2003 Duramax Stalling - Chevy and GMC Duramax Diesel Forum
post #1 of 24 (permalink) Old 08-21-2006, 07:11 PM Thread Starter
Joe Momma's Avatar
About a month ago I was towing and at a stop light when the light turned green I gave it lite throttle and it died! I really did not expect it to restart but it did. Fast forward to today not towing pulling out of my daughters school it died on me twice but restarted both times?? 82k trouble free miles (except for that mega dollar leaking water pump)
Help?
Email jwg65@bellsouth.net
Joe
www.chevynova.com
Joe Momma is offline
post #2 of 24 (permalink) Old 08-21-2006, 07:23 PM
Hi, I'm Earth. Have we met?
05_LLY's Avatar
Joe sounds like a bad fuel filter, how long since its been changed? how many miles? dose it run fine other than the stalling?
LAter
Caleb
Hot rodding duramax trucks since 2004
05_LLY is offline
post #3 of 24 (permalink) Old 08-21-2006, 10:51 PM
LIL Kahuna
Monster truck's Avatar
is it a auto or stick?
Dads: 99 2500 Ext Cab Longbed 4X4 3.55s CTD, 5'', 47re, BHAF Outerwear Heat Sheild, Turnbuckle Wastgate, Fuel Pressure, Sucnoast Tripple Disk TC with custom vb work.
Mine: 95 Ext Cab SLT, Loaded, 5spd, 3.54s, Leveled 5'' Lift 35'' Toyos, 4'' Straight, Super B 57/66/14, Stage 2 Sticks, 3GSK, #60 Valve Springs, Stage 2 clutch, Custom Intake, Plateless,Boost and EGT on the pillar.
Monster truck is offline
post #4 of 24 (permalink) Old 08-22-2006, 06:41 PM Thread Starter
Joe Momma's Avatar
Caleb it has been about 15k miles, the last one put on was the new high micron that GM gave away for free.
Junior
post #5 of 24 (permalink) Old 08-22-2006, 06:42 PM Thread Starter
Joe Momma's Avatar
it is auto.
Junior/Joe Momma
post #6 of 24 (permalink) Old 08-22-2006, 07:58 PM
05_LLY's Avatar
15k yep thats where i would start, i change mine every other oil change (about 7000 miles) sometimes sooner due to poor performance due to a dirty fuel filter!
The filters are to small to start with and second they filter such small particals that 1 tank of dirty fuel will plug them right up!!!
Hope this helps!!
Caleb
05_LLY is offline
post #7 of 24 (permalink) Old 08-23-2006, 06:41 PM Thread Starter
Joe Momma's Avatar
What is the best way to change the fuel filter, I have never done this myself.
thanks
Joe momma.
post #8 of 24 (permalink) Old 08-23-2006, 09:13 PM
Administrator
ob_1jr's Avatar
check this link out: http://www.dieselplace.com/forum/showthread.php?t=1508
also, I usually put a plastic bag over the filter after I get it loose enough to pull off by hand so it doesn't spill all over.
2016 GMC Sierra 2500HD Denali
Extang Blackmax Tonneau
X-pel clear bra
SOLD 2004 GMC Sierra LB7
ob_1jr is offline
post #9 of 24 (permalink) Old 09-12-2006, 06:13 PM Thread Starter
Joe Momma's Avatar
The day before I was going to change the filter my truck would turn over but not fire. I have auto start and it has acted up before so I flipped the small switch under the dash to reset it no start. I have the Edge box puggedin under the hood and it has failed before also so I unplugged it, no start. I went to my shop to get some tools to change the fuel filter as suggested, I decided to try to start it, it started. I plugged the edge box back in and it started again no problem. so I changed the filter and it appeared to be aobut 90% dirty. If you forward your email address I have photos of the dirty 15k filter if you know how to post them?
My direct email is jwg65@bellsouth.net. So far it has started with no problems, going on an 8 hour round trip tomorrow. We shall see.
Joe Momma
2003 DM
post #10 of 24 (permalink) Old 09-12-2006, 06:16 PM Thread Starter
Joe Momma's Avatar
Oh yeah by the way the link fo rthe fuel filter replacement was great!! Took aobut 20 min to change. I did not bend the a/c line but I had a helper pull gently on the intercooler line to get the filter to slide by, worked fine. Hope I cannot hurt this big line by doing it this way??
the plastic bag did the trick too!!
Joe Momma
