| 911 Problems Forum Truck won't start or drive? Post here! |
| Junior Member Join Date: Jun 2008 Location: TEXAS
| Replaced CP3, still no start!!! We have a 2003 2500HD LB7, all stock, no modifications at all. Our problem started with hard starts, then went to no start. We tried all the more inexpensive things suggested to us. Several new filters, bleeder screw, water in fuel sensor and a new fuel filter housing. Nothing worked. We took it to a GM dealer service center and had diagnostics ran on it and they said the CP3 was bad. Their price to fix it was roughly $2500. We decided to do it ourselves. We bought the new cp3 from Oregon Fuel Injection and my husband and a buddy installed it yesterday. Well, we are still in the same boat. Truck still only starts when we put gas on a rag over the intake and it runs great. The diagnostic printout they gave us at the shop said it could also be a bad fuel junction box. Does anyone have any experience with that problem??? I would love to hear any input anyone can give.
__________________ '03 Silverado, 4 Door, Short Bed, 4X4 |
| Senior Member Join Date: Nov 2008
| It may actually be your injectors that are causing the problem. If an injector is leaking it won't ramp up enough pressure to start but you can band-aid fix it to get it running. I would have the dealer check the balance rates and fuel return rates.
__________________ 2001 Chevy 2500 4x4 ECSB, 6 speed with Southbend Clutch, 4" MBRP straight pipe exhaust. EFI Live tuned thanks Brayden and Jarrod!!! Dyno numbers 6-6-09 Fass Diesel Nationals 441 RWHP/900+ RWTQ Yeah baby! |
| DuramaxForum Enthusiast Join Date: Nov 2008 Location: Altamont, New York
| x2 on that but i could be a bad FICM
__________________ Mike 2005 Chevy 2500HD Duramax LLY BANKS ram air intake, MBRP 4" exhaust, CAT DELETE and NO MUFFLER, EGR Deleted, Fisher SS ExtremeV plow, Auto Meter Gauges, Boost, Pyro, Fuel Pressure, turbo resenator blocked off, PCV Reroute. SoCal Stage 1 heads, ARP Studs, BD Manifold, diamond eye down pipe, AFE mouth piece, AFE intercooler pipes, KMC Rokstars 20" wheels with Nitto Terra Grappler AT EFI LIVE TUNED BY NICK Big thanks to chad at Alligator performancewww.alligatorperformance.com |
| That One Guy ![]() Join Date: May 2008 Location: MN
| Do you have fuel in your oil? Take out the dip stick and put a little drop on at paper towel. The fuel will spread real fast and farther then the oil will and you will be able to tell with the different color rings whats oil and fuel. That will tell you if your injectors are bad if you have fuel in your oil.
__________________ 2002 Crew Cab Short Box, 6" Pro Comp Lift (lowered to 4"), Dark Green and Blacked out. Mods: A little of this a little of that ![]() Built With Help From Some Great Friends and Sponsor Jags Pro Truck Shop! ![]() |
| We'll try the paper towel trick and see what happens. The injectors were replaced about a year and a half ago. Does anyone know if the warranty would replace them again?
| It possible you might be able to get them replaced again because you'll be on the edge of the 7 years/200,000 miles and if you had them replaced once a good dealer might work with you to get them replaced under warranty.
| That would be awesome if we could luck into the injectors being covered by warranty, if that is our problem. I'll contact the dealer first thing in the morning.
| I'm feeling a little better about replacing the CP3 pump. My husband just got back from driving the truck and he says it has a lot more power now. The dealership said our pump was weak, but I thought they were just trying to stick it to us. The truck seemed to run great to me. But, my husband says it definitely has a lot more power now. Just still won't start.
| Just looking at it ![]() Join Date: Sep 2008 Location: North Jackson, Ohio
| how much was the cp3? cause i may be needing one
__________________ 2005 Silverado 2500HD 4x4, Reg Cab LB, LLY, RED 20inch XD Hosses, 305/50/20 Nitto 420s, 3inch drop shackles Edge Insight, Autometer gauges, 3inch boost tubes Blackout Performance trans with 1058 Tuned by Blackout Performance -Jake |
| Senior Member Join Date: Dec 2008 Location: Live at Alberta Beach Near Edmonton
| Dumb question here but what is a cp3 ??
__________________ Youngone (Pat)Black 2009 CCLB 1 Ton LMM 4X4 400 liter in box fuel and tool tank Custom headache rack with lights and side box rails. :rockinStock as she came from GM. I added Recon Smoked Cab Lights. Ring of Fire Tailgate lights and Big Rig Ice Lights. Alberta Beach (Edmonton) Alberta Canada |
