Starter Problem - Chevy and GMC Duramax Diesel Forum
post #1 of 20 (permalink) Old 06-04-2009, 08:51 PM Thread Starter
05silverado's Avatar
Starter Problem
It's a 2005 LLY. It doesn't do it all of the time maybe once every couple of days. The starter will spin but not engage to crank the engine over. I put a new starter on and checked battery connections and tested batteries. It sounds like the teeth are trying to mesh but they are not. When it does it I just shut the key off and try it again and it always works fine.
Any help would be great.
05silverado is offline
post #2 of 20 (permalink) Old 06-04-2009, 08:54 PM
I would try cleaning the connections at the solenoid to make sure they are clean and able to pass a full current, if they are not, then they may not be allowing the teeth to get enough juice to engage fully.....
bigdaddydiesel is offline
post #3 of 20 (permalink) Old 06-04-2009, 08:55 PM
twinturbo3150's Avatar
sounds like maybe youl need to shim it. The new starter comes with shims, did you notice shims when you took the old starter out?
I dont own a Duramax! I own a Gremlin
twinturbo3150 is offline
post #4 of 20 (permalink) Old 06-04-2009, 08:58 PM Thread Starter
It didn't have any shims with it. All of the connections are clean. I just put the new starter on last night.
post #5 of 20 (permalink) Old 06-04-2009, 11:14 PM
Is it a schucks or autozone brand. They are ALWAYS junk.
2015 LML Dually, 2017 L5P is on order
Toypuller is offline
post #6 of 20 (permalink) Old 06-05-2009, 04:25 AM
that sux, i wuz gonna get a started at autozone...mine iz goin on my cummins !!!
(Mike)2006 Ford F-350...Truck has goodies !!!
pete37922 is offline
post #7 of 20 (permalink) Old 06-05-2009, 11:55 AM
JoshH's Avatar
No shims in a Duramax starter. Unless it gets to the point that it does it all the time, I wouldn't worry too much about it. Mine has done it on occasion too.
2006 Silverado 2500HD
JoshH is offline
post #8 of 20 (permalink) Old 06-09-2009, 08:24 AM
i just had a new starter put in a few weeks ago and now i'm having the same problem. i brought it to the shop and they're telling me that the new starter isn't messhing with a gear in the transmission and that they have to replace that gear. it's coasting me a 1000 bucks to get this done.
The same garage replaced the starter and thats when the issues began. i was having problems starting it before but that turned out to be the fuel filter so the new starter wasn't even needed.
i feel like i'm getting kinda screwed over by the garage, any thoughts or ideas?
2006 GMC SLT 2500HD, LBZ EXT. LONG BOX. DIABLO PREDATOR 85HP TUNE. FLO PRO 4" TURBO BACK SS EXAUST WITH 5" TIP AND NO KITTY, EGR BLOCK PLATE.
2001 F350 LARIAT EXT. LONG BOX. SUPERCHIPS FLASHPAQ PERFORMANCE TOWING TUNE
2009 LEXUS IS250 AWD WITH NAV.
Repeatedly stabbing monkeys with sharpened objects may have an adverse effect on their health, according to a new study.
work horse is offline
post #9 of 20 (permalink) Old 06-09-2009, 09:06 AM
bumpity bump bump
post #10 of 20 (permalink) Old 06-09-2009, 07:49 PM
bump buda bump bada bump bump bump
