2001 won't crank replaced batteries, what now? - Chevy and GMC Duramax Diesel Forum
post #1 of 62 (permalink) Old 02-19-2009, 04:27 PM Thread Starter
maxluvr's Avatar
Unhappy 2001 won't crank replaced batteries, what now?
We have a 2001 2500hd Duramax. Pulled on to highway low on fuel. Truck died. Cranked a couple of times then just click. Took out batteries and had them checked. Both were bad. Replaced them but still nothing. Have been told everything from locked up motor and vapor lock to starter and ECM. Please help! We are 850 miles from home!!
maxluvr is offline
post #2 of 62 (permalink) Old 02-19-2009, 04:59 PM
LHN...We ARE the Joneses
Mr Obvious: "Did you ever get fuel?" "Prime it?"
Does it even turn over?
Hook'em_Horns! is offline
post #3 of 62 (permalink) Old 02-19-2009, 05:04 PM
Banned
pull off filters fill em with fuel and put them back on make sure you have fuel in the tank then it will start right up
Chkmeout08 is offline
post #4 of 62 (permalink) Old 02-19-2009, 05:07 PM
strokethis03's Avatar
yeah if it turns over but just wont start change fuel filter and add 5gal of fuel. To tank. Guages are known to be bad. Trust me been there done that
SOLD
TRUCK: 2003 Silverado 2500HD, Ext Cab, Short Bed
TUNER:Quadzilla On 90Hp
EXHAUST:4 Inch Straight Pipe,
INTAKE:K&N CAI With Amsoil Filter And Intake Horn Mod
WHEELS:18 Inch Ultra 248 (Black)
TIRES:285/65/18 Nitto Terra Grapplers
EXTERIOR:Blacked Out Bumpers and Black Diamond Plate Tool Box With Black Bow Tie, Black Nerf Bars. 06 Style Tow Mirrors, De-Badged
SOLD
2006 Chrysler 300c Hemi STOCK!!!!
strokethis03 is offline
post #5 of 62 (permalink) Old 02-19-2009, 05:31 PM Thread Starter
maxluvr's Avatar
It does not turn over. It has ran out of fuel before towing our RV I know how to prime, etc.
2008 Chevy Silverado CC 2500HD Z71 LMM - FASS 95, AFE Stage 2, DPF delete, Duramax Tuners DSP5, Transgo Jr, mbrp down pipe, mbrp exhaust, PPE tie rod sleeves, PPE CP3 fitting, blocked, plugged and rerouted, and on meth
2013 cruze turbo
2010 Polaris RZR +6 super atv long arm kit
[B]1987 Chevy K5 Blazer 5.3 LSX
1970 Chevy C10 - mid resto [/SIZE][/FONT]
1989 LT250R ported polished and stroked
maxluvr is offline
post #6 of 62 (permalink) Old 02-19-2009, 05:35 PM
mijdirtyjeep's Avatar
Are you sure the new batteries you bought were fully charged? I bought two marine batteries, put them in trailered it to the lake only to find both were not charged enough to start the motor...
Jim
mijdirtyjeep is offline
post #7 of 62 (permalink) Old 02-19-2009, 05:35 PM
550racer's Avatar
Send a message via MSN to 550racer
your starter solenoid is probobly shot...i have a trick...twist the jet to start really fast until it starts...like on start, on, start, on, start...really fast...it should start it...
01 Chevy CCSB LB7
EFI By Rob,
M/A Tranny w/ Precision ML converter ,ATS 4000, 5" ATS CAI, Carrillo Rods, Cut/Coated Pistons, Keyed Crank/Cam, Balanced, H Series Bearings, ARP Head/Main Studs, 12mm stroker exergy cp3, 100% over exergy injectors, AIRDOG-II 165 w/ cat filters, Nicktane, MA Mounts, Cognitos, Sleeves, 4" Straight Pipe, Merchant Pump Rub, Bilstein 5100's, Cobalt Boost/Pyro/Fuel, 8000k's, Duratracs 285/75/16, JVC Head Unit,Memphis Speakers, 10" Pioneer @ 1000w...
YOUTUBE Channel of Pulls, Races, Launches, etc: YOUTUBE CHANNEL
-Dillon Student at Michigan Tech University studying Mech & Elec Engineering
550racer is online now
post #8 of 62 (permalink) Old 02-19-2009, 05:36 PM
550racer's Avatar
twist the key i mean!!! sorry
01 Chevy CCSB LB7
EFI By Rob,
post #9 of 62 (permalink) Old 02-19-2009, 05:37 PM
have you checked all the fuses and made sure nothing is loose on the starter? the ignition switch is good?
tate07lbz is offline
post #10 of 62 (permalink) Old 02-19-2009, 05:38 PM
550racer's Avatar
serously try it or put it in nuetral and try to start it...
01 Chevy CCSB LB7
EFI By Rob,
