Old 06-21-2009, 01:10 PM   eBay Motors   #1 (permalink)
biggmatt
biggmatt's Avatar
LOw Oil Pressure Light
My brother is driving his 26' travel trailer home right now. he has oil pressure above 60 while on the throttle, but as soon as he lets off the throttle the LOW OIL PRESSURE light starts flashing... Any help or Ideas would be good.
2001 GMC 2500 HD SLT CC SB
edge juice with attitude
6" RCD Lift
2006 Extendable tow mirrors
Amp Boards
"I'll Keep My Money, My Guns, My Liberty, And My Religion,
You Can Keep Your CHANGE."
- Hank Williams JR.
biggmatt is offline   Reply With Quote
Old 06-21-2009, 01:14 PM   eBay Motors   #2 (permalink)
twinturbo3150
Banned
has he pulled over and actually checked his oil level?
twinturbo3150 is offline   Reply With Quote
Old 06-21-2009, 01:17 PM   eBay Motors   #3 (permalink)
biggmatt
biggmatt's Avatar
not yet. I'll Have him do that.
6" RCD Lift
Amp Boards
- Hank Williams JR.
Old 06-21-2009, 01:18 PM   eBay Motors   #4 (permalink)
jc1843
Probably has bad injectors. They may have dumped a load of diesel into the crankcase which dulited the oil.
Chevy 04.5 LLY, 265s, shell, XDR, MikeL 6spd, TransGo, deep pan, blocked, fingered, de-badged, PVC, 65 Gallon Aero tank, PPE, LBZ- mod, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags
Old 06-21-2009, 01:18 PM   eBay Motors   #5 (permalink)
biggmatt
biggmatt's Avatar
He says he checked it cold this AM and it was full.
6" RCD Lift
Amp Boards
- Hank Williams JR.
Old 06-21-2009, 01:22 PM   eBay Motors   #6 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
does it smell of diesel? could have a bad cluster, but could have bad injectors too. what year truck?
Old 06-21-2009, 01:23 PM   eBay Motors   #7 (permalink)
biggmatt
biggmatt's Avatar
what other symptoms would he see, fuel on dipstick? running weak?
6" RCD Lift
Amp Boards
- Hank Williams JR.
Old 06-21-2009, 01:24 PM   eBay Motors   #8 (permalink)
biggmatt
biggmatt's Avatar
He has a 2003 LB7
6" RCD Lift
Amp Boards
- Hank Williams JR.
Old 06-21-2009, 01:27 PM   eBay Motors   #9 (permalink)
biggmatt
biggmatt's Avatar
if he has a bad injector or something, what then?
6" RCD Lift
Amp Boards
- Hank Williams JR.
Old 06-21-2009, 01:31 PM   eBay Motors   #10 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
Normally all 4 on that side need to be replaced...or are replaced. If it is injectors and they fail for what special policy 0439 states he is covered under a 7yr/200,000 mile warranty with NO deductable (check my garage i have an older copy of it there). You wont see the fuel on the dipstick, just see the halo on the paper towel. And if it smells of diesel, its time to have it looked at.
