s&b intake help - Chevy and GMC Duramax Diesel Forum
2011+ LML Performance Parts Discussion Discussion of Performance Parts For the 07 and up LML Duramax Trucks No Advertising
Old 01-25-2013, 07:40 PM   eBay Motors  #1 (permalink)
cleandirtymax's Avatar
s&b intake help
I know this has been covered but im on my lunchbreak at work installing my s&b intake. I have a 2013 duramax I swapped the maf sensor over. But what do I do with tje other sensor on my stock airbox? Just leave it unplugged?
cleandirtymax is offline   Reply With Quote
Old 01-25-2013, 07:53 PM   eBay Motors  #2 (permalink)
FC5452's Avatar
Contact the Dealer you got it from and have them send you the right kit. Dry filter kit Item #: 75-5065D Cotton Filter Item #: 75-5065 In the interim put your stock intake back on you'll throw a code.
LML with some stuff added
Time to beat: 6DOT6
www.trollperformance.com/
FC5452 is offline   Reply With Quote
Old 01-25-2013, 07:54 PM   eBay Motors  #3 (permalink)
I remember reading at some point someone had the same issue and they were told just to leave ot alone I think
Old 01-25-2013, 08:05 PM   eBay Motors  #4 (permalink)
FC5452's Avatar
Now that you brought it up, I remember reading that, Though I believe he had to swap the kit out. Here ya go Just installed s&b intake. Check engine light?
Time to beat: 6DOT6
Old 01-25-2013, 09:05 PM   eBay Motors  #5 (permalink)
any idea what that sensor is?
Old 01-25-2013, 09:25 PM   eBay Motors  #6 (permalink)
and will it be safe to drive it for a few days till i get it exchanged
Old 01-26-2013, 02:54 AM   eBay Motors  #7 (permalink)
If you do drive it fuel mileage goes down and check engine light comes on. Not sure what the sensor actually reads
2013 2500 lml leveled w/ s&b intake. Many more mods to come
Oilfieldtrashdmax is offline   Reply With Quote
Old 01-26-2013, 06:32 AM   eBay Motors  #8 (permalink)
FC5452's Avatar
A mass air flow sensor is used to find out the mass flow-rate of air entering a fuel-injected internal combustion engine. The air mass information is necessary for the engine control unit (ECU) to balance and deliver the correct fuel mass to the engine. Air changes its density as it expands and contracts with temperature and pressure. Only thing I can think of why GM is Using two is that the mapping changed. seen this done in injected Gas engines. maybe Kory, Rob have a better explanation in the tuning aspect of it.
Time to beat: 6DOT6
Old 01-26-2013, 06:58 AM   eBay Motors  #9 (permalink)
I put it back to stock. Check engine lights still on. Do I need to disconnect my batteries
Old 01-26-2013, 08:09 AM   eBay Motors  #10 (permalink)
jay_boom's Avatar
What is the part number of your intake? there is a difference between the 2012 and 2013 intakes.
2013 2500 Grey Denali, Leveled, RBP 94R 20x10 -12, Nitto Terra Grapplers 305/55r20, Amsoil Bypass kit, Airdog 165 with stock filter delete, Spyder 5"x6" tip, S&B Dry CAI, Duraflap kickback mudflaps, Romik step bars
H&S minimaxx, glowshift fuel pressure gauge and 5" Flo-Pro on the shelf waiting to install
jay_boom is offline   Reply With Quote
