Old 08-10-2007, 04:32 AM   eBay Motors   #1 (permalink)
BILLHILLY2007
Points: 637, Level: 9
Points: 637, Level: 9 Points: 637, Level: 9 Points: 637, Level: 9
Activity: 0%
2003 Duramax Fuel Filter Base Leak
I took my pickup to the dealer not a minute too soon. It was sucking air around the fuel filter base and as a result I had to crank it a long time to get it to start. After getting it started it ran fine. I would put a new filter on and it would be ok for a few days and slowly would go back to the same problem. This went on for about a month and I tried several brands of filters, all with the same result. The hotter the weather the worse the problem. On the hottest day of the year I was afraid I would get stuck some where, so to the dealer I went. Stopped in the check in line. Left it running. Had the check in guy stand by the filter and listen to it suck air after I shut it off. They couldn't get it restarted. They had it all day and called and said they couldn't figure out what was wrong. Probably the pump. Why would you not address the obvious leak? Thats where I would start. Please,has anyone out there had this problem. Thanks
BILLHILLY2007 is offline   Reply With Quote
Old 08-10-2007, 07:54 AM   eBay Motors   #2 (permalink)
ob_1jr
Super Moderator
Points: 6,093, Level: 33
Points: 6,093, Level: 33 Points: 6,093, Level: 33 Points: 6,093, Level: 33
Activity: 14%
Activity: 14% Activity: 14% Activity: 14%
ob_1jr's Avatar
They didn't address the real problem because they don't know what is going on. What pump are they talking about? (I'm assuming the injection pump since that is the only pump we have for fuel and it actually sucks fuel to itself since we do not have a factory lift pump) Your filter housing could be cracked or your bleeder screw could be leaking air into the system. Also, it could be your Fuel Pressure regulator valve being weak, but Like you said....if the filter housing is leaking, that's where I would start too...it is a lot easier to change than the injector pump and FPRV. BTW, welcome to the forum!
4" turbo back MBRP exhaust
Kennedy Diesel
Merchant Automotive
My Photos
Old 08-10-2007, 07:57 PM   eBay Motors   #3 (permalink)
TXDMAX
Points: 655, Level: 9
Points: 655, Level: 9 Points: 655, Level: 9 Points: 655, Level: 9
Activity: 0%
I had the same problem on my 2003. It ended up being a cracked housing and let me tell you it ain't cheap. Cost me like 600 dollars for a housing.
2003 Chevy c/c, s/b, 4x4, Custom diesel depot tranny, ATS converter, ATS Co-Pilot, Edge jucice w/att, triple dog (crazy larry!) Stacked, 4" Magnaflow stainless straight, Quadzillia monster intake. 275/60r20 goodyears on gear alloy 20x9 injectors.
TXDMAX is offline   Reply With Quote
Old 08-11-2007, 04:16 AM   eBay Motors   #4 (permalink)
97Cobra
Points: 674, Level: 9
Points: 674, Level: 9 Points: 674, Level: 9 Points: 674, Level: 9
Activity: 0%
97Cobra's Avatar
I bet thats whats wrong with mine! It starts fine in the mornings and when the motor is cold but the hotter the motor and the day the harder it is to start. What would be the best method to find out you have a bad housing??
03 SVT Focus
02 2500HD
97 SVT Cobra
81 Scrambler
79 J-10 -> For Sale $500
16' Car trailer -> For Sale $550
(256)658-4956
97Cobra is offline   Reply With Quote
Old 08-11-2007, 11:55 AM   eBay Motors   #5 (permalink)
ob_1jr
Super Moderator
Activity: 14%
ob_1jr's Avatar
That could also be an indicator of injectors going bad too.
Kennedy Diesel
Merchant Automotive
My Photos
