Truck died while idling...won't start - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 08-01-2011, 05:44 AM Thread Starter
chevyaddict's Avatar
Sitting in the driveway this morning. Cranked right up. About a minute later just died...no sputter or nothing...just died. Turns over good...will not crank. No codes on the reader either.
Any suggestions? Will have to tackle this evening.
2013 Sierra-SLT 2500HD LML 6.6L Z71 CC-SB
Air Lift Load Lifter 5000 Rear Air Bags Kit Soon to add...2" Rear Drop Shackle
Pull a 2006 Keystone Raptor 3712 Toy Hauler
I LOVE MY WIFE! I LOVE MY TRUCK!
Passed down to my son...
2003 Chevy 2500HD LB7 6.6L 4X4 CC-SB -- Edge 'Hot Juice' EJC1000 -- Full-Ported Intake Mouthpiece w/ Plugged Resonator -- Firestone Ride-Right 5000 Air Springs
chevyaddict is offline
post #2 of 6 (permalink) Old 08-01-2011, 05:48 AM
Banned
Pump the primer bulb on the filter housing to see if it is hard. Have you changed the fuel filter lately?
smokinlmm is offline
post #3 of 6 (permalink) Old 08-01-2011, 05:51 AM Thread Starter
Have not changed fuel filter lately. It has about 5K miles on it.
Will check primer bulb, bleeder, and filter first.
post #4 of 6 (permalink) Old 08-01-2011, 07:00 AM
iflyabeech's Avatar
Also make sure the water in fuel plastic nut thing beneath the fuel filter is tight...
2002 Chevy 2500HD Crew Cab 4x4 LB7 Duramax. Edge Juice with Attitude. 285/75-16 Falken All-Terrains. Ranchhand replacement rear bumper and front bambi killer! Banks Monster muffler.
iflyabeech is offline
post #5 of 6 (permalink) Old 08-01-2011, 04:37 PM
Earnhardtfan's Avatar
Sounds like you are loosing prime. Check the fuel filter and WIF sensor. If they are not tight then it will die. Also, can you pump the primer bulb and it gets hard?
Justin 2001 LB7 Silverado 2500HD LT CCSB 4x4.
EFI Live by Idaho Rob, 445K+ and rolling, Undercover Bed Cover, Vortex spray in bed liner, Odyssey Extreme Batteries, Westin steps, Bilstein Shocks, Road Master Active Suspension, M/A Pump Rub Kit, PPE Trans Cooler, MBRP 5" Exhaust, Edge Insight CTS, K&N drop in filter, AirDog II 100 w/ CAT 751, LLY FF Housing w/ Racor, Running on LMM Blacked out Wheels & Michelin LTX M/S2 tires.
ADRENALINE TRUCK PERFORMANCE
Lincoln Diesel Specialties
Merchant Automotive
Earnhardtfan is offline
post #6 of 6 (permalink) Old 08-02-2011, 05:01 AM Thread Starter
The WIF nut was the problem. It had started to back-off...plastic nut on a plastic filter.
Primer bulb worked good after.
Took a few more revolutions to crank this morning, but cranked anyway.
Will keep a close eye the next few days.
Thanks for the help everyone.
