No juice to starter - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 02-06-2008, 12:11 PM Thread Starter
No juice to starter
My husband has a 2003 Chevy Duramax Deisel. When he turns the key, nothing happens. No juice to little wire but if he uses a screwdriver accross the 2 terminals on the solenoid, it starts. I have not been able to find repair manual so we can figure out how to fix it (we have a friend that will do it for us for free once we find the problem).! I am new to this site and as I am female, I know now what a male must feel like when his wife sends him to the store for "female products". Because of the problem of the truck not starting with the key, we have not been able to dive the truck in about 2 weeks. With over 8 inches of snow here, my Camero is not the best car to be the only working one. Hope I did not post this in wrong forum. Does anyone know where we can get a repair manuel?
Last edited by Kari Anderson; 02-08-2008 at 02:57 PM. Reason: Not sure if I am in correct forum
Kari Anderson is offline
post #2 of 5 (permalink) Old 02-06-2008, 01:13 PM
Administrator
ob_1jr's Avatar
sounds like a bad starter. You can go to alldatadiy.com and buy a subscription for less than $15. How old are the batteries? One battery can be bad and draw down the whole system. BTW, welcome to the forum!
2016 GMC Sierra 2500HD Denali
Extang Blackmax Tonneau
X-pel clear bra
SOLD 2004 GMC Sierra LB7
ob_1jr is offline
post #3 of 5 (permalink) Old 02-06-2008, 05:45 PM
BryanVilaubi's Avatar
Check the Neutral Safety Switch on the drivers side of the tranny. It has a plastic white cover on it with two plugs that the shift cable feeds to. It can be just a hair off and cause the problem you are having. Just loosen the two bolds that hold it on and rotate it a LITTLE bit at a time then give it a shot. Sometimes it will fix the problem!! Welcome to the site.
2003 GMC Sierra LB7
New motor in the works as we speak with lots of goodies!!!
BryanVilaubi is offline
post #4 of 5 (permalink) Old 02-06-2008, 07:14 PM
John-Boy 331's Avatar
how about a bad ignition switch, if the starter was bad it wouldn't be able of being jumped with a screwdriver, but at the same time theres so many relays and safety switches on these trucks now it could be a needle in a hay stack or something in plain site and easy.
2006 LBZ 3500 4x4 cclb/srw lt3, 4" straight pipe, blocked, fingured, 2"plugged
Sold 2011 lml 2500hd 4x4 lt ecsb taupe gray. 3" mbrp down pipe, 4" flo-pro straight pipe, egr and resonator blocks, and efi live autocal w/o any extra horses
Sold 06 LBZ 3500 4x4 single rear wheel regular cab long bed WT, 4" turbo back straight pipe, solid gooseneck, drw wrecker prep springs, blocked, fingured, 2"plugged, and plenty of UWS boxes
John-Boy 331 is offline
post #5 of 5 (permalink) Old 02-07-2008, 05:36 PM
Take out the starter relay under the hood and pop the cover on it open. Stick it back in the fuse box and manually trip the relay. If the starter cranks, then its somewhere between the ignition switch and the relay
2003 GMC Sierra LB7
