Go Back   Chevy and GMC Duramax Diesel Forum > Pre Duramax Discussion > 6.2L Diesel Forum
Old 06-25-2008, 09:52 AM   eBay Motors   #1 (permalink)
bbail2x2
New 93 GMC 4x4 needs help, so do I, LOL
I got a really nice deal on this 93 4x4 6.2L auto, but could use some advice, help. can I put on a turbo and where do you get them? junk yard or pro shop?
also I doesn't want to go into 4L. it goes between 2H and 4H but the shifter won't even go past neutral.
also I'm assuming the A/C is R12 or R22. (not sure) it is not cold.
I was told buy the Govt agency that sold it that it smoked but I cannot see any smoke at all. I did find a mouse nest in the air cleaner compartment though. could that do that?
I'm not sure if its a GM, Cummins, or Duramax, anyone know?
I also still need 2 16" 6 lug 4x4 wheels if anyone has some for sale. they are called 1618's off an 88-91 GMC I've been told. see my other post and pic. thanks
1985 Mercedes Benz 300CD Turbo (254K)(still going strong)
1993 GMC 4X4 6.2L Diesel (42K-original)
2000 Silverado ext. cab (Gas-97K)(going)
2000 Monte Carlo (Gas-35K)
bbail2x2 is offline   Reply With Quote
Old 06-25-2008, 11:19 AM   eBay Motors   #2 (permalink)
gr8shot
gr8shot's Avatar
well I can maybe help you a little bit. The a/c is most likley R12. You can buy a kit to convert it to 134a. That way its alot cheaper to recharge it. Mine's been converted so it was cheap to recharge it. Listen and see if the compressor is turning on too, if its low it shoudn't even turn on.
the 4wd... In order to shift into low, you have to do the following. Be in gear, let off the brake so your moving at idle speed, then shift the tranny to neutral, and shove it hard into 4LO while your moving, then shift tranny back to "D". To shif out its the same thing, idle speed, shift tranny to neutral, and yank hard out of 4LO while your still moving, then shift tranny back to "D". My truck I have to really shove it to get it to go. It's always been that way. 4HI can be shifted in and out on the fly, whenever you want. Just let off the gas and shift in to 4HI, let off gas and shift out of 4HI. Wouldn't use it on dry pavement though.
The 6.2L motor is a GM motor. It was used before and at the same time as the 6.5L. I know that banks used to (long time ago) make turbo kits for 6.2's. You may be able to steal the hardware from a 6.5L turbo, but I'm not very sure.
And yes the mouse nest could make it smoke, and it is a diesel, so it will smoke black a little, thats normal.
Old 06-25-2008, 11:51 PM   eBay Motors   #3 (permalink)
Tow Master
Idiot lookin at the computer
Tow Master's Avatar
I was gonna say word for word what he said! ^^^^^^
If you find out that a 6.5 turbo would work give me a yell! I have a complete motor (with a broken crank) with turbo for sale!
Jason
Old 06-26-2008, 07:09 PM   eBay Motors   #4 (permalink)
bbail2x2
turbo and other stuff
thanks Gr8shot. I tried the 4L in neutral and it worked! wow. Iwas on asphalt backing up and heard a loud bang so I took it out again. I'll check on the turbo fit and get back to you Tow Master, thanks. I found 2 4x4 Alum. 16" rims I was after so it will loog good when I get some new rubber on front. its cleaning up nice. radio and A/C not working but it sure sounds sweet.
Old 06-26-2008, 07:28 PM   eBay Motors   #5 (permalink)
gr8shot
gr8shot's Avatar
Glad I could help! Not sure what the band would be, but I've put close to 300k on my 92 gasser, and haven't had a single problem with my t-case, so hopefully yours is as good for you!! The a/c can be a crapshoot though... If you can find some R12, you can give it a charge and at least see if the compressor will cycle on. With that few miles i'm suprised its not workin. I'd do the 134a conversion though. I also had a $7 connector fail that left my a/c not working for a year. So its tough to say whats keepin it from workin.
Old 06-26-2008, 07:44 PM   eBay Motors   #6 (permalink)
WorkTruck
WorkTruck's Avatar
The radio in my 92 doesn't work either. I found a used radio, brainbox and tape player at a swap meet. Swapped everything out and it works about 30% of the time. I'm about ready to give up on the whole setup and go to Wal-Mart and get a cheap CD player. (I'm not usually a Wal-Mart shopper, but it's just a work truck). Good luck with you radio.
'07 Classic 2500HD ext. cab
nerf bars
delta diamond plate tool box
back rack
Edge Juice w/attitude
K&N CAI
MBRP 4" turbo back w/5" tip
Moto Metal 16 x 9 (hopefully 285's soon!)
04 GMC Yukon Denali
07 Honda Rancher 400 w/ITP Mudlites!
WorkTruck is offline   Reply With Quote
Old 06-26-2008, 11:04 PM   eBay Motors   #7 (permalink)
Tow Master
Tow Master's Avatar
If you go they have the install kit that puts the radio in the hole where the tape player is or just a open hole! I think they have it in black for $10.00? I went to circuit city and bought a tan one to match the interior in my one truck for $25.
Jason
Old 06-26-2008, 11:11 PM   eBay Motors   #8 (permalink)
daddysLBZ
Your wife's in my profile
daddysLBZ's Avatar
Talking Sup noob???
IMO don't but a turbo fer a boat anchor???WTF prob the last of one of dem paper thin blocks that have not made it's way into a drink canJ/KR22 is used in ref for homes only..If ya need advice on how to send er to the scrap,then ya come to the right place!!
2006 GMC 2500HD 4x4{cc,sb,SLE} 90/175hp tune,nocat/muff!Naked pic of wife hanging from the rear view.
Goodies waiting for installation!! LBZpowered!!
2002 GMC 1500 [2wd]5.3 power{98k}20 in wheels on!!!LOOK AT AVATAR<<<<
1987 Monte Carlo SS all orig!!89k.....
1978 Malibu [2 dr!!]too far in the $$$ to ever think of selling..[ZZ4 from GMPP coming in March!!]
HOT SHOT RIG:2002 GMC Yukon XL***312,674 miles***Hytech tuned,K&N cai[not my choice]...Runs like a whore in church...The left lane was meant to pass,move over or we'll run over your assss!!!P.H.inc. Hot shot 7080let he who touch dis sig die...
Old 06-26-2008, 11:15 PM   eBay Motors   #9 (permalink)
Duraski
Duraski's Avatar
BBail2X2 might try when shifting into 4lo to put transmission in neutral then shift transfer case into neutral, then put transfer case into 4low and then shift transmission into gear. Usually works with less bang to transfer case might hear alittle transfer case gear meshing when happens bu usually no bang. to transfer back go back in neutral in transmission to shift back to neutral or 4hi or low in transfer case ( to it when not moving or very slow moving) Just my .02 to save your tranfer case.
2002 2500HD Dur/Al CC SB LS 4x4 Sprayed in bedliner, Sun Visor Star Board running boards from previous owner. Edge w/attitude is installed again.
Next Mods when I have the Cash
4" Stainless Exhaust Single Or Duals?
1967 Camaro RS 327 .30 over Holley 650, Edelbrock hi-rise, Crane Fireball level three cam(torque range 2000 to 8000rpm double bumped heads Hooker Headers 2 inch Duals and thrush turbo muffs,4 Speed Saginaw.
Duraski is offline   Reply With Quote
Old 06-26-2008, 11:21 PM   eBay Motors   #10 (permalink)
daddysLBZ
daddysLBZ's Avatar
Yeah,why not just shift into or outta 4 wheel in neutral???Could help life of case!!
