Oil in charge air cooler - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 08-16-2008, 05:29 PM Thread Starter
I'm getting oil into the air duct between the turbo and the charge air cooler on the right side. The oil is seeping through the rubber hose connecting the air duct to the bottom of the air cooler. Is this normal? Help!
ScooterNutz2 is offline
post #2 of 7 (permalink) Old 08-16-2008, 05:34 PM
Yep!
deeretracks's Avatar
It is caused by the PVC valve. If you do the PVC reroute it should solve this prob. PVC REROUTE Write up.Also fill out your sig so we know more about your truck it will help us help you.
Craig
deeretracks is offline
post #3 of 7 (permalink) Old 08-17-2008, 12:29 AM
r.laz's Avatar
X2. Had that problem, 'till I rerouted my PVC into an open system. No more oil in the 'charger and IC lines.
08 Sierra WT CC SB
Steel Gray 4x4
PPE RACE
Modded OEM AirBox/PCV Reroute/4" MBRP into 5" MagnaFlow/ EGR BLOCKED
Isspro EGT/Boost gauges Cognito Leveling Kit/HD Tie Rods Pitman/Idler Support Brackets/Bilsteins
Pirelli Scorpion ATR 265/75/16 Coated OEM Wheels
Factory Oval Steps/Rhino Lining
Klein Air Horns (4)/ViaAir 150 psi 2g compressor
r.laz is offline
post #4 of 7 (permalink) Old 08-17-2008, 12:54 AM
Mclovin1414's Avatar
Does it kinda look like this...?
I was putting in my intercooler and saw this, and couldnt stop thinking about how my bank account couldnt handle a f*cked turbo... But its normal. And the re-route will solve the problem, but leaving it be wont hurt anything either .
2007 Chevy 2500HD CC/SB LBZ
Banks Intake,Banks Intercooler,EFILive,Banks exhaust (No Muff) Diamond Eye Down Pipe
NADP Heavy Hauler!! FASS 150, Sinister EGR Delete, Cognito HD Tie rods, Auto Meter Gauges.
A sh*t Ton of LED K-10 Off-Road Light Bars http://www.k10offroadlighting.ca
Mclovin1414 is offline
post #5 of 7 (permalink) Old 08-17-2008, 07:53 AM
Administrator
jc1843's Avatar
I did mine about 10,000 miles ago and my engine stays so clean-- I just dust it off!
Yes, you could just leave it alone- it won't hurt anything-- but will continue to dump the oil and restricts the flow and you loose horsepower!
jc1843 is online now
post #6 of 7 (permalink) Old 08-17-2008, 10:00 AM
VAGITARIAN :)
daddysLBZ's Avatar
Wink it is normal/worse in the long run
It is normal for it to look like that,but not necessarily healthyI just clean mine real good at the hose connections@ every 5-10k.It will not hurt,but in the long run the engine life will somewhat be shortened.Period...
2006 GMC 4x4 CC/SB/sle1/LBZ**312,000 miles!!** PPE HOT+2 225 TUNE beeeyotch:-)AutoMeter egt/boost Suncoast 5 trans w/1056TC!tsktsk,billet in/out shafts/MagHytec pan!!,M/A built T-Case,4 in.str8piped,5%tint all around......
2007 Chevrolet 4x4 cc\sb,lbz.......SOLD to blunova
Also, I speed and don't come to complete stops at stop signs.
''don't sweat the petty things,pet the sweaty things''
Click below/pictures of my junk!!
http://www.duramaxforum.com/forum/vb...do=hall&u=8415
daddysLBZ is offline
post #7 of 7 (permalink) Old 08-19-2008, 09:09 PM
jaydawg's Avatar
Try switching to rotella oil.....if u don't do the reroute.
jaydawg is offline
