| Premium Membership | |
| | | 911 Urgent Problems Forum In a jam? Post here! |  |
02-16-2007, 08:53 PM
eBay Motors
#1 (permalink)
| | Junior Member
| 05 duramax sputters have a 05 chevy duramax ..have had for 2 years now has ran great just started to sputer and hesitate when i flore it now ..i run the edge and preditor chips.egr block plate fule presure shims cold air intake and turbow back stright pipe........need help has ran fine till now never had any problems thankyou my email mr-eric@comcast.net |
| Advertisement
02-16-2007, 09:53 PM
eBay Motors
#2 (permalink)
| | Senior Member
| when is the last time you changed your fuel filter and do you use your block heater??
__________________ LLY+Allison 05 Black Chevy Silverado 2500HD LTZ85 Crew Cab Short Box
Eaton Lockers, 5" Turbo-Back Stainless Pro Series, lost/stolen cat  (reward if found), SuperChips FLASHpaq "stacked" on an EDGE Juice w/ Attitude, PPE Variable Boost Controller, K&N Intake System, 20" American Racing Chrome Wolverine's, ReadyLift Leveling Kit, Peripheral iPod integration, I hate mods lists!!...blah blah blah... H&H Diesel Performance - Colorado's Diesel Performance Leader |
02-16-2007, 10:04 PM
eBay Motors
#3 (permalink)
| | Junior Member
| just had filter changed no block heater |
02-17-2007, 05:23 AM
eBay Motors
#4 (permalink)
| | Gear Jammer...
| It could be a number of things, most likely is the fuel filter, running the two chips stacked? IF you are those to together run huge amounts of timing, and can do some weired stuff in the cold. Edge boxes have also been know to do things like that when they go bad, matbe try unpluging it and running it. Make sure to unplug it and not just turn it back to stock seting because it still changes a few things even in stock setting!
__________________ 05 Chevy 2500HD dark blue reg cab ZF-6 speed/W South Bend Clutch ,Power by EFI Live W/Dsp2 , PPE GT4094R, ATS CP3x2, Modified Volant intake, MBRP front pipe, 4" side pipe, Holley Blue lift pump, Isspro gauges,Cognito Braces, SD Centerlink, Caltracs, ATS Tie Rod Sleeves Best ET 12.53@ 109 mph 04.5 Chevy 2500HD, silverbirch, D/A, CC/SB , EFI live, SCIV w/ATS 5Star converter,McRat shim mod, Wicked Diesels modded FPR, Kennedy dual lift pump, Modified Volant intake, Cognito Braces,CUD tie rod Sleeves, EGR BLocker,Diamond eye Down pipe, 4" dual exhaust, Elocker, MA Tcase Fix, B&W GN Hitch Best ET 13.53 @ 101mph |
02-17-2007, 08:08 AM
eBay Motors
#5 (permalink)
| | Senior Member
| what edge (model and version) and predator chips do you have installed??
02-26-2007, 04:55 PM
eBay Motors
#6 (permalink)
| | Junior Member
| sputtering i also have an 05 lly....with the edge box and attitude monitor...last friday night i was cruising down the highway and gradually laid into the throttle and it felt like my tranny was spuutering it wasn't the usaul feeling my edge has caused in the past.. went to the dealership saturday and they thought maybe it was the clutch pack in 5th gear...i the edge on 3 wasnt driving it very hard at all....i was wondering if anyone else has had this problem  |
02-28-2007, 11:57 PM
eBay Motors
#7 (permalink)
| | Member
| Do you folks race your trucks or are you using them for daily drivers?
I haven't modified my truck at all and I pass people on hills while pulling a 14,000 lb load behind my truck.
BWAHAHAHA  |
03-01-2007, 01:45 PM
eBay Motors
#8 (permalink)
| | Junior Member
| no racing here.....i guess you could call it a daily driver if you consider 22,000lbs of anyhdrous amonia behind it in the spring in the fall.....it gets used a little to hard at times......not that it should be acting up...i had a little more confidence in the allison....but things lilke that happen i guess
__________________ 2005 GMC cab and a half short bed 4x4, white,edge box with attitude monitor,straight pipe, 15% tint all the way around,265 cooper tires |
| Advertisement
