Old 11-03-2009, 07:19 AM   eBay Motors   #1 (permalink)
gunmetalsi
gunmetalsi's Avatar
Blew most of coolant out of reservoir
So over the week I had to move my brother from Durango to Denver. I was going over wolf creek pass (11,900 feet) my egt's were only 1150 when I smelt coolant and at the same time low coolant flashed in the DIC. I pull over and look under the hood to find the coolant reservoir almost completely empty and coolant all over the under side of the drivers side of the truck. Checked dipstick to see if I blew a head gasket and NO there was no coolant on the dipstick. Temp. gauge never got over 210, trans temp never got hot. After going over wolf creek pass there was only one more pass to go over but it was only 9500' and everything seemed fine after the first incident. Made it all the way back home let it sit for a 4 or 5 hours check hoses and they are not hard. Yesterday I put 18-20 psi through the cooling system to see if I could find a leak and nothing is visible. ---long winded sorry.
Anyone have any ideas what to look for. Also have not had any puddles or drops on the driveway. I took off my covers on the bottom to notice if I had any leaks.
Thanks Bryan
Bryan
03 GMC 2500HD LB7 4x4 CCSB 285/75/16 Hankook DynaPro on PYO 4" MBRP Cool Duals High Idle Switch Superchip Flashpaq Recon Line of Fire and Ice Recon Smoked LED 3rd Brake light Brite Box headlight mod High/Low and Fog Light
Toys-99 Civic Si-Turbo 490hp 11.820 @116 mph 1.797 60', 1995 Buell S2, 1988.5 Suzuki Samurai(wheeling rig someday)
www.myspace.com/firejunky99
gunmetalsi is offline   Reply With Quote
Old 11-03-2009, 07:29 AM   eBay Motors   #2 (permalink)
BoiseRob
BoiseRob's Avatar
Blown head gasket...
FYI, you would have oil coming out the dip stick tube if you "holed" a piston...
2007 2500HD "Classic" 4x4, LBZ/Allison, CC/SB, Nerf Bars, Billet Grille & Emblem, Tinted Windows, Incubus Rims, 265/75R16 BFG A/T, AFE Filter, Bilstein Shocks, TransGo Jr. & Mike L. cooler installed by Mike L., MBRP T-409 4" Cat-Back, PPE Blocker Plate & EFILive tuned by IdahoRob...
473hp & 920ft/lbs
BoiseRob is offline   Reply With Quote
Old 11-03-2009, 08:25 AM   eBay Motors   #3 (permalink)
gunmetalsi
gunmetalsi's Avatar
don't' have oil coming out of dip stick. i also have not lost any more coolant out of the reservoir. No smoke out the tail pipe. So I'm totally lost.
Bryan
Old 11-03-2009, 08:34 AM   eBay Motors   #4 (permalink)
DuramaxSMOKE11
DuramaxSMOKE11's Avatar
when my head gaskets went the samething happened. i thought maybe i had a bad pump or something or bad EGR cooler because my upper hose never got hard either. come to find out it was the head gasket.
2005 Chevy 2500HD Duramax LLY, Banks ram air intake w/super scoop, Banks 4" exhaust, CAT DELETE and NO MUFFLER, EGR blocker plate & fingerstick, Fisher SS ExtremeV plow, Auto Meter Gauges, Boost, Pyro, Fuel Pressure, turbo resenator blocked off, PCV Reroute. SoCal Stage 1 heads, ARP Studs, BD Manifold, diamond eye down pipe, AFE mouth piece, AFE intercooler pipes, PPE standard, KMC Rokstars 20" wheels with Nitto Terra Grappler AT
To come soon
AFE Intercooler, Raptor 150 pump, SunCoast tranny & TC
Big thanks to chad at Alligator performance and Guy at SoCal Diesel
DuramaxSMOKE11 is offline   Reply With Quote
Old 11-03-2009, 08:45 AM   eBay Motors   #5 (permalink)
gunmetalsi
gunmetalsi's Avatar
How long did you drive the truck before you replace the head gaskets?
Bryan
Old 11-03-2009, 08:47 AM   eBay Motors   #6 (permalink)
DuramaxSMOKE11
oh a few days then the truck sat in my garage for a month before i took her all apart. it got to the point that i was going threw more water in a mile then what the truck would hold
To come soon
Old 11-03-2009, 08:55 AM   eBay Motors   #7 (permalink)
RedBowTies88
RedBowTies88's Avatar
you could always get a compression test
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
Old 11-03-2009, 08:56 AM   eBay Motors   #8 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
Wolf creek is a climb, did that with a trailer and 01 lb7 a few months ago to ATS. isnt that climb heading into Pagosa springs???
as far as your issue, maybe it was your lower rad hose that connects your degas bottle to your radiator... just a thought.
Old 11-03-2009, 09:21 AM   eBay Motors   #9 (permalink)
gunmetalsi
gunmetalsi's Avatar
it makes every other pass seem simple.
Brian your talking about where the "TEE" in the line right. I had coolant residue on the lower hose but nothing on the block that i could tell.
Bryan
Old 11-03-2009, 09:23 AM   eBay Motors   #10 (permalink)
Hondarider552
Yeah right at the T. mine has come loose and dripped before, but not gushing out like it seems yours did
I crossed wolf creek bout 2 months ago, cold as hell and foggy as hell, fun pass though.
