I am not even sure if my truck is safe to drive as I am having to change the oil at <60 miles before it is full of diesel..... I guess my question now is, how bad do the injectors have to be to be warrantied???? The following post is mine from the FPR area. If it can go from no problems to what I have now in less than 10 days, will they completely trash out?
Having read all the postings, I feel I can change out the FPR myself, thanks for all who have given advice. Dealer quoted $350.00 to change (part and all), but since I am getting a crankcase full of fuel very fast.... Dealer said 2 injectors shot, 4 marginal, and two still good, would not qualify for the warranty replacement.... Went from no problems with truck to really trashing out in a week. Said FPR bad and could not finish test for warranty, so will replace myself and take it back to them. They said they had very few fall within the warranty guidelines and $3500.00 to replace injectors if it is out of warranty. Aside from the very high fuel and every 80 miles having to replace the oil as it is only fuel by then, would running it a while longer get the rest of the injectors to fail as they said they always failed all at once. Only 78k on a 02, and never a problem in the past, just the last 10days. Thanks....
keep callin the dealer drive em nuts take it to another one if not it doesnt even have 100k tell them to fix it but dont drive it youll wash your main bearings out and then the whole motors ruined and they dont cover neglect.
__________________ Black 05' Silverado 2500 HD CC/SB, LLY . LT 3 pkg. 4x4.
Interior-Sunroof,Huskey liners,Galaxy 77 CB,Boomer cb amp,Uniden scanner,Motorola bluetooth,Wilson cell phone amp.
Exterior-Stainless trim,Rhino liner,Steel front bumper,Stainless chevy emblem,5% tint,17x10 Utramotorsports wheels,35x12.50 Cooper STT's.
Engine-ARP Headstuds,Shaved heads,new valves,valve seals,new injector,LBZ mouthpeice,Res.plugged,PCV reroute,airbox mod.,Diamond Eye downpipe, 4inch striaght pipe downpipe back.
Transmission-over-cooked and highly baked
Suspension-Rough country leveling kit cranked,Cognito ptiman/Idler braces,Cognito HD tie rods, added 3 rear springs, Rancho 5000 shocks.
old faithful- 91' F-150 XLT Lariat,302
Thanks for the answer, will take a long time to build up that much $$$$, unfortunately 100% disabled and this is my only transportation. Life can deal you some bad ones sometimes, will just have more time to make lemonade... lol Am going to replace the FPR anyway and hope the others go bad quickly.... They did say the fuel return rates were high, but with two good injectors still, won't qualify.
Yeah if its still under 7yrs and 200k, I would on the phone with GM relentlessly explain to them your situation, even if you have to call Corp headquarters, someone has to be able to help you. Keep us informed.
2001 Chevy 2500HD D/A 4" MBRP turbo back exhaust, PPE Boost Valve, Banks Big Head wastegate,Modded air intake horn, SCIV 1056, Kennedy Billet pickup, Kennedy dual lift pumps, Snow stage 2 water/meth kit, SPA combo gauge, Air lift bags
Crank it up Tierod sleeves
Cognito Steering Braces
07 Chevy taillights
305/65/17 M/T ATZ's on Chrome H2's
EFI Live Tuned
12.72 @ 104.7 10/25/09
Stop driving it, you will smoke some bearings very quickly. Unfortunate situation but 1200 bucks for injectors versus 6-8 grand for a new motor I think you can see the cheaper alternative.
Again thanks for all the replies‼ Unfortunately, it is $3500.00 for the injectors, and by the prices I have been seeing here on the forums, they may have quoted me only the cost of the parts since most are saying $5k for the complete job. Maybe a bad choice, but am going to buy a case of cheep oil and see if I can't get another week or two out of it, then take it back. Maybe ALL the injectors will be bad by then, not just most of them..... Just really feel it should not happen to a truck that has only 78k and has been serviced regularly and never worked a day in it's life....
it took me 4 stealerships to get mine fixed...one told me i had 5 injectors bad, one said nothing was wrong with the injectors and my AFE filter needed replaced and that was causing my problems and the 3rd dealership said you have bad injectors. Finally I talked to a buddy that know someone at a dealership and 2 days later i had 8 new injectors no questions asked. they shitty thing is they didn't replace the fuel filter or change the oil. So all i can really say don't give up and try a different dealership
__________________ Bryan 03 GMC 2500HD LB7 4x4 CCSB 285/75/16 Hankook DynaPro on PYO 4" MBRP Cool Duals High Idle Switch Superchip Flashpaq Recon Line of Fire and Ice Recon Smoked LED 3rd Brake light Brite Box headlight mod High/Low and Fog Light
Toys-99 Civic Si-Turbo 490hp 11.820 @116 mph 1.797 60', 1995 Buell S2, 1988.5 Suzuki Samurai(wheeling rig someday) www.myspace.com/firejunky99
^^^ Yea that sounds like your best bet.
__________________ Pickup: 2002 Chevrolet 2500HD Duramax/Allison Reg. Cab with
Royal Utility bed and racks
Intake: Stock with KN Filter
Transmission: Stock
Mileage: 151,000 No Rust
