| You probably have a bad master cylinder-- when the master cylinder piston gets sticky with "crud" it will not return to the proper place which blocks off the fluid return port in the cylinder bore. When heat builds up in the brake system, the fluid expands and has no where to go, so this starts building pressure and applys the caliper pistons.
Opening a brake line will usually release the pressure, and it will be OK until it builds pressure again.
Hope this helps.
__________________ Chevy 04.5 LLY, 265s, shell, XDR, MikeL 6spd, TransGo, deep pan, blocked, fingered, de-badged, PVC, 65 Gallon Aero tank, PPE, LBZ- mod, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags |
