Old 11-04-2009, 09:07 PM   eBay Motors   #11 (permalink)
duramaxbd03
Wants more go "FUN" parts
duramaxbd03's Avatar
kit? get it from the the dealer?
2003 Silverado 2500HD 4x4,Ext, LB7, Silver
6inch Black Single,
18inch Rockstars with 285 Nitto Terra Grapplers
Ported MouthPiece,PPE Lift Pump
Autometer Cobalts, K&N Intake, Cognito HD Tie-Rods
EFI Live with DSP 2 Switch Tuned by MMLMM
SunCoast Stage III
- Jake
duramaxbd03 is offline   Reply With Quote
Old 11-04-2009, 09:10 PM   eBay Motors   #12 (permalink)
RedBowTies88
RedBowTies88's Avatar
jake ice pick trick it first..worked great for me...this happens on lly's all the time...
and worse comes to worse you need the updated harness and thats only 150 bucks and some light wiring
call/text me 609-408-7490 i can walk ya through it
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
Old 11-04-2009, 09:25 PM   eBay Motors   #13 (permalink)
duramaxbd03
ice pick trick???
im confused on what that is
6inch Black Single,
SunCoast Stage III
- Jake
Old 11-05-2009, 06:22 AM   eBay Motors   #14 (permalink)
RedBowTies88
Originally Posted by duramaxbd03 View Post
ice pick trick???
basically what you gotta do is take off the injector harness then use and ice pick or an all or something hard skinny and sharp (use your imagination) and shove it through the harness to crimp the contacts inside to make better contact with the injector
its not hard at all i can walk you through it on the phone...there are thread on it on DD and diesel place too but i cant find them right now for some reason
LLY Cc/sb 4x4 RED
Old 11-07-2009, 11:22 PM   eBay Motors   #15 (permalink)
bjohnson
Very easy fix, took me an hour. Kit cost me $382 CA, they were going to charge me 4 hours labor but I did it myself. Send me an e-mail brianang@telusplanet.net and I will attach the picture of the repair kit, I wasn't able to attach to this forum for some reason??
Brian
bjohnson is offline   Reply With Quote
Old 11-08-2009, 12:01 AM   eBay Motors   #16 (permalink)
chevymakesitizuzushakesit
chevymakesitizuzushakesit's Avatar
please pm me me this info icase this ever happens to my lly
05' CCSB 4x4 DMAX/Allison
mbrp, ppe, airdog, nitto, efi live, autometer, bilstein
chevymakesitizuzushakesit is offline   Reply With Quote
Old 11-08-2009, 12:03 AM   eBay Motors   #17 (permalink)
duramaxbd03
ok so we fixed the injector... bought a new wiring harness everything was running great....
now the truck is smoking white everyonce and a while and dripping fuel? the wierd thing is doesnt do it all the time
and a time it will have powerloss but no check engine light
6inch Black Single,
SunCoast Stage III
- Jake
Old 11-08-2009, 12:33 AM   eBay Motors   #18 (permalink)
Oldvintageiron
Oldvintageiron's Avatar
After my truck had the harness go bad and the dealer fixed it it did not run right. I was on my way to cali and I could not loss any more time. After it ran a while everything is fine. Not sure but I think the ECM had to relearn.
I had a power loss to under 2000 rpm then it would take off. No smoke thought. How long did you drive it in limp mode?
2004.5 lly GMC CCSB 2500
AFE Stage 2, modded MP(soon AFE MP), Afe Boost tube
BD manifold, EGR block plate, Banks turbo back(no cat)
EFI Live by IDAHOROB w/ DSP5
Aeroforce Interceptor gauges
19.5 Rickson wheels W/ 225/70/19.5 drive/ steer
BD Flowmax Lift pump, auxiliary fuel filter PPE fprv shim
Bullydog shift enhancer/ Amsoil Race Trans Fluid
Amsoil Bypass Filtration 5w30 3000 HD Diesel oil
Cognito Motorsports Pitman/ Idler support kit
Oldvintageiron is offline   Reply With Quote
Old 11-08-2009, 05:32 AM   eBay Motors   #19 (permalink)
blackdeath
blackdeath's Avatar
i think u need an injector. a faulty injector will not alwys give a light on
2008 silverado dmax LTZ, aFe stage 2,race tune from idahorob,EFI LIVE, AD 150 lift , ppe shim kit,dpf delete,EGR block off plate,autometer gauges (cobalt) boost and pyro,transgo jr,6"fabtech with maxxcams and 2"addleaf,fabtech tierods,37"procomp 20" boyd wheels. 5% tint all around,5"grandrock stack kit,straight piped, custom painted dash panel,SCIV coming maybe
2008 trailblazer ss, straight pipe ,jetttstream air intake,iat relocate kit,efi tuned , 3" lowered
blackdeath is offline   Reply With Quote
Old 11-08-2009, 08:46 AM   eBay Motors   #20 (permalink)
duramaxbd03
we just changed the injector...
and its leaking fuel somewhere
6inch Black Single,
SunCoast Stage III
- Jake
