fuel filter air lock - Page 3 - Chevy and GMC Duramax Diesel Forum
post #21 of 30 (permalink) Old 01-18-2009, 11:25 AM
No. It runs strong when running. When I shut down and try to restart the problem is most evident. It takes progressively longer cranks to get the truck to turn over. By this I mean that when I remove and refill / reinstall the filter, the truck starts immediately. Over the course of weeks the cranks get longer, and eventually it fails to start all together. I remove the filter and refill it, then the truck will finally kick over. And the cycle begins again. Its left me pretty puzzled. Maybe I should begin by asking what the priming proceedure really should be? Maybe if I did it correctly I could avoid having to remove the filter.
Thanks,
Jeff
Jeff Rayner is offline
post #22 of 30 (permalink) Old 01-18-2009, 12:09 PM
LHN...We ARE the Joneses
Similar to Bleeding Brakes
Close the bleeder screw. Pump the primer button until firm. THEN, open the bleeder slightly to remove the air, and then close it. Pump up the primer till firm. Open the bleeder again to release the air. Continue the cycle until only fuel sprays with no air when opened , then you are primed.
Some will try to prime with the bleeder left open, and they pump all day on it.
Hook'em_Horns! is offline
post #23 of 30 (permalink) Old 01-18-2009, 12:51 PM Thread Starter
well guys after all your good advice i did it,somthing went boom dont now what yet eather goin to the shop or im goin to learn more abought whats under the hood, ill take all the snikers or advice i can get Thanks Dale
03 - chevy 2500 LT silverrado exstend cab 4x4 set up for 5th wheel
dale u is offline
post #24 of 30 (permalink) Old 01-18-2009, 01:16 PM
Originally Posted by dale u View Post
well guys after all your good advice i did it, something went boom don't know what yet either going to the shop or I'm going to learn more about whats under the hood, ill take all the snickers or advice i can get Thanks Dale
Please...elaborate. What went boom? Literally or figuratively? No one on this site snickers, I don't think...
well, not openly!
post #25 of 30 (permalink) Old 01-18-2009, 01:32 PM Thread Starter
after start up truck went red line for 10-15 sec. now when it turns over its real slow and has a real exsaust buield up like its not clearing out the valves. the boom was when my head exploed
dale u is offline
post #26 of 30 (permalink) Old 01-19-2009, 01:25 PM
jon5212's Avatar
Sounds like you got too much starting fluid in and it self ran itself until destruction.
2001 Chevy 2500 4x4 ECSB, 6 speed with Southbend Clutch, 4" MBRP straight pipe exhaust. EFI Live tuned thanks Brayden and Jarrod!!! Dyno numbers 6-6-09 Fass Diesel Nationals 441 RWHP/900+ RWTQ Yeah baby!
jon5212 is offline
post #27 of 30 (permalink) Old 01-19-2009, 01:42 PM Thread Starter
Thanks, jon5212 this i know, what i dont know is what all was damaged & how much $ thinking used motor if its moor than push rods and valves.
dale u is offline
post #28 of 30 (permalink) Old 01-19-2009, 05:05 PM
jon5212's Avatar
I'm betting you will probably need a full rebuild... you can usually pickup a used engine on ebay for 3-5 grand.
jon5212 is offline
post #29 of 30 (permalink) Old 01-19-2009, 06:07 PM
duramaxin14's Avatar
Hmm, Ok thanks. Only thing is that when I crack that and operate the primer pump fuel comes out. When I remove the filter there is still a head space of air in it. (There is no spillage occuring when I remove the filter.) Any suggestions?
Thanks,
Jeff
Get a new bleeder screw seems to be a common problem. Wish i would have came in here sooner i just done a 03 today that had the same problem. I had to take the diafram apart and work on it from there.
Snow flake 2004.5 D/A Efi live, PPE lift pump, 35inch mudders and a florida stack
13.20@115 mph
duramaxin14 is offline
post #30 of 30 (permalink) Old 01-21-2009, 07:12 AM
You know, I'm confused as anything. I continue to get air into my fuel filter....about an inch and a half of airspace when I drop the filter subsequent to a failure to start. I'm priming the thing, but cannot get the air to remove. My proceedure is as follows: pump the pump till firm....crack the bleeder screw. Repeat several times. Mostly just fuel comes out. occasionally I think I'm seeing a bubble or two, but its almost exclusively fuel. It's nothing like it would be if I were bleeding brakes, for instance. And when I drop the filter its still full of air.
This morning I had to install a new fuel filter in the coffee shop parking lot after the truck failed to start. I replaced the filter just to eliminate it as a problem source. I took the new filter and filled it with fuel then installed it. I pumped the primer and eventually it started.
I appreciate any instruction, really.
Thanks!
Jeff
