04 Duramax wont start! - Chevy and GMC Duramax Diesel Forum
Old 08-05-2011, 04:12 PM   eBay Motors  #1 (permalink)
Been having problems with the truck not starting, it happens randomly doesn't matter if it's hot or cold. Took it to the dealer they said it wasn't showing any codes, and every time they tried to start it the truck started right up. Got them to replace the filters and change the oil just in case. Still doesn't start. I can spray starting fluid in and it starts up after a few sprays and trys but then does it again later. I've been told that the fuel pump in the tank is messed up. But that doesn't seem right to me. Any suggestions?
boltonn is offline   Reply With Quote
Old 08-05-2011, 04:16 PM   eBay Motors  #2 (permalink)
RyanZ71's Avatar
Could be the fuel pump, only way to know is to have the fuel pressure checked.
2008 GMC 2500 D-Max Crew Cab Long Bed Z71 100% Stock
Real trucks don't need stacks
RyanZ71 is offline   Reply With Quote
Old 08-05-2011, 04:19 PM   eBay Motors  #3 (permalink)
EFI'd and lovin it
Johnasara's Avatar
You do not have a fuel pump in the tank. I would look at the filter head. it could have a hairline crack in it causing it to randomly suck air. When you have a no start issue try pumping the primer bulb until it gets hard. Then start it. You should not need any type of starting fluid.
EXHAUST,EFI LIVE,DSP5,TPTUNED BY KORY WILLIS,S&B COLD AIR INTAKE
WORK RIG
O7.5 3500 CREW,DUALLY, LMM, ROYAL UTILITY BED...STOCK......ISH
This is not only your forum you have to share it with over 80,000 others
Old 08-06-2011, 04:42 PM   eBay Motors  #4 (permalink)
Siewell Dmax's Avatar
Do not use starting fluid on your truck or it will become parts for the rest of us. I second the filter head is probably the problem their are rebuilt o-ring kits from Merchant that you can probably solve that problem.
(FOR SALE) 2004 Silverado 2500 HD, LB7, Resonator capped, shiny mod's - billet door handles and buckets, Centerline Blackfoot forged wheels, and a drop in K&N filter. New Headgaskets, Injectors, Cups, Turbo and Nicktane Cat Filter mod. ****(AND IT IS FOR SALE)****
Siewell Dmax is offline   Reply With Quote
Old 08-07-2011, 12:39 PM   eBay Motors  #5 (permalink)
Truck sat for a day got home sat morning fired right up Is there a pick-up pump in the tank, was told by a mechanic about that possibly being it. John are you talking about the fuel filter? Thanks for the input guys, as you can probably tell this is my first diesel. Don't really know alot about the engines.
Old 08-07-2011, 01:01 PM   eBay Motors  #6 (permalink)
EFI'd and lovin it
Johnasara's Avatar
Yes the fuel filter head. It is the part the filter screws onto. I hear they cause porblems in the earlier years. Merchant automotive carries a rebuild kit. There is no kind of lift pump in the tank the pump is settled in the lifter valley and it actually sickt the fuel through the filter. That is why it will not run when there is a gap in the system.
WORK RIG
Old 08-07-2011, 01:53 PM   eBay Motors  #7 (permalink)
Bob Trailerhauler's Avatar
Been through this problem. A: There is no pickup pump in the tank. I know that because I put a Titan 43 gallon tank in my "03. Pickup and sending unit only. B: My problem was an easy fix. Bought the fuel filter head rebuild kit as mentioned above. Took the new stainless steel bleeder valve out of the kit and replaced the plastic POS that is original equipment. Have not had a problem starting in 2 years. Threw the rest of the kit on the shelf just in case. Haven't needed it.
2003 Extended cab, short bed
GM running boards, Titan 43, Air Lift Bags
Bilsteins all 4, Slider Hitch
Homemade flaps
Montana 29 RK,
Ebbtide 19' 150 horse Johnson, Lowrance Electronics
GPS, Downriggers,
15000 bucks per pound of Fish,
It's worth it!
Bob Trailerhauler is offline   Reply With Quote
