egr blocked, pcv rerout, resonator plugged, 6" Fabtech RTS lowered down a little, add a leaf, 4" block, Rare Parts tierods, MOOG pitman, idler arm, and idler arm bracket, cognito brace kit (PISK), Rancho steering stabilizer, 35/12.5" toyo's, 20/10" xd satin diesels, horn blasters "train horns", custom 23gal air tank, de-badged, Tow mirrors, 145000 miles 3rd owner, lots of custom dents and scratches | |
| Senior Member Join Date: Jun 2010 Location: Santa Clarita, CA
| If your gears are humming I would attribute that to incorrect install not brand of gear. And no, run the same ratio, the difference is too big and will cause issues. Sent from my iPhone using AutoGuide.com App
__________________ 2006 Chevy Silverado 2500HD CCSB LBZ 2wd: EFI Live by IdahoRob|Edge CTS Insight|Holley HP150|Nicktane FF adapter|Diamond Eye 3" downpipe and 4" straight pipe|S&B Intake|Transgo Jr.|EGR Blocked|PPE Race Valve|4" CST spindle|35" Dynapro ATM's| |
| Senior Member Join Date: Jul 2011 Location: At the sparkly end of a welding lead.
| This comes down to your personal preference. Hardly noticeable noise OR longevity of your drivetrain. The difference between 4.63:1 and 4.56:1 is just about the largest spread I would want to run in a daily driver. Personally, I would jump for an aftermarket gear-set over an OEM one, re-gearing or not. If you know what you are doing with pinion/ring gears, setting them up correctly (backlash issues are typically responsible for noise) will yield next to no noticeable noise over OEM... unless the gears have a poor-quality grind. I bet the hum from your 37's will drown out any noise from the aftermarket gear-sets. How often you jump for 4WD and in what sort of conditions needs to be taken into consideration. The mismatched gear-sets will get along just fine in snow/sand/mud or on ice. Less so on dry pavement... Hope that helps you a little bit.
__________________ -'11 GMC Sierra HD 3500 SLE, CC/LB/DRW, LML, 4x4 -'91 GMC Suburban V2500 -'90 GMC Suburban V1500 -'90 Subaru Sambar (DURAMAX KILLER) -'88 Chevrolet R20 3+3 -'86 GMC Sierra K35 3+3, SRW, mild-350/400/205/60/14FF(welded), 39.5s and 44s / 4" springs, X-over, m15000 rear winch, etc. THREAD -'86 GMC K2500 reg/long, 350/465/205/44/14SF -'82 Chevrolet S-10 reg/long/2WD -Aluminum jet boat 427BBC/SD309 Last edited by JOKER; 01-04-2013 at 08:14 PM. Reason: still learning to spell |
