fuel filter air lock - Chevy and GMC Duramax Diesel Forum
post #1 of 30 (permalink) Old 01-13-2009, 05:45 PM Thread Starter
Angry fuel filter air lock
03 help-i ran out of fuel, i am 99% sure i have done all the right fixs,new filter , and good seals ,good fuel at prime no air that i can dtect still no start. turning over but have to charge to keep it up, gave 2-3 shots of starting flued (i know its not the best thing to do) i was after this it started and went high rev then died ,now its not turning over the same like its loded up. did i blow it up
dale u is offline
post #2 of 30 (permalink) Old 01-13-2009, 05:49 PM
Yep!
deeretracks's Avatar
If you ran it out of fuel you prolly still got air in the lines. It my take a few times of bleeding and cranking to get her running again. If you have an air compressor you can open the bleed screw and then use the air hose and blow air in the fuel tank to help push the fuel back to the filter. You will need to use a rag to help make an air seal around the air nozzle and the fuel tank filler neck.
Craig
deeretracks is offline
post #3 of 30 (permalink) Old 01-13-2009, 06:03 PM Thread Starter
tried this alredy no luck ,how much air
dale u is offline
post #4 of 30 (permalink) Old 01-13-2009, 06:07 PM
Yep!
you have to remember that there is air in the lines from the CP3 to the injectors so it will take a few times. after you get your batts. charged you can have someone crank the truck for you wile you pump the primmer.
Craig
post #5 of 30 (permalink) Old 01-13-2009, 06:08 PM
mijdirtyjeep's Avatar
Could be lots. try and have someone prime while you crank it over. Leave the bleeder screw closed while you do it and do not crank it more than 15sec at a time then let it sit for a few to let the starter cool down
Jim
mijdirtyjeep is offline
post #6 of 30 (permalink) Old 01-13-2009, 06:29 PM Thread Starter
what do ya think of the high rev after ether shots then differnt cranking did i load it up
dale u is offline
post #7 of 30 (permalink) Old 01-13-2009, 06:36 PM
Yep!
If ya loaded it up or vapor locked it most of the time it wont turn over. Be careful useing starting fluid. If the glow plugs are hot you could blow it up. Prolly what happened is it used what fuel it had in the lines the went to pulling air again. Its common for a diesel to get high revs when they start sucking air.
Craig
post #8 of 30 (permalink) Old 01-13-2009, 06:36 PM
Got me.. I was told to never ever spray ether in our trucks. Someone else might have the answer.
Jim
post #9 of 30 (permalink) Old 01-13-2009, 06:50 PM
i used to spray it in semi's to get them started you just have to use it wisely. or BOOM.... i think everyone has covered the ways to start them after running out of fuel but like Jim said be easy on the starter bc im sure they arent cheap.
2005 Chevy 2500 HD
6.6 Duramax LLY 57000 miles
Ext. Cab, Short Bed. White
Stage IV SC, EFI LIVE.
5" MBRP turbo back exhaust
Raptor 150 GPH lift pump
truxxx leveling/lift kit, 3 in the front 2" in the rear
305/70 16 Mastercraft courser MT tires (33X12.5)
Pro Comp xtreme alloy 6001 series wheels.
PPE Tie Rod Sleeves and Pitman and Idler arm Supports
493 HP and 973 Ft. Lb. Torque 4-5-09
codyt is offline
post #10 of 30 (permalink) Old 01-13-2009, 06:53 PM
SonicAudio's Avatar
WD-40 works better in our trucks than ether. it will run the truck for a few seconds
2001 GMC sle 2500HD 4X4
6.6L Diesel (LB7), Extended cab, Shortbed
PPE standard K&N Air Filter
Kennedy pump rub fix installed
AUTOMETER CARBON FIBER EGT and Aeroforce Interceptor Scan Gauge
LB7 PPE boost increase valve for wastegate
PPE Billet fuel pump pick up kit & Air Dog 150
Excalibur AL-2000 alarm and autostart
carbon fiber tail lights and Amsoil front to back
My truck is a her and i know it because every time I get money she takes it!
SonicAudio is offline
