Old 11-02-2009, 05:12 AM   eBay Motors   #1 (permalink)
shaddfamily
Brake lights do not work
I have no brake lights. Blinkers work, hazards work. Brake light on top of cab works, but tail brakes do not. I have tried replacing fuses but nothing working. Any suggestions?
shaddfamily is offline   Reply With Quote
Old 11-02-2009, 05:50 AM   eBay Motors   #2 (permalink)
maxthis
maxthis's Avatar
Bad relay possibly?
04.5 LLY 68,000 miles and not a problem one!
-6" superlift
-35x12.50 Toyo MT's on 18" Ultra Predators
-PPE standard, shim kit, egr and resonator blocked
-4" banks turbo back and 5" MBRP miter cut stack
-AFE mouthpiece, K&N Stainless intake
-full Transgo shift kit
-weld in gooseneck plate
-Cowl hood, spray in bed liner
-Suncoast, DSP5, lift pump an possibly a turbo after harvest!
maxthis is offline   Reply With Quote
Old 11-02-2009, 06:31 AM   eBay Motors   #3 (permalink)
tpb1976
try checking the main plug under the bed,mine was doing the same thing a while back and it was a little corroded
2001 2500hd lb7 a/t. ex cab sb.leather,straight pipe,westin steps,intake horn mod,billet grille emblem,mldgs removed,partially debadged,Quadzilla stealth 2 perfomancetruckproducts.com
tpb1976 is offline   Reply With Quote
