Fuel in oil, Injectors or cp3? - Chevy and GMC Duramax Diesel Forum
post #1 of 19 (permalink) Old 02-01-2010, 10:00 PM Thread Starter
Maxed Ambition's Avatar
Well, did the major build, new Dragonfly +50hp injectors, Banks billet torque coverter, full Transgo shift kit, and Airdog II DF-165. All was great, idle a bit rougher than before, but lots of power. After a couple days noticed high reading on dipstick, drained, had 4 quarts extra. Hooked up a guage onto Airdog, was at 10.5lbs, dialed it down to 5.5lbs, put in new oil, went for a few hour burn, drained oil, 2 quarts extra. Does anyone know if fuel can be pushed past the seal in the cp3 pump? If so, at what pressure? And if the seal goes back into place after the extra pressure is gone? I expect that a bad injector is the problem, just would like to rule out the fuel pressure to the cp3 before I send them to get tested. Thanks for your replies on this brain scratcher, Wade.
2003 GMC Sierra 2500HD, 4x4, 6.6l Duramax.LB7
Add ons, BD Fullbore exhaust manifold, K&N coldair intake, MBRP 4" 304 stainless Cool Duals, The Juice with Attitude, New Dragonfly +50hp Injectors, Airdog II 165gph Demand flow, PPE Boost Valve, Banks Billet Torque Converter, Transgo Full Shift Kit, Autran Syn 295.
Maxed Ambition is offline
post #2 of 19 (permalink) Old 02-01-2010, 10:10 PM
JShe8918's Avatar
Not sure on the other but the reason your truck is not idling smoothly is because of your tuning. Larger injectors require custom tuning with EFI live to get the full benefit. Any particular reason you installed a banks TC? I don't know of anyone here running one. Banks anything = junk. EXCEPT the intake! I wish you well and hope you figure out your problem. But check into efi live from one of our vendors!
2005 LLY ext/sb
EFI live by rob, fass 150, mbrp 4" straight pipe
cognito 9" lift w/ 20" diamos and 37" toyos
Suncoast Gmax w/ 1056 :rockin
"Husker Diesel - 402-502-6961"
JShe8918 is offline
post #3 of 19 (permalink) Old 02-01-2010, 10:17 PM
SDP
Scott@SDP's Avatar
Chances are you have a leak on a return line or possibly feed line, hopefully you don't have a bad injector. You'll need to scan it and check balance rates, rail pressure and return rates. If you can get it to a dealer they should be able to give you this info and tell you what is out of spec, from there you can narrow it down a bit.
Screamin Diesel Performance 360-417-9000 Scott@SDPtwins.com
Compound twin turbo kits with 3" y-bridge and coolant tank for all Duramax's
SDPtwins.com LIKE US ON FACEBOOK!
2016 2.8L Duramax Canyon with SDP Compound twin turbo kit and DSP4 tuning
2009 LMM SDP trans, SDP GT5541/GTX42 twins, 200% injectors, 2x Exergy CP3's, Socal motor, ATP tuned
2002 LB7 SDP twins, ATP tuned, stock motor 11.97@113mph 7,200lbs
2001 LB7 SDP Built transmission, Single SDP S475, ATP tuning
2006 LBZ Race truck build
Scott@SDP is offline
post #4 of 19 (permalink) Old 02-01-2010, 10:18 PM Thread Starter
Tuning should have little to no effect at idle, and so far the torque converter rocks, I even get better mileage in the city now, than I got on the highway before. In the future, PPE looks the best to me. Thanks though.
post #5 of 19 (permalink) Old 02-01-2010, 10:25 PM Thread Starter
Too late, tore it down to see if anything obvious on the return side. Dealer said they couldn't tell for certain what it was by return rates, only that there was a problem. All new washers and seals went back in, all torques to spec.
post #6 of 19 (permalink) Old 02-01-2010, 10:47 PM
JShe8918's Avatar
If you say so..... Just think about it. Search the forums about it and contact a few vendors and see what their recommendations are.
2005 LLY ext/sb
JShe8918 is offline
post #7 of 19 (permalink) Old 02-01-2010, 11:03 PM Thread Starter
I'm not saying I don't like EFI, really I know nothing about it. Just thought a set tune was safer than one you download. Educate me! Anyway, the Banks torque converter had better specs, 1800ft/lbs, and looked to be better quality than the BD one I was looking at. After talking to Banks, they beat BD's sale price. I am impressed with the changes it has made so far. Since I have this fuel in oil problem, I had only tried the Juice on #4, and even that was sick fast!
Last edited by Maxed Ambition; 02-01-2010 at 11:31 PM. Reason: more complete answer
post #8 of 19 (permalink) Old 02-02-2010, 10:14 AM
Motox536's Avatar
Just wondering if you figured out what the problem was. Kinda have the same situation right now.
Motox536 is offline
post #9 of 19 (permalink) Old 02-02-2010, 10:49 AM
SDP
Scott@SDP's Avatar
Give IdahoRob a call and he'll help you with the tuning part. I used to have the same tuning you are running and have used PPE for a while as well, neither compare to EFI live with Rob doing the tuning. The canned tunes don't factor in your slightly larger injectors either.
Hopefully the new fuel line gaskets solves the issue, I haven't heard of a CP3 leaking oil into the crankcase.
post #10 of 19 (permalink) Old 02-02-2010, 11:38 AM
DuraTitus's Avatar
Do you still have the problem after the new return line seals?
DuraTitus is offline
