Advice needed for front end problems - Chevy and GMC Duramax Diesel Forum
post #1 of 12 (permalink) Old 02-06-2010, 01:31 PM Thread Starter
joecar's Avatar
I just replaced my driver's side front hub because the original had about 1/4 inch of play at the edge of the tire. I replaced the hub and have been listening to my truck just to be safe, and I have what sounds like a bad bearing on the same side. It sounds like either that or like brakes are metal on metal. It does it at between 25 and 30 mph. You can hear it best with the windows up. I have inspected the brakes and the pads look great. Lots of life left. There are no obvious signs of odd wear on the disc or pads. I rotated the tires and the noise stays on the driver's front. The tires only have 5,000 miles on them. I don't want to just start throwing money at this until it goes away. I was wondering what kind of adverse affects it could have on that wheel's disc, pads,etc. if you were driving for a while with that kind of play in the bearing and didn't know it. I mean when that hub is wiggling around like that, the disc has got to be moving around in the caliper right? FYI, Never took this truck off road. 4x4 was just to pull the boat out at the launch on occasion when it was slippery. Just changed all the fluids in the transfer case and front axle(looked fine). What would you do next????
Thanks
2005 Chevy 2500 HD 4x4 CC/SB LS
Dark Gray
70,000 miles
Transynd at 25,000
LBZ MP + LBZ CAI installed at dealer viaTSB
245/75/16 Bridgestone Dueller Revo A/T's
Rhino Liner
joecar is offline
post #2 of 12 (permalink) Old 02-06-2010, 07:12 PM
Maxed Ambition's Avatar
Did you look to see if the wear indicator tab was bent from being bumped during the wheel hub change, or a dust shield bent? Also that your slider surface has lube? Ckeck the simple stuff first, Wade.
2003 GMC Sierra 2500HD, 4x4, 6.6l Duramax.LB7
Add ons, BD Fullbore exhaust manifold, K&N coldair intake, MBRP 4" 304 stainless Cool Duals, The Juice with Attitude, New Dragonfly +50hp Injectors, Airdog II 165gph Demand flow, PPE Boost Valve, Banks Billet Torque Converter, Transgo Full Shift Kit, Autran Syn 295.
Maxed Ambition is offline
post #3 of 12 (permalink) Old 02-06-2010, 07:16 PM Thread Starter
joecar's Avatar
Slider surface??
Dark Gray
70,000 miles
Transynd at 25,000
Rhino Liner
joecar is offline
post #4 of 12 (permalink) Old 02-06-2010, 07:30 PM
Originally Posted by joecar View Post
Slider surface??
The stainless plate that the caliper slides on.
post #5 of 12 (permalink) Old 02-06-2010, 07:36 PM
DuramaxSMOKE11's Avatar
Send a message via AIM to DuramaxSMOKE11
if you over tighten the wheel hub nut you could have crushed the bearings
Mike
2005 Chevy 2500HD Duramax LLY
BANKS ram air intake, MBRP 4" exhaust, CAT DELETE and NO MUFFLER, EGR Deleted, Fisher SS ExtremeV plow, Auto Meter Gauges, Boost, Pyro, Fuel Pressure, turbo resenator blocked off, PCV Reroute. SoCal Stage 1 heads, ARP Studs, BD Manifold, diamond eye down pipe, AFE mouth piece, AFE intercooler pipes, KMC Rokstars 20" wheels with Nitto Terra Grappler AT
EFI LIVE TUNED BY NICK
Big thanks to chad at Alligator performancewww.alligatorperformance.com
DuramaxSMOKE11 is offline
post #6 of 12 (permalink) Old 02-06-2010, 07:46 PM Thread Starter
joecar's Avatar
155 ft lbs was what I used. At least that's what the torque wrench I used was set to.
Thanks
Dark Gray
70,000 miles
Transynd at 25,000
Rhino Liner
joecar is offline
post #7 of 12 (permalink) Old 02-06-2010, 07:47 PM
I think mine was 155 to 175ft/lbs.
post #8 of 12 (permalink) Old 02-06-2010, 07:49 PM Thread Starter
joecar's Avatar
No, I didn't. I'm hoping I got a bad hub. The noise didn't start until then.
thanks
Dark Gray
70,000 miles
Transynd at 25,000
Rhino Liner
joecar is offline
post #9 of 12 (permalink) Old 02-06-2010, 07:52 PM
mileage on the truck? i have had a few 2500's with bad axle bearings
Mike
post #10 of 12 (permalink) Old 02-06-2010, 07:56 PM Thread Starter
joecar's Avatar
70,000 miles. How hard are those to change?
Dark Gray
70,000 miles
Transynd at 25,000
Rhino Liner
joecar is offline
