Old 12-25-2008, 01:22 PM   eBay Motors   #1 (permalink)
jake 78
wont start
i have a 2002 gmc 2500hd duramax problem started when i would move tilt up or down the headlights would go off so i took off column trim and found 2 burnt wires that were loose from the connectors when i was trying to take the plug loose from blinker assembly i must have touched 2 contacts i heard a pop come from passenger side dash and dome light went out well tried to start it but only turns over and also door lock on driver door will lock but wont unlock everything else works checked all fuses and all are ok except the 30 amp on stud 1 under hood any advise would be appreciated
jake 78 is offline   Reply With Quote
Old 12-26-2008, 10:03 AM   eBay Motors   #2 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
do you have a security light? You did check the ignition fuses right? this is strange problem....have you tried to make sure the fuel system is primed? I will have to think about this one for a little bit and see if I can come up with anything. BTW...Welcome to the Forum!!!
Old 12-26-2008, 10:27 AM   eBay Motors   #3 (permalink)
lb7dmaxin
Everything in your truck is protected by fuses or relays. You MUST check all of these as most likely one of them will be your problem.
2004 Chevy 2500hd LB7, 78,000, Allison 5 Speed 6" RCD Suspension,
17" Moto Metal 951"s w/35x12.5R17 Toyo m/t, Magnaflow 4"
Turbo back, Cognito Heavy Duty Sway Bar End Links, Gm Power Steering Cooler,
other than that all stock.......FOR NOW!!!!!
What lies behind us and what lies before us, are small
matters, compared to what lies within us!!!
lb7dmaxin is offline   Reply With Quote
Old 12-27-2008, 12:51 PM   eBay Motors   #4 (permalink)
HFD78
how do you check to see if the relay is good or bad
HFD78 is offline   Reply With Quote
