I'm stranded.My truck just died and will not restart! - Chevy and GMC Duramax Diesel Forum
post #1 of 15 (permalink) Old 10-04-2009, 03:36 PM Thread Starter
I have a 2003 chevy 3500 1 ton with a 6.6 duramax. I was driving down the road the MIL lamp came on and off a few times then my speedometer just jumped from 30 MPH to 100 mph then from 60MPH it jumped to 100 MPh. After that it just died and will not restart. It acts as if its not getting any fuel and the only code i recieved was P0380. Can someone please help? I'm stranded out of town and dont know what the problem is. thanks for any info
Van44 is offline
post #2 of 15 (permalink) Old 10-04-2009, 03:46 PM
Administrator
ob_1jr's Avatar
:welcome to the forum!!
Do you have any mods on your truck? have you tried to prime your fuel filter? What does your fuel gauge read? When was the last time you changed your fuel filter? I would first try to prime, then if that dont work, drain the filter, and lastly change it. It is kinda weird that the cluster did that, but they are known for going bad. Also that could be a sign one of your batteries are messed up.
2016 GMC Sierra 2500HD Denali
Extang Blackmax Tonneau
X-pel clear bra
SOLD 2004 GMC Sierra LB7
ob_1jr is offline
post #3 of 15 (permalink) Old 10-04-2009, 03:47 PM
Chevyguy08's Avatar
your P0380 code is a Glow Plug Circ Error Circ A, what tuner are you running if you are running one? check the primer to see if it feels hard or spungy
08 LMM is alive and well again with a few add ons
2011 3500 Denali
2011 2500HD LTZ
2011 1500 LTZ
Chevyguy08 is offline
post #4 of 15 (permalink) Old 10-04-2009, 03:55 PM Thread Starter
I have no mods. I'ts just a plane jane 3500 1 ton with the 6.6 Duramax. Also i noticed when i turn the key on i dont hear the fuel pump in the tank running (like u would a gasoline engine) so i tried tapping on it while someone else started it but no luck. still no start. Shouldn't i hear the pump pressurising the fuel from the tank.
Van44 is offline
post #5 of 15 (permalink) Old 10-04-2009, 03:57 PM
delong_1's Avatar
there is no pump in the tank, the injection pump pulls the fuel.
built motor, big turbos, built trans, etc all by me, parts from Elite Diesel
1016 hp
7.1 1/8 @ 100
11.27 @ 105
delong_1 is offline
post #6 of 15 (permalink) Old 10-04-2009, 04:02 PM Thread Starter
i have a dump bed on my truck and i raised it up to look at the tank and there is a pump mounted on top of the fuel tank just like a normal gasoline engine fuel tank would have
Van44 is offline
post #7 of 15 (permalink) Old 10-04-2009, 04:07 PM
maybe thats just the sending unit
2006 gmc slt,full bore exhaust maniflod,leather,dee zee nerf bars,Diamondback hd tonneu cover,cloud rider mud flaps ,trans go jr with bd valve body, cognito level installed uca , ppe tie rod sleeves,atx teflon,pro comp shocks edge evoloution A/T.295/70/17 nitto terra grapplers::die NOW WHERE ARE THE CANADIAN TRANNY BUILDERS
marbles72 is offline
post #8 of 15 (permalink) Old 10-04-2009, 04:07 PM
delong_1's Avatar
im not calling you a liar but are you sure its not just the feed and return lines plus a couple wires for the fuel gauge?
1016 hp
7.1 1/8 @ 100
11.27 @ 105
delong_1 is offline
post #9 of 15 (permalink) Old 10-04-2009, 04:16 PM Thread Starter
I'm not a mechanic but it sounds like u know what you are talking about so yes thats probally what it is. I just thought that it pressurised fuel to the pump.
Ok so i need to start by checking the prime on my filter first right? Maybe it somehow lost its prime and if so i need to fill it up with fuel and it should run right?
Van44 is offline
post #10 of 15 (permalink) Old 10-04-2009, 04:20 PM
Banned
sounds elec. to me, not fuel related. check the bail connectors and connectors to ecm.
make sure the fuses are all good, under the hood especially.
MMLMM is offline
