Old 10-30-2009, 01:09 PM   eBay Motors   #1 (permalink)
jon5212
Need suggestions
Hey guys... yesterday my truck seemed to be running a little odd. Pulled the fuel filter off to put a new one on, it was pretty much full of gasoline. Seems either Pilot had someone put gasoline in their diesel tank at the fuel station, or someone dumped gas in my tank at my house. In either case it couldn't have been a whole lot because there is diesel in my tank still, i've added a half a quart of 2 stroke oil as well as diesel treatment. I've got half a tank left. Right now it runs fine... I don't have any check engine lights... however it is idling high for some reason, just under 1000 RPM instead of around 600. Any thoughts? My DSP5 seems to still be working switching between tunes.
2001 Chevy 2500 4x4 ECSB, 6 speed with Southbend Clutch, 4" MBRP exhaust. EFI Live tuned thanks Brayden and Jarrod!!! Dyno numbers 6-6-09 Fass Diesel Nationals 441 RWHP/900+ RWTQ Yeah baby!
jon5212 is offline   Reply With Quote
Old 10-30-2009, 01:53 PM   eBay Motors   #2 (permalink)
jc1843
It probably has high idle because the gas-- I suggest you add another quart of 2 cycle-- gas can really damage the system because it lacks lubrication.
The gas should have mixed with the diesel and just have a gas smell to it. No way to tell how much gas in in the system.
You should consider draining the tank and adding clean diesel.
Chevy 04.5 LLY, 265s, shell, XDR, MikeL 6spd, TransGo, deep pan, blocked, fingered, de-badged, PVC, 65 Gallon Aero tank, PPE, LBZ- mod, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags
Old 10-30-2009, 03:20 PM   eBay Motors   #3 (permalink)
jon5212
Yeah im going to stop and fill up with diesel on my way home... its got almost a quart of 2 stroke oil in it now wtih just half a tank... i also poured a whole bottle of the white bottle diesel treatment... can't remember the name of it.
Old 10-30-2009, 03:54 PM   eBay Motors   #4 (permalink)
jlb444
jlb444's Avatar
Get a jug of Howes diesel treatment. It will add lubrication. You'll only need to dump about 1/4-1/3 of it in.
2005 Duramax LLY
90 h.p. Bully Dog, K&N CAI
No muffler, no cat. dual 5" turn-outs behind cab
Crew Cab: Dark Blue, 7 cab lights, tinted windows, nerf bars
Chrome vent shades and bug shield;17x9 Moto Metal 951's with 285/70/17 Hancooks
B & W hitch, Rhino lining and rocker panel stainless steel.
jlb444 is offline   Reply With Quote
Old 10-30-2009, 04:14 PM   eBay Motors   #5 (permalink)
bowhunternkbay
bowhunternkbay's Avatar
You also might consider a locking fuel cap.Since you are not sure if the "problem gas" came from the station or if someone tried to be "funny". First thing I did after purchasing my truck was buy a locking gas cap. I wasn't worried about someone stealing the diesel, but from putting contaminants in the tank.
'06 2500 HD CC/SB
BullyDog TripleDog
AiRaid CAI
MBRP 4" Turboback
Goodyear Silent Armor LT 285/75R16
Blocked,Fingered,Rerouted,Sleeved and Plugged
www.DiscountTireDirect.com
bowhunternkbay is offline   Reply With Quote
Old 10-30-2009, 04:57 PM   eBay Motors   #6 (permalink)
jc1843
X2 me to! To easy to dump something in the tank and cause BIG $$$$. Also I have the only key in a special place-- and only "I" put the fuel in! I almost put gas in once-- the damn cover on the nozzle had a green boot.
Old 10-31-2009, 09:25 AM   eBay Motors   #7 (permalink)
jon5212
Yeah well I filled up put about 12-13 gallons of good diesel in it... it's still got the same symptoms after about 30 miles. It has a louder "diesel" sound, it's idling high. No check engine lights and it seems to have "most" of its power. I had a couple thoughts, I lost an injector... but I'm not "making any oil, and the oil doesn't smell like diesel. I thought maybe I popped a head gasket, the cooling system is not "pressurizing" beyond normal pressure. With the truck hot I can still squeeze the radiator hose semi-easily, its not rock hard at all. I think i'll just stop by a chevy dealer and get someone to hook it up to a Tech 2 and have the monitor everything and see if that can point me somewhere.
Old 10-31-2009, 09:32 AM   eBay Motors   #8 (permalink)
bowhunternkbay
You can also go by autoZone or other Parts store and let them scan it...sounds like you just got to get rid of the "bad stuff" in your tank.
'06 2500 HD CC/SB
BullyDog TripleDog
AiRaid CAI
MBRP 4" Turboback
Old 10-31-2009, 10:16 AM   eBay Motors   #9 (permalink)
jon5212
Most likely, but autozone all they can do is read codes, they can't monitor everything live like a Tech 2 will. I'll keep driving it over the weekend and see if it improves at all.
Old 10-31-2009, 12:16 PM   eBay Motors   #10 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
Once you're good for Diesel only in the tank, I'd change the filter again and add a Diesel treatment to the fuel.
