Old 10-02-2009, 08:19 PM   eBay Motors  #1 (permalink)
Where to buy fuel inj harness parts?
My 05 LLY has a code P0452 (Evapoative Emission System Pressure Sensor/Switch Low Input), to my knowledge I need the fuel inj wiring harness upgrade from GM part #98017958. Went to the GM dealer and he quoted me $400 + for two small clips and a splice kit.
Could anyone offer suggestions on finding this part cheaper, seems like alot of money for two small connectors.
Thanks,
Brian
bjohnson is offline   Reply With Quote
Old 10-03-2009, 07:09 AM   eBay Motors  #2 (permalink)
DF Trustee,
jc1843's Avatar
I think the code is wrong-- diesels do not have a evaporative system such as the gas vehicles.
You may have a problem such as these--
That problem is usually caused by a loose connector at the injector. The cheap fix that will last, is to remove the connector, place it against something flat, and push a SHARP ice pick into both terminals. This will raise a dimple inside the connector for a better contact. Do this for #2 and #7 injectors. (The cylinders are numbered from the front--- passenger side- 1-3-5-7 and the drivers side is 2-4-6-8)
Also inspect the FICM harness at the alternator for shorts and wear-through. The harness gets cut and shorts by contact with the sharp corner of the bracket.
These are common problems for the LLY engine. Everyone that has a LLY should know how to do this and have a sharp ice pick in the glove box!
Chevy 04.5 LLY, 265s, shell, XDR, MikeL 6spd, TransGo, deep pan, blocked, fingered, de-badged, PVC, 65 Gallon Aero tank, PPE, LBZ- mod, shimmed, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags. Jerry
Old 10-03-2009, 10:51 AM   eBay Motors  #3 (permalink)
Thanks, I have been doing the ice pick fix and the problem has become repetative, I am no thinking that the connectors require replacement. I have managed to fine the connector kit for $150 thru gmpartsdirect.com so this might be my best option.
Thanks,
Brian
Old 10-10-2009, 05:48 PM   eBay Motors  #4 (permalink)
duramax driver's Avatar
just had that problem on my 05 gmc and the dealer would not fix it on warranty. so I had merchant automotive in Zeeland Michigan replace those parts for $300 including labor.
GMC 05 LLY,SLE Ext cab, Short Box, Motor + Trans Performance, 4 inch Exhaust Turbo Back with 5 inch tip, no Kitty, Edge Juice with Attitude programmer, Fass 150 Lift Pump Fuel System with Filters, S+B Cold Air Intake + Filter, LBZ Turbo Mouth Piece, AFE Inter-Cooler Tube upgrade = 75 CFM flow increase, Blocked EGR, BD Manifold, Amsoil 5w40, Fumoto Oil Drain Valve, TransGo Shift Kit with Deep Pan, Amsoil Torque-Drive Synthetic Transmission Fluid, Drive Chassis, Bilstein Shocks, Cognito Steering Support Kit, Super Diesel Tie Rod Sleeves, Russell Braided Stainless Steel Brake Lines, Air Lift Air Bags and Pump, B&W Turnover Ball Goose-Neck hitch, Bridgestone Revo Tires LT265 75 R16, Amsoil Severe Gear 75w-120 in Differentials,
duramax driver is offline   Reply With Quote
