2002 6.6L Duramax, Fuel Problem - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 04-07-2008, 05:18 PM Thread Starter
Starts only with ether or wd40. Runs fine once started. Shut off I have to use ether or wd40 again.
sneadsferrytruck is offline
post #2 of 6 (permalink) Old 04-07-2008, 05:30 PM
Yep!
deeretracks's Avatar
First of be careful useing any starting aid. very bad things can happen... Sounds like glow plugs or the gp controller.
Craig
deeretracks is offline
post #3 of 6 (permalink) Old 04-07-2008, 06:23 PM
matt_28_01's Avatar
i have seen the results of a starting aid and it was not pretty.
02 LB7 2500HD ex/sb, EFILIVE, 4"t/b 6" aussie stacks
K&N intake with PROFAB INTAKE HORN
AIRDOG II 165
autometer NEXUS boost and pyro gauges :rockin
SPORT COMP fuel pres.
STAGE IV PPE w/ PRECISION TC
matt_28_01 is offline
post #4 of 6 (permalink) Old 04-07-2008, 06:25 PM
Yep!
:blowup:blowup:blowup I bet it was like that.
Craig
post #5 of 6 (permalink) Old 04-07-2008, 06:52 PM
Patches4's Avatar
Thant's funny - I don't care who you are!!!
HAD - 94 Chevy Dually 4x4 - 6.5 Turbo
96 Chevy Ext.cab 4x4 - 6.5 Turbo
99 GMC Dually 4x4 - 6.5 Turbo
HAVE - 2005 GMC Sierra crew/6'box - 4X4 - Duramax w/Allison. Fully loaded - AiRaid intake - 4" Pinnicle Performance Exhaust (No Converter - Straight through muffler) - EGR blocker plate - Edge Juice w/attitude - 2" plug in Turbo Resinator -
Patches4 is offline
post #6 of 6 (permalink) Old 04-09-2008, 08:21 PM
Sound like the injectors are bad. High return rate can cause a no start condition. The Duramax waits for about 1500 P.S.I. of fuel pressure before it will even turn on the injectors. So if the injectors are sending to much fuel back the return line the the injection pump may not be able to build enough pressure when cranking the engine. By adding starting fluid to it you make the engine start which also spins the injection pump faster and makes enough pressure for the computer to fire the injectors. They also set fuel related codes especially when towing...p1093 is the most common.
duramaxdr is offline
