Old 04-05-2007, 04:24 AM   eBay Motors   #1 (permalink)
messr84
Points: 1,208, Level: 13
Points: 1,208, Level: 13 Points: 1,208, Level: 13 Points: 1,208, Level: 13
Activity: 0%
messr84's Avatar
03 LB7 concern question
On the way home from work a couple mornings ago, the Battery Not Charging light came on. My truck died and i coasted into a vacant lot. I thought my alternator took a dump... i waited a few minutes and tried starting it up...she fired right up and i havent had any problems since...maybe a loose connection or wire somewhere? Well im editing this...sounds like in an earlier posted thread it could lead to the edge, which yes i have....hopefully it doesnt happen again or i think ill call edge!! thanks
03' 2500HD EC SB
Edge Juice w/ Attitude
Dual 5" Silverline Stacks w/ diamond plate cover
K&N Cold Air
Autometer A pillar w Boost and Pyro
BFG 285/75/16 MT's
Recon Smoke Clearance LED lights
Westin Stainless Steel Nerf Bars
Diamond Tread Billet Grille/Rail Caps
http://www.cardomain.com/ride/2590748
messr84 is offline   Reply With Quote
Old 04-05-2007, 12:25 PM   eBay Motors   #2 (permalink)
ob_1jr
Super Moderator
Points: 6,121, Level: 33
Points: 6,121, Level: 33 Points: 6,121, Level: 33 Points: 6,121, Level: 33
Activity: 11%
Activity: 11% Activity: 11% Activity: 11%
ob_1jr's Avatar
Yep, could be the edge, could be a bad battery if you still have the originals. If it is a battery, you will have to change them as a pair.
4" turbo back MBRP exhaust
Kennedy Diesel
Merchant Automotive
My Photos
Old 04-05-2007, 01:39 PM   eBay Motors   #3 (permalink)
aggar
Points: 2,994, Level: 22
Points: 2,994, Level: 22 Points: 2,994, Level: 22 Points: 2,994, Level: 22
Activity: 18%
Activity: 18% Activity: 18% Activity: 18%
aggar's Avatar
yep on the edge there is a small square plug in under the hood. Make sure that is tight. Dad's did that and the dealer ended up putting heat shrink tube on it to keep water out and to keep it tight.
2006 Crew Cab SB 4x4, Stock LBZ, Black with Gray leather, Factory Steps. Black H2's with 295/70/17 Nitto Terra Grapplers, Silverline 4" Turbo Back ss system w/Hushpower muffler. PPE Excelerator Hot + 2(set on 350), Bugshield, and grille insert. SCIV and 1058(Fleece Performance), HP 150 lift pump, Auto meter gauges and pod, EGR Blocker and FRPV shim kit,
Old 04-18-2007, 04:49 PM   eBay Motors   #4 (permalink)
messr84
Activity: 0%
messr84's Avatar
Well after it happening again just yesterday, my dad and i pulled the batteries and alternator and had them tested....they were fine. After hooking everything back up, the truck started and i took it to the local dealer. After they got it in they said it was an Engine Control Module. $900. Thank god it had an 8yr 80k warranty on it so i got luck by 2300 miles. So if anyone has this prob, make sure you get ur truck in before it hits 80k!!
03' 2500HD EC SB
K&N Cold Air
BFG 285/75/16 MT's
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104
