Breather tube blowing oil - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 10-14-2009, 05:30 AM Thread Starter
I have a stock 2002 4x4 crewcab. blew most of the oil out the breather tube in a matter of minutes. towed it home. filled it up with oil and it runs fine with no misses. any ideas? lots of pressure in crankcase when removing oil fil cap.
95000 MILES
seindhunter is offline
post #2 of 6 (permalink) Old 10-14-2009, 05:35 AM
mijdirtyjeep's Avatar
1st did you just add oil or did you pull the drain plug and see if it had fuel in it. Fuel will be hard to read on the dipstick. You might have lost an injector or 2 and it overfilled your crankcase with diesel, pushing the oil out.
Jim
mijdirtyjeep is offline
post #3 of 6 (permalink) Old 10-14-2009, 05:39 AM Thread Starter
no didnt drain oil. would it blow it out till it was a gallon and a half low if it was an injector?
post #4 of 6 (permalink) Old 10-14-2009, 05:43 AM
It might not of been a gallon and a half low! It might of had a gallon and a half of diesel in it, and that is hard to read on the dip stick. I would drain the oil and see how much comes out. You might need a 5gallon bucket if I am correct. Tiss the time of the year that more injectors start taking a crap!!!
Jim
post #5 of 6 (permalink) Old 10-14-2009, 05:44 AM
If it was coming out of the tube at the front of the oil pan, that is usually a sign that it is injectors.
EDIT: There are also two other possibilities
1: PVC tube plugged and forcing pressure to build up in the oil pan "Not likely it would blow that much out at one time"
2: Hole in your piston, but you would also have a severe loss in power
Jim
post #6 of 6 (permalink) Old 10-14-2009, 10:02 AM Thread Starter
thanks for your help.
Does appear to be an injector problem. Oil is diluted with fuel
