Old 11-02-2009, 04:30 PM   eBay Motors   #1 (permalink)
duramaxbd03
Wants more go "FUN" parts
duramaxbd03's Avatar
Exclamation lly injector
so today are lly got powerloss and it started knocking real bad
went to autozone they checked it and 3 codes came up all dealing with injector # 7
but then we brought it home and turned it off and turned it back on it acted like nothing happen but the check engine light was still on
so any input?
and if it is the injector does anyone have directions on install
and correct if im wrong you dont have to take off the valve cover like lb7?
2003 Silverado 2500HD 4x4,Ext, LB7, Silver
6inch Black Single,
18inch Rockstars with 285 Nitto Terra Grapplers
Ported MouthPiece,PPE Lift Pump
Autometer Cobalts, K&N Intake, Cognito HD Tie-Rods
EFI Live with DSP 2 Switch Tuned by MMLMM
SunCoast Stage III
- Jake
duramaxbd03 is offline   Reply With Quote
Old 11-02-2009, 04:39 PM   eBay Motors   #2 (permalink)
diesnuts
diesnuts's Avatar
its probably the connector, they were bad from the factory, it will probably happen again, so fix asap, if you can find it pull apart and crimp down the female end with a small pointed tool, there may be a write up somewhere on how to do this
05 LLY 2500HD Crew Cab 4x4
Gear Alloys on BFG 315s
Billstein shocks
EFI LIVE tuned by GEORGIA DIESEL
DSP5 Switch
4" Magnaflow Turbo back exhaust
pyro/boost guages
LBZ MP/airbox mod
pcv reroute/egr blocker
diesnuts is offline   Reply With Quote
Old 11-02-2009, 04:39 PM   eBay Motors   #3 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
no you dont have to take off the valve cover. Have you checked your injector harness?
Old 11-02-2009, 04:44 PM   eBay Motors   #4 (permalink)
custom8726
custom8726's Avatar
Like everyone else advised check the harness first, search ice pick for a wright up on how to correct this. If it ends up being an injector I believe number 7 is the drivers side closest to the firewall, its a pretty easy one to change and no you do not have to remove the valve cover....
[b]05-LLY-crewcab-SB- 285-65-18's on MKW wheel's, PPE HOT+2 ET -AFE STAGE 2-MBRP DUALS-EGR BLOCK PLATE-AUTOMETER PYRO+BOOST GAUGES- B&W turn over, Diamond + JL AUDIO, Remote starter,Turbo timer, Tranny upgrade, PRECISION T.C., AIRDOG 150 L.P., PPE SHIM KIT & PORTED FUEL RAIL, LBZ mouth piece, COGNITO H.D. TIE RODS & BRACES.
EFI LIVE, DSP-5...... ATP TUNING, 40 over BD Injectors 4" T.C. lift, 35" Nitto graplers, Rancho 9000's
custom8726 is offline   Reply With Quote
Old 11-02-2009, 06:39 PM   eBay Motors   #5 (permalink)
duramaxbd03
ok thanks guys!!!
idk when were goin to work on it but wheres the harness run at?
6inch Black Single,
SunCoast Stage III
- Jake
Old 11-02-2009, 07:24 PM   eBay Motors   #6 (permalink)
duramaxbd03
bump!!!!!!!!!!!!!!
6inch Black Single,
SunCoast Stage III
- Jake
Old 11-02-2009, 07:32 PM   eBay Motors   #7 (permalink)
blackdeath
blackdeath's Avatar
check it where it plugs to the injector ,, i just fixed a lly and funny enought 2 and 7 had bad injectors , not connectors
2008 silverado dmax LTZ, aFe stage 2,race tune from idahorob,EFI LIVE, AD 150 lift , ppe shim kit,dpf delete,EGR block off plate,autometer gauges (cobalt) boost and pyro,transgo jr,6"fabtech with maxxcams and 2"addleaf,fabtech tierods,37"procomp 20" boyd wheels. 5% tint all around,5"grandrock stack kit,straight piped, custom painted dash panel,SCIV on its way
2008 trailblazer ss, straight pipe ,jetttstream air intake,iat relocate kit,efi tuned , 3" lowered
blackdeath is offline   Reply With Quote
Old 11-02-2009, 07:40 PM   eBay Motors   #8 (permalink)
duramaxbd03
ok thanks
6inch Black Single,
SunCoast Stage III
- Jake
Old 11-04-2009, 05:29 PM   eBay Motors   #9 (permalink)
duramaxbd03
does anyone no how hard it is to install an injector wiring harness? and could tell how hard it is and if i need to take it to the dealer
but we changed the injector... it was fried on the end
but the truck still isnt running right
we got 2 codes from it now
one is a voltage to the injector and the other is the code that it shuts down the 4 cylinders on the side of the bad injector
6inch Black Single,
SunCoast Stage III
- Jake
Old 11-04-2009, 08:54 PM   eBay Motors   #10 (permalink)
blackdeath
blackdeath's Avatar
get the kit and ull see , its real simple ,
