Old 10-03-2009, 06:28 PM   eBay Motors   #1 (permalink)
J.P.
gas in diesel
I put gas in my 2003 duramax at a rate of 24 gal. gas to 6-7 gal. diesel, then drove it for 20 or so miles until it started pinging. After about 10 seconds of pinging I shut it off, pulled over and had it towed home. What next ? Any Help is greatly appreciated. Thanks, J.P.
J.P. is offline   Reply With Quote
Old 10-03-2009, 06:35 PM   eBay Motors   #2 (permalink)
delong_1
truck for sale
delong_1's Avatar
best bet would be to drain the tank, fuel filter etc and fill them with some diesel and put a concentrated amt. of a fuel supplement.
Nate
2 turbos, built trans, and some tuning.
Old 10-03-2009, 06:57 PM   eBay Motors   #3 (permalink)
jc1843
It is good that you shut it off and did not run it anymore--
I would do as stated above and add about a cup of 2 cycle oil to the new fuel filter before you prime it, and a couple quarts to the in tank diesel after you drain the tank-- the oil will help lube everything. It may smoke a little, but that may save your injectors and engine.
Keep your fingers crossed-- and maybe there will not be any damage.
This is not the first time someone has done this-- and more will do it in the future.
Chevy 04.5 LLY, 265s, shell, XDR, MikeL 6spd, TransGo, deep pan, blocked, fingered, de-badged, PVC, 65 Gallon Aero tank, PPE, LBZ- mod, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags
Old 11-02-2009, 04:08 PM   eBay Motors   #4 (permalink)
rmcable
rmcable's Avatar
Yeah they will, hope not me though.
Funny how they designed the fuel nozzle's so Diesel won't fit in a gasser but the Gas sure will fit in the Diesel....
2009 Chevy Duramax, LMM, 6 Speed Allison,
Black, 4 dr, 4wd
Mods:
Edge Evolution Tuner,
Level 3
T-Bars Cranked,
Modded Airbox...... So far.
YEAH I already know, DELETE the DPF.
Gun's don't kill people; Daddies with little girl's KILL people!
rmcable is offline   Reply With Quote
Old 11-02-2009, 04:44 PM   eBay Motors   #5 (permalink)
BUBBA3M
BUBBA3M's Avatar
Welcome to the DF!! Follow the previous suggestiond and keep your fingers crossed. Hope it will be OK.
2006 2500HD, 4WD, LT, 6.6 Turbo, LBZ, Allison 6 spd, XC/SB, Silver Birch Metallic,
Bone stock with the exception of being 5" Straight piped.
My other Chevy is an 05 Impala, 3.4 V-6, 4spd auto, 36mpg hiway @ 65mph
George
BUBBA3M is offline   Reply With Quote
Old 11-02-2009, 08:06 PM   eBay Motors   #6 (permalink)
Toypuller
I always remove the fuel lines at the fuel filter and install a fuel pump to suck all the fuel out of the tank. When you go to restart it will knock and sound HORRIBLE for about 5 seconds and then run ok.
Oh also after you suck all the fuel out of the tank make sure you refill your tank with at least 15 gallons of diesel, This way any left over gas in the tank that you could not get out it will deluit it enough to run ok.
2005 LT 3500HD CCLB SRW LLY
EFI LIVE TUNED BY IDAHOROB
TCM TUNED BY MMLMM
Lbz intake and mouthpiece
Torsion lift keys
MBRP 4" turbo back
Mcculloch 5300k HIDS
