[size="4"]While changing fuel filter this morning Wires to water sensor snapped off. Will there be a problem running with that disconnected for a few days?
__________________ 2003 LB7 4x4
K&N Cold Air Intake
Hypertech Max Energy sta
285/75/16
you can leave it unpluged. it will not throw a falt code.
__________________ Four stroke diesel S.S.B.B. Suck Squeez Bang Blow
My iron is yellow Id rather be dead then CUMMINS RED!
i did the same thing it it was fine till i got tne new part just for fair warning my buddy who is a tech got one for me at his cost and that was almost $50 bucks at my cost it would have been around $80 so dont get sticker shock when they give you a price on one.
__________________ 2008 3500HD Dually SLT
raptor 150 lift pump
mbrp 4" turbo back open pipe no dpf
efi live dsp 5
edge insight to watch everything
egr blocked and pcv reroute
fab four rear bumper
cognito tie rods and braces
Stage IV Tranny kit www.meyerperformance.com Amsoil from BIGDADDYDIESEL
X2, this is the way GM rolls
Alligator Diesel Performance - Chad Hall Owner 1-866-255-7212
You just have to be careful when you are changing it. You can try a wrecking yard. Probobly 5.00 for it.
__________________ 2005 LT 3500HD CCLB SRW LLY EFI LIVE TUNED BY IDAHOROB TCM TUNED BY MMLMM
Lbz intake and mouthpiece
Torsion lift keys
MBRP 4" turbo back
Mcculloch 5300k HIDS
it can throw a low fuel rail pressure code,i had that happen countless times on our one LLY untill i replaced the WIF sensor and the problem disappered..didnt know it could do that.
__________________ James
Priority List
God
Wife
Her Car
Work Car
then the Truck
i have been running with mine unplugged for month and never threw a code. i also have mine JB welded shut though, it was leaking fuel out of it. i want to try and find another larger filter to just put on it
__________________ Pickup: 03 GMC 2500HD EXT Cab Long Box
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders, 255/85R16 BFG KM2 Screamin Diesel Performance
