Old 11-02-2009, 07:43 AM   eBay Motors   #1 (permalink)
pwrtripls1
Unhappy Just blew trans!!!!!
On my way into work I was going to pass a car and half way around the car the trans made a "thud" sound and the RPM's jumped. I didnt even give it enough to downshift and was only going about 57-58mph. The Edge was on 4. I've taken the truck to the track a few times and played some on the highway but was always pretty easy on it and I never once limped it. So now it appears the trans only has 4th gear forward, the convertor isnt locking up, and no reverse. So what the heck happened? Why did it let go, I'm not making much power?
Also, I need to get it back on the road as fast AND as cheap as possible, what do I do? Please let me know, I am really lost and in a bad spot right now.
2005 QCLB LLY - Edge J/A, Yukon Turbo MP, Crank Vent, AirAid, Blocked&Fingered, 5" Strait Pipe Turbo Back,275/70/18's on Predators. 176,000 and counting.
1992 Dodge D250 - Getrag, SBDD 3250 Clutch, SPS-62, Custom DDP Injectors, 4200rpm Gov, 5" Exhaust, Single Stack, 52psi, 438,000+ miles and FAST.....
pwrtripls1 is offline   Reply With Quote
Old 11-02-2009, 07:44 AM   eBay Motors   #2 (permalink)
pwrtripls1
This was on the 05'. The 07 is gone now, I need to delete it.
Old 11-02-2009, 07:46 AM   eBay Motors   #3 (permalink)
RedBowTies88
RedBowTies88's Avatar
it just limped....shut down clear codes and it should be back to normal...
you gonne have to either turn down the power or stay out of it in 5th gear till you build it or it will happen more and more
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
Old 11-02-2009, 08:02 AM   eBay Motors   #4 (permalink)
pwrtripls1
Trany limp mode just locks the trans in 4th gear and no reverse? It has no problem going over 2k rpms. I drove the last 3 miles into work at 55mph and 2400rpm.
Old 11-02-2009, 08:05 AM   eBay Motors   #5 (permalink)
maxthis
maxthis's Avatar
clear the codes!..you should have sold the Edge and kept the Bully Dog!!
04.5 LLY 68,000 miles and not a problem one!
-6" superlift
-35x12.50 Toyo MT's on 18" Ultra Predators
-PPE standard, shim kit, egr and resonator blocked
-4" banks turbo back and 5" MBRP miter cut stack
-AFE mouthpiece, K&N Stainless intake
-full Transgo shift kit
-weld in gooseneck plate
-Cowl hood, spray in bed liner
-Suncoast, DSP5, lift pump an possibly a turbo after harvest!
maxthis is offline   Reply With Quote
Old 11-02-2009, 08:08 AM   eBay Motors   #6 (permalink)
RedBowTies88
yep thats limp mode shut down wait a while and restart it will be ok....ten minutes tops of shutdown is what it should take
bully dog is the only chip worse then edge juice
LLY Cc/sb 4x4 RED
Old 11-02-2009, 08:11 AM   eBay Motors   #7 (permalink)
wilkie
what is wrong with Bully Dog?
2005 GMC LLY
Bully Dog Triple Dog with Outlook
AFE Stage 2
AFE 4 inch Cat back exhaust
wilkie is offline   Reply With Quote
Old 11-02-2009, 08:15 AM   eBay Motors   #8 (permalink)
RedBowTies88
their tunes are poorly constructed
LLY Cc/sb 4x4 RED
Old 11-02-2009, 08:22 AM   eBay Motors   #9 (permalink)
pwrtripls1
I really hope y'all are right that its limp mode and not a broken trany. It clunks pretty good going from N to D, is that normal for limped trany?
Old 11-02-2009, 08:25 AM   eBay Motors   #10 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
Yep...it makes a lot of noise until it resets.
