2002 Duramax won't start - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 04-02-2010, 06:48 AM Thread Starter
Hi all, I'm having an issue. I parked my truck for about 3 days and went to start it up this morning to go to work. Everything seemed fine but she ran for about 2 seconds and shut off. Now it just cranks and no fire. I'm assuming the glow plugs are working as the indicator shuts off the wait to start.
I am left with it possibly (or likely) a fuel issue. When I get home I will try to bleed the filter and prime it and see what happens. I hooked up my programmer to it and it isn't giving me any DTC's. I do have about an 1/8 of a tank, but it is on level ground. My truck is a 2002. I'm at a loss as it was running great when I parked it. Any help would be appreciated. There are no leaks of any fluid underneath it.
A Bad Day On a Bike is Better Than a Good Day at Work!
Now I can tow the bike on the bad day!
'02 2500 HD Silverado Duramax 6.6L
Crew cab L/B 4x4
Allison
Cattle catcher
Flaspaq programmer
Kneedrg is offline
post #2 of 5 (permalink) Old 04-02-2010, 07:29 AM
Administrator
jc1843's Avatar
It does sound like a fuel issue-- You are correct in try to prime it and if it starts and runs ok. It could be a loose bleeder screw, WIF sensor leak, loose filter, or dry O-Rings in the primer pump. Any of these will cause the problem you are describing.
jc1843 is offline
post #3 of 5 (permalink) Old 04-02-2010, 09:16 AM
DuraTitus's Avatar
Yup had the same thing happen on my 2002 right afert I got it...
Pumped the primer a little bit and it popped right off.
DuraTitus is offline
post #4 of 5 (permalink) Old 04-02-2010, 09:30 AM
maximizer23's Avatar
might be sucking air in somewhere. did you mess with the fuel filter yet? i broke my bleeder screw and used a make shift one until the dealer got one in.
2001 2500HD EC/SB 4x4
Rebuilt Trans, S&B intake, AirdogII 165, 4" pipes, PPE Sleeves, PPE Boost Valve, Turbo Mouthpiece Mod, Cooper ATP's 285/70/17 on Vtec rage wheels, ProComp es9000 shocks, EFI from Idaho Rob
maximizer23 is offline
post #5 of 5 (permalink) Old 04-02-2010, 04:33 PM
pezsez's Avatar
or it may be a cracked bleeder screw like a hairline fracture thats what happened with mine.
2003 durmax, with allison tranny, edge juice, airaid air intake, optima batteries, mbrp 5 inch exhast, mid section cat delete, 6 inch lift, biltein shocks in front, resivoior procomps in the rear, 35 procomp xtreme AT , on rock star rims
pezsez is offline
