| 911 Problems Forum Truck won't start or drive? Post here! |
| Junior Member Join Date: Sep 2010
| LLY won't start without help... I have a 04 3500 4x4 6 spd manual, stock, no mods at all. The problem that I am having is that it will not start without ether (previous owner started it that way, I have read about the horror stories and will not use it) or a pull/push start. The motor cranks over very stong with the key just does not start. It also only cranks for 20 seconds or so and then stops, not sure if that's normal? It has a new filter and fresh o-rings in the filter housing. The primer on top of the housing never gets very firm when pumping it to prime. Any help would be great. |
| Junior Member ![]() Join Date: Sep 2008 Location: Eastern Shore, Maryland
| I'd second the horror stories about ether, It's like using asprin to cure a broken arm; hides the symtoms but does nothing to cure the problem. Have you looked at the primer screw fitting on top of the housing? Plastic, and apparantly often crack or split. Afteermarket metal ones are available (I forget where I saw them, though) or just get a new one from GM.
__________________ 2007 2500 HD Classic LBZ/Allison, standard cab, stone stock, rollup windows, manual door locks, towing and plowing packages with Western plow. |
| I meant "bleeder" above; not "primer".
| Sounds like the injector pump is bad Sounds like the injector pump is bad you need to have someone check fuel rail pressure |
| Duramax Lifetime Supporter Join Date: Sep 2009 Location: Sacramento, CA
| Starter times out to prevent it from melting down.
__________________ (FOR SALE) 2004 Silverado 2500 HD, LB7, Resonator capped, shiny mod's - billet door handles and buckets, Centerline Blackfoot forged wheels, and a drop in K&N filter. New Headgaskets, Injectors, Cups, Turbo and Nicktane Cat Filter mod. ****(AND IT IS FOR SALE)**** |
| Thanks for the replies. I have replaced all the O-rings in the filter housing, including the one on the plastic plug. With a bad injector pump how is it that it will run if push/pull started and off of a shot of ether? I'm somewhat new to diesels so any input would be great. |
| The biggest problem with these engines is--- the did not put a fuel pump in the system. They used the CP3 to pull the fuel from the tank, through the filter and into the CP3 where it is pressurized and sent to the injectors. So any small leak from the tank to the engine, and the fuel will get air and allow the fuel to drain back to the tank, resulting a no start. I have pressurized the fuel tank with the outlet of a shop vac-- be sure it is clean and place a rag over the hose to catch any dust. While pressurized, inspect the entire fuel system, filter, WIF sensor, around the hoses and lines. You can use shop air but keep the pressure below 10 lbs. Hope this helps.
| | eBay Motors #8 (permalink) | |
| Senior Member | Quote:
The CP3 has to put a minimum amount of fuel pressure on the injectors before they'll open (IIRC, something like 5000psi). In a worse case scenario, if the second stage of the CP3 is the problem, it can be diagnosed by low fuel pressure from the CP3. Best case scenario, the Fuel Pressure Regulator is the problem and the CP3 is good - a rail pressure test will reveal it. Regards, Keith
__________________ ----------------------------------------------------------- '04.5 GMC Sierra 2500HD LLY/Allison M74, Summit White, CC/SB SLE 4x4, Leather, Westin Nerf bars, DiabloSport Predator 2.02 (+65 hp), Backup Camera, Homebrew Biodiesel, Power Service, AC Delco stock filter w/TxC CAI, LuberFiner Fuel Filter, BTSI Security Lock, Stiff Throttle Spring, High Idle mod, EGR blocked, Resonator blocked, PCV rerouted, LBZ Mouthpiece, 2" cranked lift, 4" Banks turbo back w/muffler, Garmin C330 GPS, Tekonsha Voyager 9030 brake controller, PowerBright 400/800w inverter, All Headlights mod, OnStar, Spray liner, V-5 Talon, VentShades, James Window Tinting 20%, Engine Driven On-board Air, riding on Michelin LTX M/S 285/75 R16 | |
| Junior Member Join Date: Oct 2008 Location: Kansas City, MO
| Try having someone crank it over as you prime it. If it starts and dies, your getting air in from somewhere.
__________________ 2005 LLY REG. CAB LONG BED 4x4 MBRP 4in. turbo back exhaust 265/75/16 BFG all terrians Weatherguard tool chest |
| DF Sponsors ![]() Join Date: Jan 2008 Location: Texas
| Sounds like a problem on the high pressure side. More than likely an injector returning too much fuel or leaking past the needle keeping the CP3 from building pressure. Ether will get it spinning faster and allow it to build enough pressure to fire.
__________________ 2006 Silverado 2500HD |
